New Prius or New Camry Hybrid?
Discussion in 'Gen 5 Prius Main Forum' started by David9962000, Sep 22, 2024.
  1. bisco
    52,432
    agreedm but i drove one and found it to be too high :p
    our bolt is kind of a small suv or cuv, and just about the right height for us.
  2. Prodigyplace
    12,690
    11,834
    Central Virginia
    I have now had my 2025 HyCam XLE for a week. about 300 miles, with whatever fuel the dealer gave me. I know from my Prius, 10% ethanol giver higher mpg. My current overall average is about 44.5 mpg or a little higher, I hope to improve on that with breakin, ECU learning, & more hybrid driving. Much of the current driving was my 3.5 hour highway drive home.
  3. Winston Smith
    Winston Smith Active Member
    413
    288
    OH
    2024 Prius
    LE AWD-e
    I'm fairly sure that my dealer overfilled my Prius tank. I drove back 150 miles getting off the highway early and ripping around on some secondary roads, then commuted for a week. At 479.8 miles I filled the tank with 7.757 gallons, 61.85 miles per gallon.
    I think it's more likely that they stuffed an extra gallon in the filler neck than I got my best efficiency so far on initial highway miles.
    52,432
    about 2,600 miles of that trip was highway. from here to virginia, it's a stop and go nightmare.
    then the rest of the trip is mostly 70mph.
    ours does much better around town, which is pretty amazing for a cruiser. i keep the tyres at 42/40 i think,
    Prodigyplace likes this.
  5. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    My Prius PHEV is currently in service centre waiting for a replacement part to arrive, and I got the Camry 2024 hybrid as temporary.
    I must say it's certainly a good vehicle as well, but for my needs it is a bit too heavy (1600 kg vs 2100 kg), too big, fuel consumption is around 1,5l per 100 km higher, it is considerably slower (compared to PHEV, probably much closer to HEV version), BUT it is certainly much more roomy and comfortable on bad roads - 17" on my Prius, 17" on Camry.
  6. Gokhan
    Gokhan Senior Member
    6,568
    2,619
    Paramount CA
    In America, bigger is better.
  7. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey man, I had this exact scenario about a year ago when I acquired my 2023 prius. After a year of driving this vehicle and putting over 25k miles on it, I seriously recommend you to buy the camry (not the 2025/new camry), it has alot better build quality and I think it's more comfortable. The only upside for the Prius is the trunk has a large accessible flat surface as well as 10mpg higher I believe. Cheers!
  8. bisco
    52,432
    hycam slower than plug in prius? wow!
  9. Hammersmith
    Hammersmith Senior Member
    2,332
    2,392
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The 2025 Camry AWD is almost as quick as a Prius PHEV, but the outgoing model is noticeably slower. JoeBlack is correct that a 2024 Hycam should feel similar to a FWD gen5.
    Sorted by 0-60 times
    2024 Prius PHEV - about 3500lb - 220hp - 0-60 in 6.6sec
    2025 Camry AWD - about 3650lb - 232hp - 0-60 in 6.8sec
    2025 Camry FWD - about 3500lb - 225hp - 0-60 in 7.0sec
    2024 Prius AWD - about 3280lb - 196hp - 0-60 in 7.1sec
    2024 Camry Hybrid - about 3550lb - 208hp - 0-60 in 7.4sec
    2024 Prius FWD - about 3100lb - 194hp - 0-60 in 7.5sec
  10. Leadfoot J. McCoalroller
    8,155
    7,657
    Pennsylvania
    2018 Prius c
    Plus lookathat red leather!
  11. Gokhan
    6,568
    2,619
    Paramount CA
  12. JimLudden
    JimLudden Member
    Taos, NM
    2024 Prius Prime
    After driving Camry's since 1984, I switched to Sienna for 15 years. Then bought '24 Prius Prime. Great car, but much smaller than the Sienna and notably smaller than the Camry.
    I'd say your primary consideration is size (but I'm 5'-11").
  13. Gokhan
    6,568
    2,619
    Paramount CA
    I sat in it again last week. It is smaller, but not unforcortably small. A bigger car is mostly psychologically more comfortable (as in less claustrophobic). The interior is pretty nice. With every generation, cars are slightly more improved (in most areas, though with backsteps in some).
  14. Hammersmith
    2,332
    2,392
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I have to say, I really like the front end look of the XSE Camry in Wind Chill Pearl. Not enough to give up a hatchback, but still...
    Optioned out the way I would want it, I was looking at about $45k(or about $5k above what I paid for my Prius).
