New piston design.?
Discussion in 'Gen 3 Prius Main Forum' started by taxidriver50005, Mar 15, 2019.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Nope;).
    Since the egr takeoff is still before catalytic converter, you'll get the same buildup:cool:.
    But at least there are videos and plenty of experienced folks available to help(y).
    #21 Raytheeagle, Jul 24, 2020
    Majafamily and Grit like this.
  2. Mendel Leisk
    42,343
    ^ I should update this. I've heard the new rings and old pistons (or vice versa) are not compatible. Accordingly, it seems likely what happened was "sometime" through 2014 model year, both the rings and pistons were switched (to the new part numbers), at the same time.
    Steph1972 and ASRDogman like this.
  3. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    I believe you, even 4th gen Prius with after cat-EGR still have the same issue. In short, any cooled EGR design need regular maintenance in EGR and intake manifold cleaning. It will still be a problem until Toyota come out with something radicals like how Toyota/Lexus used dual-injection (direct and ports) to eliminate common GDI intake valves problems.
    52,849
    oh no...:unsure:
  5. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Do you know someone who's torn into a Gen 4 EGR??
    Raytheeagle likes this.
  6. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    I have one in my parts bin, but the donor engine had only 5K on it. It looks the same for the cooling fins and surround tank,
  7. wr69
    wr69 Member
    143
    79
    portland, or
  8. TNToy
    TNToy Member
    70
    42
    Memphis TN
    Only when doing a 4th gen swap. Engine wass claimed by eBay seller to be a 2018 with 35k miles. Was a US-market engine, and by far the cleanest used motor I’ve ever installed.
    Looked absolutely brand new inside valve cover when pulled. EGR cooler had very slight carbon dusting inside. Nothing that would have begun to inhibit flow.
    I used the 4th gen’s EGR in my swap into a 2011 with 206k miles. Had to restrict the flow into the intake, since the 4th gen’s EGR has a lot more flow and roughly double the surface area inside the cooler.
    Everyone else uses the old engine’s EGR when doing a motor swap. I wanted to be difficult.
    3G inlet and outlet pipes got cut & welded to fit 4th Gen EGR:
    Size comparison - 3rd gen is in my hand:
  9. TNToy
    TNToy Member
    70
    42
    Memphis TN
    It is extremely easy. If you have skills to pull an engine and replace with the same, you’re golden. Prius have the easiest engine to drop and swap you’ll ever do. No starter, belts, etc. No torque converter or clutch to worry about. Only 1 motor mount. You can pull the engine with intake and exhaust manifolds attached to it, no need to strip before removal.
    Then install flexplate, intake, exhaust, engine mount off you old motor and drop it back into the car. The only hard part is some tweaking of the EGR brackets and re-routing the coolant lines since things are in new spots.
    I have done 3 now. My own car and two others. Being a former Toyota Master tech, I tend to do some sidework on Japanese vehicles. Did two for guys in the Memphis area. Charged $3,600 including price of the engine. All three run flawlessly.
    mjoo likes this.
  10. bisco
    52,849
    this thread should be pinned
    mjoo likes this.
