New Prime Owners: (Things discovered/Likes/Dislikes)
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Nov 20, 2016.
  1. lroki
    lroki Member
    83
    103
    Sacramento, CA
    I agree. And the Michelins will provide long read life too. I got 100,000+ miles on a set on my Gen2 Prius. I'll switch to that brand first chance I get.
    NeilPeart likes this.
  2. Eric Maple
    Eric Maple Junior Member
    27
    28
    Mattoon IL
    The 1st thing my kids pointed out was the back seat at the bottom on both sides of the car. It sticks our far enough that is makes you want to slide down in your seat. But besides that it's a nice driving and riding car.
    52,876
    that's weird.
  4. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    Are these tires really quiet?
  5. lroki
    lroki Member
    83
    103
    Sacramento, CA
    Yes. Every car I've owned came with something other than Michelins. When they need to be replaced, I always get Michelins and I am reminded why: quieter, better ride, longer tread life.
  6. bisco
    52,876
    virtually silent. there are still other noises such as wind and the sounds coming off the road through the poorly insulated body panels. but the reduction in noise from the oem tires to the michelins was dramatic.
    Coast Cruiser and CTorPrius? like this.
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I've been using Bridgestone Ecopia Plus's and I think they are quiet. What are the OEM tires?
  8. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    Have you tried the Michelins before? Which are better?
  9. lroki
    lroki Member
    83
    103
    Sacramento, CA
    Dunlop Enasave 01 A/S
  10. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    I will be getting these bad boys next time. I didn't think there was such a difference between tires.
  11. Mendel Leisk
    42,361
    I recently downloaded and compiled into a pdf, the Owner's Manual for the 1958 Volkswagen Beetle. In about 80 pages, they covered:
    1. All the basics, very thorough.
    2. Driving tips.
    3. Engine oil change, extensive explanation of oil grades.
    4. Transmission and differential fluid changes.
    5. Steering gear lube.
    6. Suspension lube.
    7. Wheel bearing lube description.
    8. Door and window lube.
    9. Seat track and shift lube.
    10. Tire inspection and removal, jacking.
    11. Body care, washing, waxing.
    12. Interior upholstery cleaning.
    13. Cleaning of glass, maintenance of weather strips.
    14. Air filter service.
    15. Fan belt adjustment.
    16. Carburetor clean/overhaul.
    17. Valve adjustment.
    18. Spark plugs, timing
    19. Battery maintenance.
    20. Fuses.
    21. Headlight aiming, bulb replacement.
    22. Brake adjustment, bleeding. (the latter only with optional hydraulic brakes, lol)
    23. Brake adjustments.
    24. Steering gear adjustment.
    25. Front toe-in check.
    26. Front wheel bearing check.
    27. Door lock adjustment.
    28. Exploded views with extensive identification of engine and transmission.
    29. Extensive description of chassis, transmission and rear axle, brakes, body and heating system.
    30. Seven pages of technical specifications.
    31. Maintenance chart.
    32. Six page index and supplied tool list.
    '58 Volkwagen Beetle Owner's Manual | PriusChat
    #31 Mendel Leisk, Nov 27, 2016
  12. Lee Jay
    5,850
    4,036
    No.
  13. Mendel Leisk
    42,361
    Any particular Michelins??
  14. Lee Jay
    5,850
    4,036
    The low-rolling-resistance ones called "Energy Savers".
    lroki and Mendel Leisk like this.
  15. bisco
    52,876
    i just got the energy saver a/s. and we just had the ecopia's put on my daughters '08. she's halfway back to new york, and says they are very quiet as well. not sure what she had before them.
    Glipzcom, Insirt and Coast Cruiser like this.
  16. Lee Jay
    5,850
    4,036
    I only have 8,000 miles on my Ecopia's. Maybe I should have the dealer keep the OEM tires and put my Ecopia's on my new Prime when it comes in?
    bodgm likes this.
  17. bisco
    52,876
    toyota uses several brands on the same models. so i would wait and see hat they are, do some research and a test drive, then decide.
    i was going to keep my old tyres, and if i traded in or sold, swap them out and use the michelin's on the next car. but i decided i'll just swap them if i trade. if i sell, that would be more money, and i'll decide about new tires based on what i think of the oem's.
  18. lroki
    lroki Member
    83
    103
    Sacramento, CA
    I think I would have done that has I thought of it earlier. I guess I was too excited to have gotten the car.
  19. lroki
    lroki Member
    83
    103
    Sacramento, CA
    Take a look at reviews of the Dunlops. There send to be an issue with tread life. They are known to be noisy as well.
  20. lroki
    lroki Member
    83
    103
    Sacramento, CA
    "There seems to be...."
