New PiP Owners...More data please!!!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iRun26.2, Mar 6, 2012.
  1. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Going over 1600 miles before needing to finally fill my car with gas is impressive enough to me to justify the purchase. I don't need any other 'math' quotes about my car to tell other people what my car can do for me. (Of course, as an engineer, I love numbers so I am always excited to improve my mpg numbers even if I don't quote them to other people :) ).
    Most people scoff at the fact that I 'only' get 12 to 15 miles of all EV driving per charge (and I darn near hate it when people ask). Charge at home, work, and home again each day really can add up quickly.
  2. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    I wonder how much the lack of ICE use will catch up with engine parts.
  3. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    We call that MPG$
  4. stephens5.rich@gmail.com
    [email protected] New Member
    39
    Los Gatos, CA
    My first tank. I finally had to get gas!
    EV 499 miles
    HV 533 miles
    Total 1033.1 miles
    9.5 gallons
    CONS 111MPG
    117kwh
    Fuel Saved by Charge: 9.7 gallons
  5. iRun26.2
    824
    169
    United States
    I think I know what you mean, but could you please explain precisely what you were referring to?
  6. iRun26.2
    824
    169
    United States
    You did very well! I really like seeing the 'Fuel Saved by Charge'. That really puts in perspective.
  7. bfd
    659
    172
    If a PiP is in a situation where it can almost always be run in golf cart mode, I'm wondering how that might affect the ICE.
    More of a general assumption - maybe not even valid - but it would seem as the use of EV increases, the use of ICE decreases.
    So maybe in the worst cases (or best, depending on whether someone is looking at highest EV use) the ICE is hardly ever warming up to an operating temperature. So the carbon build up on pistons, petroleum grime build up on the injectors, etc. etc. accelerates at a faster pace than it might on a car that is ICE only. Over time, I'm not sure there's much data on how this might affect a hybrid's ICE.
  8. iRun26.2
    824
    169
    United States
    When the ICE comes on, it does not turn off immediately, even if the reason it was turned on in the place does 'goes away' (you demanded lots of acceleration but only for a short time). I get the impression that the warm up is complete, finishing at a higher temperature than the normal Pruis.
    You could be right, though, in some instances. It is uncharted territory but I am hopeful the Toyota engineers got it all figured out. I expect to be fine simply because I burn gas about 1/3 of the time during the week (and sometimes will drive 300 miles on gas during a single weekend).
  9. bisco
    52,803
    drove my pip home from the dealer today. 12+ miles, all ev. let it cool down and recharged it for the big test. would i be able to make my commute in all ev? the cool thing was, the range started at 13.3 but as i was driving, the odo was going up more than the range was going down. when i got to work, the range was 7.9 and the odo was 7.6. it's a total elevation drop of 90'. when i got home, the odo was at 14.7 and the range was still at .4 miles. this answers the question i have had since the first test mules came out. can i make my commute on all ev? i love this car. feeling the same exitement i had when i got my first pri in 04!
    2 people like this.
  10. iRun26.2
    824
    169
    United States
    That's awesome Bisco!
    I always like to try to play the game of getting the odometer to go up faster than the range go down. I can do this when I start and finish my commute (because I'm driving slower then).
  11. hill
    9,018
    I got lost here. How does 50 electric miles match 1 gallon. If gas has approximately the energy (discounting anywhere between 6kWh to 12kWh) of 36kWh of electricity ... then even at 3 miles per kWh (for example) ... you'd get over 100 miles down the road. If you equate 50 electric miles with 1 gallon, you're valuing your EV range at only 1.3 miles per kWh. Or, maybe i'm missing something.
  12. Jozo
    Jozo PIP PIP HOORAY!
    145
    27
    Sacramento
    I haven't really needed any gas since taking delivery of my PiP 2 weeks ago, but I had a long drive for work today, so we topped off the tank for the first time and calculated 85.75 mpg, which I think is FREAKIN' AWESOME for the very first time! YAY!
  13. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    You are right, the really significant point is getting over 1000 miles a tank and that should be the selling point of the PIP. The math is interesting, but too complicated and still not covering every factor, ie: Kwhrs reproduced by regeneration.
  14. andyprius
    2,212
    188
    Congrats Bisco. :cheer2:
  15. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Think "gallons saved".
    Then say "Oh, yeah. Duh." ;)
  16. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    188 miles, all in HV mode, almost all highway, inside stuffed with cargo, 2 bikes on back.... 46 MPG.
  17. iRun26.2
    824
    169
    United States
    John,
    What would you have gotten with your Gen 3 Prius in a similar situation?
  18. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    True, but bear in mind that some people only care about half the story. I think part of the reason we will continue to struggle with how to compare mileage/efficiency in plugin vehicles is that there are so many different things to compare. And given that everyone that buys one has their own unique reasons, there isn't really any such thing as the right way.
    For someone that primarily cares about reducing consumption of petroleum, either from a resource conservation or energy independence perspective miles per gallon of gasoline may well be the bottom line.
    MPGe based on btu efficiency may well be the "right" way to do it, but may really only matter to us engineering types who actually care about maximizing thermodynamic efficiency.
    For those with a more environmental bent, well to wheels pollution or GHG emissions may be more relevant and will vary greatly depending on where your electricity comes from.
    For those with a more economic bent, $/mi may mater most and will depend greatly on the relative costs of gas and electricity.
    And I'm sure there are plenty more ways to look at it that aren't occurring to me right now :)
    Its certainly worth bringing these topics up and discussing, but I think its also worth remembering that there's more than one "right" way.
  19. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    One of our members, and one of my own PHEV buyers, asked me to post these three pics. His name is Jack. He's in Missouri! Looks like his mileage is awesome!
  20. bisco
    52,803
    back to work again tonite. since i had .4 miles of range left yesterday. i decided to drive a little faster tonite. a little more acceleration and kept up with the speed limit. crawled into my garage with .1 left. when the battery icon switched from solid to barred, i thought the engine was going to come on.:eek:
