New Prime owner with a Question
Discussion in 'Prime Main Forum (2017-2022)' started by ToeJamFootball, Nov 2, 2022.
  1. ToeJamFootball
    ToeJamFootball Junior Member
    17
    I finally received my 2022 Prius Prime. With my old 2012 Prius hybrid I could unlock or lock the doors by touching the driver’s door handle. On my new Prime, I can unlock the door by touching the handle but I can’t figure out how to lock it that way. I really like not having to fish the key out of my pocket to lock the car. Is there a way to do that?
  2. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    There are 2 raised lines on the outside front of the handle. you touch there and it will lock the doors. Depending on your trim level it may be on the Drivers side only.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You could also push the door lock switch on the driver's armrest on the way out. Then what I usually do after closing the driver's door is grab the rear passenger door handle to make sure all doors are locked. Then I feel confident I can walk away leaving the car locked.
  4. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    On my 2020 XLE I can touch the two lines as MalachyNG mentioned and it will lock all doors. I know there are some options for door locks in settings.
    Congratulations on your new Prime! Don’t forget to update your profile.
    #4 Prim.e.xample, Nov 3, 2022
  5. ToeJamFootball
    17
    Thanks for the replies. I got it now. To unlock, I grab the handle and hold it. To lock, I touch the 2 lines on the door handle.
    I am really enjoying my new Prime. I read through the manuals but there is a lot details in there that are easy to miss.
    drash likes this.
  6. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Just touch the inner surface of the handle for a very short duration.
