New PiP Owners...More data please!!!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iRun26.2, Mar 6, 2012.
  1. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    With the PiP's great 'gas-only' gas mileage, one would think that there would be no so such thing as 'range anxiety'. Well, for Bisco (and myself and others) there still is: It is the "I sure hope I can make it home without needing to use any gas!" type of anxiety.
    It is very easy to avoid starting up the ICE when driving a PiP (the EV-only acceleration is awesome and the heated seats are very nice). I turn on the engine only when my trip will require gas at some point (when it is > 14 miles away). It love getting home from round trips where no gas was used.
  2. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    We call that gas anxiety.. or ice-anxiety
    You know you have it bad when you decide you can drive 25mph in a 40mph zone just to make it home.
    Jimbo69ny likes this.
  3. Mark Y
    Mark Y Junior Member
    Connecticut, USA
    Haha. And I feel bad for driving 61mph in a 65mph zone (while in EV range)...
    -- TouchPad using Communities
  4. Jozo
    Jozo PIP PIP HOORAY!
    145
    27
    Sacramento
    Hi. I'm curious about how to get my 'gauge' to appear as red in the upper ICE zone...mine is just a pale green-gray. Is there a setting for this?
  5. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Maybe you are looking at the Hybrid System Indicator, which is green-gray instead of the EV Driving Ratio, which is what the photo is showing.
  6. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    176 miles today, using 9 miles of EV capacity, maximum speed 60 mph, temperature 50°F.
    With the greatest of ease, the result was 61 MPG.
    Gotta like that.
  7. john1701a
    12,820
    5,305
    58
    Just checked the display for end-of-day stats. Turns out it was actually 62 MPG.
    That's great for a road trip, but driving 550 miles of highway travel (2/3 with bikes on back) recently sure will make the lifetime average misleading. Oh well, that is what real-world data is all about.
  8. john1701a
    12,820
    5,305
    58
    Well, my PHV certainly is broken in now.
    Today's road trip was 194 miles. There was a steady and sometimes heavy rain the entire time. The temperature was 43°F, requiring both defrost & heat to continuously run. Two bikes were strapped into a rack on back, creating quite a bit of drag cutting through the water. There was no opportunity to plug in. And the interior was stuffed with cargo (including a 3-wheel recumbent).
    That made for very ugly Spring travel conditions.
    I wasn't exactly thrilled by the thought of what the outcome would be. Although this drive is really going to bring down lifetime average, it does provide real-world data in far from an ideal situation. Fortunately, even when Prius is challenged, it still shines.
    The result display was 39 MPG. What else could accomplish the same feat, especially without plugging in?
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    This is where gasoline is superior than battery -- energy density.
  10. Jozo
    145
    27
    Sacramento
    OMG! It never occurred to me to try and put my 'bent in the back of my PiP! Which one do you have? I have an ICE Adventure FS, and it can fold, but it's kind of a pain in the nice person to fold it and then unfold and re-attach the tires. All three of my tires are 20". Tell me about your 'bent and how you squeeze it in!
  11. john1701a
    12,820
    5,305
    58
    It fits great. Good thing too, since carrying 2 on back is needed on trips like this. You can even seat 3 people inside. More photos here... http://john1701a.com/prius/album/prius-album108.htm
    2 people like this.
  12. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    John, I've had your homepage John's Stuff - Toyota Prius and more bookmarked for a long time. Are you planning to do any evaluations of the different modes in PHEV land? I'm thinking about the EV, HV, ECO, PWR modes and how they each affect mileage and performance.
    And maybe more importantly, how these modes can be used in conjunction with each other to enhance mileage or performance.
    I know the data points for the PHEV are still at the "slim or none" stage right now, but eventually there will be more. You've done a great service of observing and collecting data on the various Prius you've owned. Thanks again!
  13. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    2nd Fill Up:
    Tank Miles: 858.4
    Pump Gallons: 7.276 (multiple clicks to reach $30.99, evening out my gift card remaining amount)
    Calculated MPG: 117.98
    MFD Cons. MPG: 122
    EV Driving Display (tank)
    kWh: 117
    Gallons: 6
    Gallons Saved: 9.8
    EV%: 63
    EV Miles: 548
    HV%: 37
    HV Miles: 310
    EV Driving Display (lifetime, 2 fills)
    kWh: 213
    Gallons: 15
    Gallons Saved: 17.8
    EV%: 59
    EV Miles: 978
    HV%: 41
    HV Miles: 670
    Calculated Numbers: (factoring in estimated 15% charging loss where applicable)
    Miles/kWh: 3.98
    kWh/100mi: 25.11
    HV MPG: 42.6
    MPGe: 75.6
    Also forgot to add.. I disconnected my battery today. After reconnecting it, a full EV charge displayed 13.4, same as when my car was brand new (actually, I think my first full charge showed 13.3, cant totally remember now). Prior to disconnecting my battery, a full charge was showing 12.4 (which was a slow and steady climb up from a low of 11.2 or so, from a few weeks ago)
  14. bfd
    659
    172
    Interesting, did you lose any other settings besides the EV charge?
  15. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Everything in the radio was still there (presets, saved destinations, bluetooth pairings, etc). The monthly MPG total on the MFD was still there as well.
    The only thing I "lost" was all my trip odometer and EV driving data, my charge timer times (defaulted all back to 12AM) and the MFD date (defaulted to 1/1/2011).
    Thats all I can think of/checked.
  16. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    Well, the wait is over and I finally broke down and refueled for the first time in 4 weeks.
    I've entered this data on the Google spreadsheet, but the EV/HV driving ratio and EV/HV miles, kwh, gallons used, are all lifetime.
    1022.2 miles on trip meter
    8.561 gallons to first click on pump
    16 miles DTE w/one bar left on fuel gauge
    122 cons mpg
    25 mph avg
    110 khw metered at house on Kill-a-watt (meter not active until 3 days into this tank, so maybe add 9 kwh?)
    119.64 calculated mpg
    Have probably recharged away from house 5 times at free public charge station.
    Lifetime:
    664 ev miles, 1346 HV miles
    138 kwh, 22g
    fuel saved 11.5 g
    electricity is 11.4 cents/kwh for the EMC in our area
    This car is just freakin' amazing.
    2 people like this.
  17. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    crewdog, your HV miles displayed 1346?? is that a typo? should it have been 346?
    Sorry, I just noticed it was your 3rd or 4th fill-up.. I thought it was your first (missing the "first in 4 weeks" part)
  18. mrbigh
    3,686
    699
    Long Island, NY
    :rockon:Kudos for you !!
  19. crewdog
    493
    388
    Woodstock, GA
    That's a lifetime figure;
    I reset the EV ratio for trip 1 this time :rolleyes:
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    You are doing great! Using the MPGe calculator from XPrize, your composite (gas+electric) vehicle efficiency is 76 MPGe.
    Much higher than Volt owners average 58 MPGe.
