New PHEV SE any hints
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by DigDoug, May 19, 2026.
  1. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Waiting on my new Plug in Prius, in black. Any hints from anyone? I know just drive it but charging advice, AC temp advice anything? Going to be the first new car I purchase since a 92 Geo Metro so please realize I am tighter then two coats of paint when it comes to expenditures. Thank you all in advance. Have a great day
    Gokhan, ColoradoBoo and bisco like this.
  2. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    It’s a great car and very economical! Enjoy!
    I drive my SE mostly in “Normal” mode. Around town, spring, summer, fall I can get 80 to 90 km of EV range, but significantly less in winter. If I’m trying to squeeze out maximum EV range, I run without using the a/c or heat and use the heated seats and/or crack open the windows, if it’s too warm.
    The car will also start the gas engine if I go down a long hill with a full traction battery and especially in cooler conditions, so I shift into neutral and coast down to avoid this, since I live at the top of a hill.
    Also, the gas engine starts immediately if you press the front defrost button.
    DigDoug and bisco like this.
  3. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    So using the ac will lower your mileage with the EV? Oh well I will adapt I guess.
    #3 DigDoug, May 20, 2026
  4. Schize
    Schize Junior Member
    United States
    2023 Prius Prime
    XSE
    I, too, live at the top of a hill and run into this annoying gas engine downhill with a full traction battery issue. Unfortunately, I live in California where going downhill on neutral is a moving violation and can be ticketed - I imagine it's pretty darn unlikely to get pulled over for it, but it could be a risk if an accident happens and it comes up as a compounding factor. Might be worth checking local jurisdiction just to be informed.
    As for tips, if you weren't driving a hybrid before, maximizing regen braking and momentum will do wonders for MPG. Assuming you're plugging in at home, run some calculations and check with your utility to see if they have EV rate plans that make sense with your electrical usage as a whole.
    DigDoug likes this.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,354
    982
    Monument, Colorado USA
    Congrats on the new ride! I'd spend the extra $$ and get the oil changed at around 700 miles....get any break-in debris out of there.
    And use your air conditioning....the hybrid battery uses cabin air to cool itself so you never want to be driving around in 90+ degrees without cooling the cabin.....an overheating traction battery shortens its life.
    PrimeDan, Tande and DigDoug like this.
  6. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    I thank you all for the responses. I was hoping they had not made a change with the hybrid system so I can still enjoy my ac. I was hoping to have my new ride yesterday but there was a problem with the finish on the front by the Toyota emblem and on the the roof itself. Looks like protective shipping wrap bled into the clear coat. They are trying to rectify it at a body shop.
  7. LRO
    LRO Member
    97
    98
    United States
    2024 Prius Prime
    XSE Premium
    The 5th Gen Prius Prime/PHEV models moved the large Hybrid/Traction battery outside of the cabin airspace and it is now underneath the vehicle. So instead of relying on cabin air temps and fans in the cabin like past years this battery uses the vehicles one and only AC compressor via a split system to cool itself independently whenever it feels the need. It doesn't ask permission, give you options or let you know when it does this. When the battery wants to cool down to be healthy, safe and performing at its best for the life of the vehicle it just calls for and gets cold refrigerant delivered via its own line which circulates throughout the battery enclosure. So do as you wish running the AC for your own needs in the cabin without even thinking of the battery. The vehicle is engineered to take care of both at any time.
    PrimeDan, DigDoug and RX808 like this.
  8. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I doubt Toyota will change the HV cooling system in the Prius PHEV until a gen6(if it happens), but I really like what they've done with the current EVs and the new PHEV RAV4. It reminds me a little of a residential ground source heat pump. They've got a much less complicated refrigerant loop, and they use a refrigerant-to-liquid coolant intercooler/heat transfer module to harvest and distribute heat so much better than previous systems.
    But I don't want to derail, so check out TheCarCareNut's videos on the bZ, C-HR, and/or Lexus RZ if you're interested. (They all have the same powertrain/HV system. So if you watch one video on the cooling loops, you've seen them all.)
    DigDoug likes this.
  9. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    I absolutely love TCCN. He just released a video about the C-HR and I will watch it again when I get off work. Thank you for the information.
  10. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    To preserve the traction-battery life:
    1. Don’t store it at higher than 70% SOC. (Ideal storage SOC is under 40%, perhaps around 25%).
    2. Don’t charge it after it is driven (when the battery is hot).
    3. Use the charge schedule to charge it immediately before you drive.
    4. Avoid sudden acceleration in the BEV mode.
    5. Use the BEV mode mostly for city driving.
    6. Don’t leave it plugged in for longer than overnight (to avoid draining the 12-V battery).
    7. Use a Noco Genius on the 12-V battery immediately after you purchase the car and then every few months to keep it healthy.
    DigDoug likes this.
  11. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Picked it up today. Drove it home all on EV. Worked like a charm. Charging the battery now, hoping to see how long I can go before I use gas. I doubt it will be too long though. I did want to ask though, has anyone other than Bisco charged their battery outside? How about when rain is in the forecast? Any comments would be appreciated muchly.
  12. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Can I ask about the Noco Genius? This intrigues me.
  13. Hammersmith
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's just a battery charger/maintainer. The basic ones come in 1A, 2A, 5A, and 10A versions. Noco is a popular brand, but there are many others out there that do the same thing. A 2A works just fine as a maintainer, but it's rather undersized if you need it to actually charge a battery(~30hrs to fully charge a dead car battery). If you want one device to do both jobs well, look more to the 10A version(fully charge car batt in 6hr). I actually have one of each. I have a 2A hard-wired to my car for occasional maintaining, and a 10A in the garage for charging batteries and maintaining my lawn mower battery over the winter.
    With the Noco, you can disconnect the clamps and bolt the eyelets directly to your car battery. And then that section of the cord detaches from the actual charger with a weather proof connector. That means you can have a little pigtail sticking out of the Prius hatch and you plug the charger into that. Makes for a neat and tidy install(though I wish the pigtail was about an inch longer - it fits, but you have to stretch it tight).
    Gokhan likes this.
  14. Gokhan
    6,715
    2,672
    Paramount CA
    I have the 5-amp Noco Genius, but for maintaining it, even the 1-amp version should be OK. Even with the 10-amp version, full charge takes about 48 hours, as the final phase of the charging profile is a small-constant-current charge phase.
  15. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Thank you both. I will look into it
  16. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    I have to ask how long should I wait after a short drive home to plug it in? Today it is 93 degrees out, drove home with the air on and my battery is down to 7%. I wanted to got for a drive when they wife gets home around an hour from now.
  17. Gokhan
    6,715
    2,672
    Paramount CA
    Perhaps you can manually turn on the battery refrigerant cooling system?
    DigDoug likes this.
  18. LRO
    LRO Member
    97
    98
    United States
    2024 Prius Prime
    XSE Premium
    You don't have to wait to charge at all The vehicle has an A/C system engineered to automatically keep your battery at the best temperatures for driving and for charging. When plugged-in and charging, the A/C system has what Toyota calls a "Battery Alone Mode" that'll operate the electric A/C compressor for the batteries benefit. It's completely automatic and there's no manual control of it. It might just take a little longer to charge your battery when it's hot since some of the power you're providing via the plug has to be used to power the A/C system too and during those times less power would be available to go to your battery.
    PrimeDan and DigDoug like this.
  19. DigDoug
    DigDoug Member
    92
    25
    Pennsylvania
    Thank you both.
  20. Mendel Leisk
    42,361
    It's always been thus, there's no free lunch. Being a Plug-In doesn't negate that.
    Depends on various factors, but as often as not I'll settle on 24C (75F).
    Templeton and DigDoug like this.
