New owner
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JEP, Jan 3, 2014.
  1. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Listen to your wife, no matter how cold it is it doesn't stop me, I have a great heater in my PiP it's called the gas engine!
  2. JEP
    JEP Junior Member
    Sweden
    2013 Prius Plug-in
    The pre heater I ordered is manufactured by Defa (Norweigan I think)
    It consist of a block heater, usually 300-500Watts and then there is a cabin heater also from Defa. In Sweden they are often at least 700Watts. All in all to take full advantage of a 220V 6Ampere outlet. When sub-zero degrees and often down to -10-20 degrees celsius you need this pre heating.
    Looking forward to the summer :)
    52,814
    you're right, but when you're only going a few miles here and there in this weather, the ice won't provide much heat anyway.:)
    retired4999 likes this.
    52,814
    thanks, will you be using the cabin heater?
  5. JEP
    JEP Junior Member
    Sweden
    2013 Prius Plug-in
    Yes on sub-zero degrees to get rid of the ice on the windows.
  6. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    With grill blocking starts raising cabin temps pretty fast, I'd say in less than 5 minutes.
  7. markabele
    5,084
    1,782
    Nebraska
    "Starts" is the key word there.
    It all depends on trip length/duration.
  8. bisco
    52,814
    and outside temps. the colder it gets, the more i want heat and the longer it takes. plus, in all honesty, i like ev miles:p
  9. JEP
    JEP Junior Member
    Sweden
    2013 Prius Plug-in
    I need to check that out, grill blocking. I have read about it but don't know how exactly how it's done. I have seen a few threads about it here.
    Thanks.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep, I have at least two trips a day of 2.7 miles, takes me about 4-6 minutes. I do that in all EV. I can't see the need for heat for such a short trip. Ask me again after the next four days! :eek:
  11. bisco
    52,814
    is it below zero again?
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Nope a hot 20 degrees but wait till tonight -13, high Sunday -5 low -26, Monday -12 low -26, Tuesday -3 low -16.
    At least no snow! like you! :D
  13. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Brrrrr...still going out for coffee?
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    Only way to keep warm!:D
    jdk2 likes this.
  15. bisco
    52,814
    we got hit pretty hard, especially along the coast. not bad here, 12-15" of light and fluffy. it's the cold i can't stand. if we had temps like you, i would have to knock my house down and build a superinsulated one. i think i've used half a tank of oil in the last week just trying to keep it in the mid 60's.
  16. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I'll bet they are using a 12 volt heater...?
  17. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Ah. Different animal.
  18. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Easy - just drive at no more than 40MPH, preferably on level ground. ;-)
  19. bisco
    52,814
    no, it was 120v.
  20. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I think I'd have a little Folgers stored somewhere. If I didn't have a filter, I'd use a paper towel before going out in those temps :cry:
