New Prius already in shop. :-(
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mad4sax, Oct 5, 2012.
  1. mad4sax
    mad4sax New Member
    26
    Marcellus, New York
    With less than 900 miles on my 2012 Prius the yellow ! triangle came on and a message Problem with Hybrid System. :-(
    It is at the dealer now to be looked at tomorrow.
    Booooooooo!
    52,847
    ouch, very sorry to hear that. hope it's something simple, all the best!
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    better now then after the warranty expires i always say. ;)
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Maybe it's the 12V aux battery? NOT! Bwah hah hah!!!!
    Sorry mad4sax, I just couldn't resist needling the Optima worshipers
    who blame every conceivable fault on that appendix of a battery.
    Please lettuce know what the stealership finds. It's unusual for a Toyota
    and especially a Prius to have an concern like this so early in its life.
    You'll be on the road again soon, maybe even tomorrow.
  5. mad4sax
    mad4sax New Member
    26
    Marcellus, New York
    Well I guess the Toyota Experts on hybrids don't work on Saturdays. The dealership can't figure it out.
    So they have to wait until Monday to talk to Toyota to get it fixed. :-/
  6. mad4sax
    mad4sax New Member
    26
    Marcellus, New York
    Well the verdict is in ... a loose connector on the Hybrid Battery Cable. They don't think it was pushed on all the way when built. Took 800 some miles to loosen up enough so one pin was not touching. Let's hope this was the only issue. Must have been built late on a Friday!!
  7. bisco
    52,847
    glad that's all it was!
  8. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I had the same problem after the Toyota dealer installed a ReInVolt replacement HV Battery in my 2004 (Gen2) Prius at 195,000 miles. The connector worked loose after 1500 miles of driving (I was 900 miles from home but luckily I was within 3 hours driving of AutoBeYours in Indiana and Steve fixed it in 30 minutes for only $40.
    JeffD
  9. pinkkitty724
    pinkkitty724 Junior Member
    65
    Phew! I am glad to hear it was something small/easy. My heart sank when I read your post because I just got my new Prius a lil' over a week ago and am petrified that something will go wrong!
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Was that a high power cable or a signal cable? If it was a power cable, there is a good chance of heat damage for the pin and connector. In my line of work, I find a lot of old, abused Harting connectors with loose connections melting down due to high resistance at the loose connection.
  11. mad4sax
    mad4sax New Member
    26
    Marcellus, New York
    The whole system was working it just had the error.
    I would hope the service guy would have made sure the connector is fine. I hope!
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Hopefully the computer stopped it when it detected a voltage drop from the loose connection and it never ran high current through the partially made, loose connection.
    The systems we use at work are dumb. The PID will drive harder if a loose connection drops some volts. It just melts down quicker.
  13. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The connector that came loose in My 2004 Prius was a low signal level connector (sensors, communications, ...), not one of the 200v connectors.
    JeffD
  14. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I can just see John Belushi in "Samurai Prius Assembler" as the Line Foreman tells him "I had a call from the States. Mad4sax had a loose battery connector. We traced the car to your Monday morning shift..."
