New PHEV SE any hints
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by DigDoug, May 19, 2026.
  1. DigDoug
    DigDoug Member
    85
    25
    Pennsylvania
    I normally have it set at 72. I think either The Car Care Nut or Scotty Kilmer recommended that. So far this car has exceeded my expectations by leaps and bounds.
  2. Templeton
    Templeton Active Member
    359
    127
    usa
    2024 Prius Prime
    SE
    Yes, the use of AC or heat will eat up a little bit of range when in EV mode. We have had an SE prime for a little more than a year. With the insane gas prices, we have saved a lot of money because we now rarely buy any gas. And here are some of my gen5 PHEV suggestions:
    When on local streets or stop/go traffic, say, 50mph and under, stay in EV mode. When getting on a highway or freeway, say, over 50mph for at least 20 min., put it in HV mode.
    Keep track of all your gas purchases. For us, it is easy because we buy very, very little gas since we drive on electricity so often. Record the purchased gallons and then multiply that no. by the EPA rated highway fuel economy no. and the you'll get the number of HV miles driven. We then keep track of the cumulative HV miles for the purpose of not overdoing oil changes.
    Change the oil the first time at around 500-700 miles, but not 500-700 total miles. Change it at 500-700 HV miles.
    After the warranty period is over, consider changing your oil every 5000 miles. But, again, not 5000 total miles, but every 5000 HV miles. If you keep your HV trips longer than 20 minutes, this will keep moisture from collecting in your oil. If you keep track of HV miles, don't worry if your oil change interval is more than a year, synthetic oil lasts for years even when in a crankcase, as long as the ICE miles are low.
    Do other recommended maintenance checks and tire rotations based on the total miles on the car.
    Try to do your own oil changes to make sure they are done right (and they will be a lot cheaper too). Because the level of competence at many car and toyota dealerships is extremely low. And the level of fraud is very high. At dealerships, they very frequently mess up on very simple things that can be very hard (or impossible) to fix or reverse. I stocked up on toyota oil filters and l got a fumoto oil valve which allows me to very easily drain the car's waste oil directly into a container, vs having it splash all over into a tub.
    Consider getting a MillerCat catalytic converter shield. The shield is big so we got the aluminum version to save a bit of weight. It is not super hard to install if you have some decent metric tools. I painted the main part of the shield orange so that it is more visible to a thief under the car, this makes it more of a deterrent. For additional deterrent value, I also put the included MillerCat decals under the car on a mostly vertical part of the underbody plastic so any thief trying to look under the car from either side will know that this will not be an easy sawzall job.
    The gen5 has a big windshield and a big rear window. To reduce the heat load on the car when parked outside in the summer, consider getting a front window and a rear window reflective shield. l found that the ones made by the heatshieldstore are some of the very best available in terms of fit and cooling power.
    Don't fully charge the car unless you will be fairly quickly (quickly after charging) driving a good distance on EV mode. Otherwise, just charge it partially if it is gonna sit for a little bit or if your local trips are shorter than the full EV range of the car.
    When it is cold outside and you drive on local streets and then get on the highway, put the car in HV mode at least a mile before the beginning of the fast highway portion to allow the ICE to fully warm up. You can monitor ICE warm up by looking at the "energy flow" diagram on the center screen. The ICE has just barely warmed up when the engine block on the energy flow diagram changes from a blue color to an orange color.
    Well, that's a start. If l think of other tips, l will post later. Good luck!
    #22 Templeton, Jun 20, 2026
    PrimeDan and DigDoug like this.
  3. DigDoug
    DigDoug Member
    85
    25
    Pennsylvania
    Thank you very much
  4. Templeton
    359
    127
    usa
    2024 Prius Prime
    SE
    A question for you: how do you charge? At home? 120V ? 240 V ? Using the OEM oyota charging cable or a dedicated charger device (also known as an EVSE) ?
  5. AgentPTFC
    AgentPTFC Member
    63
    42
    PNW
    2025 Prius Plug-in
    XSE Premium
    I've never noticed that, I'll have to check that out.
    But I do the same thing if I know I'll getting on the interstate for a while. I turn on HV mode in town on the way to the interstate to warm up the ICE so I'm not going 80 when it needs to go under load.
    Templeton likes this.
  6. Templeton
    359
    127
    usa
    2024 Prius Prime
    SE
    Here you, the engine block shown on the left side of this prius prime SE image shows up in a gray cloor when in EV mode and then changes to blue when HV is activated and changes yet again to orange when the coolant gets warm in HV mode. This is viewable on the center screen ("energy flow"):
    AgentPTFC likes this.
  7. AgentPTFC
    AgentPTFC Member
    63
    42
    PNW
    2025 Prius Plug-in
    XSE Premium
    I might spend a little gas and drive home today in HV mode to see that in action haha. That is a really neat little detail.
  8. DigDoug
    DigDoug Member
    85
    25
    Pennsylvania
    I have so far only used my home Toyota charger on 120V. I would like to get one of my electrician friends to install a 240V line to the outside but we have not matched our schedules yet.
  9. DigDoug
    DigDoug Member
    85
    25
    Pennsylvania
    And I am planning on checking out the middle screen show this morning on the way to work, it sounds interesting.
  10. Templeton
    359
    127
    usa
    2024 Prius Prime
    SE
    Understood. We also charge outside and we have two PHEVs. Right now we mostly use 240 volts, but sometimes we use 240v for one car and 120v for the other car. You may know this, and while this is not "toyota approve", in North America, the OEM charger cable that toyota provides for the Prius PHEV is dual voltage, as it works on 120v and it works on 240v (with a proper adapter). So we had a electrician install two outlets on the outside of our house (each on separate circuits), one outlet is a nema 14-50 240v outlet and the other is a typical GFCI 120v outlet. This allows us maximum flexibility regarding charging one (or two) PHEVs and we will still be able to charge a BEV, if we get one in the future.
    Here is our set up, the black adapters (shown hanging in the pics) allow us to switch our charging cable(s) from the 120v outlet to the 240v outlet (and vice-versa) on an as-needed basis:
  11. DigDoug
    DigDoug Member
    85
    25
    Pennsylvania
    That is pretty neat. I so far am satisfied with the slow charger. Also looking at getting one of the NOCO charger/maintainer from Amazon since they are a prime day deal
  12. LRO
    LRO Junior Member
    74
    88
    United States
    2024 Prius Prime
    XSE Premium
    When you do look at your "Energy Flow" graphic I suspect It'll look like this improved version. Lucky you. Toyota North America for all their marketing talk of Over-The-Air (OTA) software updates has been unable or unwilling to do a single one for any North American owner's of the 5th Gen Prius. Yet, in the EU and Japanese markets they have been providing customers with OTA update(s).
  13. Templeton
    359
    127
    usa
    2024 Prius Prime
    SE
    Nope, unfortunately, our 2024 SE has the older version of the graphic like l posted somewhere above ...
  14. LRO
    LRO Junior Member
    74
    88
    United States
    2024 Prius Prime
    XSE Premium
    Good mention because it is one of the rare times to get a sale price on that brand. The Prius owner's manual specifically made mention of the max slow charge rate as being 5 amps so I chose the NOCO GENIUS5 charger during prime days last year and use like quarterly, especially in cold winter months. It has certainly attained a bulk charge to something under 100% in less than 8 hours when the last green light will continue to flash but if you can leave it connected for 24-72 hours until that last green light goes solid it'll continue to do all kinds of magic and pump as much energy into the 12-v as it can safely take (something you would only notice if you're OCD and have infinite time to monitor that progression). So it does something extra that the car's battery management system would never achieve if you have the time and desire to.
    Also picked up a NOCO Boost X GBX45 Jump Starter as I just wanted to be prepared and not have to wait on others. I've only had to use it for jump starting twice now, not for my Prius which has never failed me but to save other stranded souls. It's amazing what that little thing can do even to save a big gas powered van. But, rather than just buying a jump starter, I chose this one because it can be charged up through its high power 60w usb-c port ---and--- that same powerful usb port can be used to charge any of my own usb devices like phones and even laptops way faster than any Prius port (I wouldn't even try a laptop on a Prius port). So, it's insurance to always get going again without a wait and on rare occasions when I need that extra fast charging speed for my devices I'll pull it out from under the seat and use it to charge those devices. And it's got a nice LED flashlight too.
    Obviously the world is full of all brands and capabilities and I'm only sharing my choices. I never even heard of NOCO until joining PRIUSchat and now that I own two I'm grateful and appreciative of having heard of that brand here. All thanks to the good people here.
    DigDoug likes this.
