New Prius Handling Components to be available soon!!
Discussion in 'Sponsored Commercial Sales' started by BT Tech, Jun 8, 2005.
  1. BT Tech
    BT Tech New Member
    885
    South Florida
    Already working on that project!! In my experience however, the support across the top of the struts will basically enhance handling while driving at the extreme limits. In everyday driving, one would rarely notice its value due the placement of the support.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
    <div class='quotetop'>QUOTE(Poppajack747\";p=\"98572)</div>
  2. ScubaX
    ScubaX Member
    484
    Redding, CA
    <div class='quotetop'>QUOTE(DanMan32\";p=\"98751)</div>
    But when does or did mid-2005 production begin?
  3. leeskarha
    leeskarha New Member
    79
    <div class='quotetop'>QUOTE(ScubaX\";p=\"98830)</div>
    [/b][/quote]
    Has anyone taken delivery of one yet?
  4. BT Tech
    BT Tech New Member
    885
    South Florida
    I wanted to keep everyone updated on the progress of this new part and am happy to report that they have all been cnc machined and are currently being hard annodized. The machining is first rate and looks superb!!
    The plates should be ready to ship within the next 7-10 days. I will be contacting everyone on my list as soon as I have them in stock and are ready to ship out.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  5. mongo
    mongo Junior Member
    31
    I've sent you mail. If it will fit my 2004 Prius, I'm interested!
  6. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    Please do not forget me - we spoke about this already. Cairo94507
  7. Craig0812
    Craig0812 New Member
    36
    Houston TX
    Brian(Blkc5),
    What are the plates(handling) you are referring to? Is this something the dealer has to install?
    Please advise....
    Thanks.
  8. cairo94507
    923
    36
    Auburn, CA, USA
    Craig - I am pretty sure if you read the thread all of your questions will be answered. Looks pretty good to me; I am going to put one on my car.
  9. Craig0812
    36
    Houston TX
    Cairo -
    I will definitely go back through the threads..jumped too soon on that one..thanks!
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i think we need to clarify some questions that keep popping up here.
    1) this mod will work on any 04 Prius and newer.
    2) installing is simply removing a similiar stock plate attached by 4 bolts and re-installing the mod plate. doable by virtually anyone i would think.
    i would be very interested in hearing about anyone's thoughts after installing this plate. i realize this only enhances the driving experience on the performance end. however, the extra stability would come into play if ever one would need to perform evasive manuvers to avoid an accident. at $150, its a pretty cheap insurance policy in my book
  11. BT Tech
    BT Tech New Member
    885
    South Florida
    Hello everyone.... Let me try to clarify a few points about this new part.
    This is designed for the 2004 and 2005 Prius. The part is very easy to install and will require a simple socket wrench. It will probably fit the 2006 model as well but it is unknown at this time.
    One does not need to drive the car aggressively to be able to discern the difference in the vehicles stiffness/handling with this part in place. What this part does is to significantly stiffen the body's torsional rigidity resulting in less flex in the body and better handling.
    This part does NOT interfere with the vehicles engineered crumple zones due to the placement of the plate.
    If anyone has any questions, please feel free to ask.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  12. BobR
    BobR Member
    336
    <div class='quotetop'>QUOTE(blkc5\";p=\"102141)</div>
    Is this like Tom's Floor Strengthening Brace?
    http://newtoyotaparts.com/product/?id=1741
    Bob
  13. Whitey
    Whitey New Member
    33
    This is the type of mod I'm looking for. Unfortunately, I live in Michigan and must consider corrosion resistant materials. I'm assuming that the nut (whether it is a weld nut or cage nut) welded to the body is steel. This plate is aluminum. I know that if the bolt attaching the two is not zinc treated, there can be long-term corrosion issues in regions that use salt and/or other chemicals to melt snow/ice in the winter.
    Brian, you can count me in if there are organic zinc treated bolts to attach the plate. Otherwise I must live with a flexible Prius.
  14. BT Tech
    BT Tech New Member
    885
    South Florida
    Hello Whitey.. Our plates were designed with you guys in mind.. The plate starts out from billet 6061-T6 and is CNC machined and then hard anodized with a black finish. The bolts that I chose to use are stainless steel cap bolts that are recessed and when tightened are flush with the plate so there is nothing protruding for zero wind resistance.
    The 6061-T6 material and hard anodizing have superior strength and corrosion resitance which means it will probably outlast the car itself!!
    Thanks!!
    Brian
    BT Tech
    305-652-3115
    <div class='quotetop'>QUOTE(Whitey\";p=\"106553)</div>
  15. Bill Merchant
    Bill Merchant absit invidia
    4,096
    86
    [font=Comic Sans MS:fd872f7cb5]So when can we actually buy them?[/font:fd872f7cb5]
  16. BT Tech
    BT Tech New Member
    885
    South Florida
    I spoke to the anodizing shop today and the plates should be ready to ship to me by tomorrow!! I am hoping to have them in stock and ready to ship out to everyone on my list by next week.
    As anyone in manufacturing knows, there unfortuanely are delays that occur, espeically in high precision CNC machine shops. The fact that this was a low volume run put my job on hold several times but this is unforunately the nature of the business.
    I have not taken payment by anyone at this point as I wanted the plates to be in stock and ready to ship out before I bill anyone. There are few things worse than to pay for something and not even have it ready to ship!!
    Thanks!!
    Brian
    BT Tech
    305-652-3115
    <div class='quotetop'>QUOTE(Bill Merchant\";p=\"106643)</div>
  17. BT Tech
    BT Tech New Member
    885
    South Florida
    Hello everyone.. I wanted to show what our plates look like prior to the hard anodizing. These are completely CNC machined and really came out superb!! Note the internal ribbing and radiused curves.... The hard anodizing will add a black color so the final product will be black.
    I still have a few plates that will be available from this first run so if you want one, please email me your information.
    I should have them ready to ship out as soon as I receive them back from the annodizer!!
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  18. genalex
    genalex Member
    265
    Jersey suburbs of Phila.
    Yes, but what was the "mid-year" cut-in date for the stiffer chassis change?
  19. cairo94507
    923
    36
    Auburn, CA, USA
    Brian, I still want one as soon as they are available. I want to do whatever I can to help my Prius handle better.
    Thank you, Michael
  20. BT Tech
    BT Tech New Member
    885
    South Florida
    Prius Chassis Stiffening plates ready to ship next week!!
    We just got word that our Prius stiffening plates have been completed and are shipping to us!! To all of you that our on my list, I will be contacting you shortly. There are still some plates available so if you want one, please contact me.
    Here is a picture of our completed plates without the anodizing applied.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
    **Please click on the picture below for a more detailed look**
