New Prius C owners please post
Discussion in 'Prius c Fuel Economy' started by alfon, Mar 9, 2012.
  1. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    you need to set the date. :)
  2. rlalford
    rlalford Junior Member
    31
    Durham, NC
    Filled-up this morning: 543 mi since last fill-up; added 9.514 gal. (with 2nd squeeze). Cutting things a little close, but very pleased!
  3. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    Does the C give you a low fuel warning?
  4. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    But of course.
  5. frugaldriver
    frugaldriver Ceterum censeo Carthaginem delendam esse - Cato
    81
    26
    Somewhere over the rainbow
    What kind of MPG's does the c get with cruise control on freeway trips, or do most individuals here refrain from using cruise (as I've heard that it decreases you MPG's with the c)? This drive would be on mostly flat highway with no significant hills or dips. Figure going around 65 mph.
  6. mam677
    mam677 New Member
    Albuquerque
    I put in 8.2 gallons today, having gone 430 miles. I love me some 52.4 mpg's!
  7. j_benj
    j_benj Prius C Fan
    125
    Jersey
    hit a personal record on my commute home today!
  8. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    I went faster then normal on the freeway yesterday to see how MPG are on high speeds and with some hills going 75-80 MPH I still got 50mpg shown. Even that is amazing when your on a long road trip and I think it will go up more if I was flat road.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    How long was that trip and was it a round trip?
    I'm trying to figure out the point at which the c drops below the efficiency of the GenIII at highway speeds.
    We all know the GenIII is more aerodynamic and has a slightly higher highway mpg rating but real world data gathered by Wayne Gerdes and folks here at PriusChat are showing the c is now slouch when it comes to great freeway mpg. We often recommend the GenIII when someone mentions a long highway commute and only recommend the c when they have an urban commute. I think many people on this forum need to rethink that advice in light of these new reports. :)
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In addition to the negative impact of a cold engine, cold ambient temps reduce fuel economy by increasing rolling resistance and aerodynamic drag (if driving at speeds above 50mph). This is another reason why your morning mpg potential is generally lower than your afternoon mpg potential. Yet another reason to keep your tire pressure at proper spec levels or higher. ;)
    The information in this thread applies not only to winter but cooler morning commutes as well.
    http://priuschat.com/forums/prius-c...summer-mpg-vs-winter-mpg-prius-c-version.html
  11. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    My first two hand-figured fill ups came out to 48.x and 49.x mpgs. The car's estimation was quite optimistic, and wrong.
  12. priusCpilot
    663
    210
    LA
    I was not long about 20 miles and with me was my friend in his Prius Plug In. He had no plug in battery power left so it was hybrid at the time of start. It showed exatly 50 mpg. That was what was funny. Also he was 2 miles ahead when I got on the freeway so I was going a bit faster.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You should try topping it off until you can see fuel in the filler neck and see if it is still optimistic when you refill again. When Wayne Gerdes tested the c it was almost dead on accurate but he only drove 50 miles or so. It would be interesting to see how this works over 500 miles. :)
  14. jacku
    jacku New Member
    Last weekend I did the 140 or so miles from St Paul to La Crosse Wisconsin. I had filled the tank the Sunday before to see how much gas I used during a "regular" week of driving. I made it all the way to La Crosse and back 50 or so miles to Kellog, MN. I filled the car there. The gas gauge was at 30% (3 spots) and it took 7.018 gallons of gas. The calculated mileage was almost exactly 53 mpg. (52.99 was the calculation) I don't remember the cars calculation, but I think it was between 54 and 55. (I have it written down but not handy.)
    I'm taking a trip from Minnesota to Florida in about a month so we'll get some good data then.
  15. whtrabbitjoe77
    whtrabbitjoe77 Junior Member
    16
    S Lehigh Co PA
    Just filled my car up for the second time and I calculated 48mpg for both tanks. Per driving trip the computer was showing 50-55mpg, so something is off. I checked the tires and they were set at 32psi f/r from the dealer so I fixed that. i will see how the next tank turns out.
    Joe
  16. Prius-C1
    Prius-C1 Junior Member
    Wisconsin
    ^^^^^what did you set them to? Higher I assume?
  17. GraeSack
    GraeSack New Member
    30
    Lacey, WA
    Picked up Pc3 yesterday. Took a forty mile drive of mixed urban, suburban and freeway. Averaged 56.1 per the display. Filled up this morning and will track full tank with calculator, SG and display.
    All the best.
  18. arlotone
    arlotone New Member
    25
    Portland, OR
    For my second tank, I drove 466 miles on 8.56 gallons, which equals 54.4 mpg. The computer estimated 57.99.
  19. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
    First click to first click netted me 54.79 mpg. Driving 442 miles on 8.067 gallons. I forgot to look at what the Trip gauge said, but it was around 55 leading up to the fillup.
  20. rwiggins951
    rwiggins951 Junior Member
    Cleveland OH
    This is the third week with my Prius C3. My wife has been consistently getting an average in the low 70 MPG (indicated) for her 30 mile round trip commute. The trip is a mix of city and highway. She drives carefully, certainly, and this is our second hybrid. I see mid to high 50s in my more aggressive rush hour drive. Better results would be easy if I were to slow down a bit. I have been exceptionally pleased overall.
    Rod
