New Prius owner, old Prius problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BuildingInspectorBrian, Jul 16, 2021.
  1. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    You or whoever owned this car before your has kept it clean inside and had no shedding pets with a fan that looks as clean as that.
    Also, always nice to see a pack that hasn't been taken apart before... Sometimes you look at the bolts and can tell pack has been removed many times and things go from bad to worse really quick with those ones.
  2. BuildingInspectorBrian
    BuildingInspectorBrian Junior Member
    32
    Tacoma
    20210721_175119.jpg I'm a little worried about the pattern revealed under the battery. This appears to be water spots (all dried now).
  3. BuildingInspectorBrian
    32
    Tacoma
    Looks like it has been worked on. But they did a good job cleaning and putting it back together 20210721_175657.jpg
  4. BuildingInspectorBrian
    32
    Tacoma
    Found my culprit. Couple cells at 7.4, replacing those as well. Everything else was at 7.7 20210721_181937.jpg
  5. BuildingInspectorBrian
    32
    Tacoma
    Well, it's not pretty but it runs.
  6. BuildingInspectorBrian
    32
    Tacoma
    Btw, **** oh dear all the battery nuts are fiddly as all heck. Took me longer to mess around with those than anything else.
    Thank you @PriusCamper. Those modules are strong, 2nd life is awesome. Still have to put the insides back together but I'm going to call it a night.
    Thank you everybody on this site, all these discussions and information here helped me a ton. Can't wait to pull it all back apart and put a new battery in.
  7. BuildingInspectorBrian
    32
    Tacoma
    Well, day two. The pack is still functioning, the blocks look a little closer to equalizing. The lie o meter, I mean the mpg estimator says I'm getting 50+ mpg right now. I'll do the actual math next week, but it's usually only over by 1 or 2 mpg, so not bad for sure.
  8. pgaster
    pgaster New Member
    Illinois
    Lots of water leak videos on youtube:
    The good news is that is seems like an easy fix. Silicone, flex seal, or something similar should work well.
    There is a rubber drain plug in the battery area if you have water there.
    I have a 2006 and it had a few inches of water in the 12V battery area. I tried silicone. It's really messy looking but hopefully it works. If not I'll add more.
  9. BuildingInspectorBrian
    32
    Tacoma
    Very helpful! Thank you. I'll have to spray the car down and see if I have a water leak. I've driven in the rain several times since I've purchased the vehicle and I didn't see any standing water when I opened it up(although it's been several months since we've had any actual rain).
  10. BuildingInspectorBrian
    32
    Tacoma
    20210726_053925.jpg Well, the modules (according to dr Prius) look like they're stabilizing. Obviously they won't be balanced unless I find somebody to do it, but the fuel mileage is actually a tic better than prior to the pack repair.
    Another likes this.
  11. JoeX
    JoeX Junior Member
    PA
    If your car maintains mileage, I think the batteries you installed were close enough to the original ones and will balance with the rest of the pack while driving.
  12. BuildingInspectorBrian
    32
    Tacoma
    In the continuing saga of this old Prius, we see today's (poorly estimated by the computer) mileage still doing quite well. So far I'm incredibly happy with the results(here's hoping I get 6-9 months out of this repair, I'd be ecstatic). Also, that last 5 minutes of driving is a 350' elevation gain getting off the highway to my office, lol. I have one on both sides of my drive, it's 500' on the home side of the drive though. (Driving through the valley to get to and from work).
    I can't say enough about how much this forums resources have helped me. Thank you all so much for the support you've given to a nobody on the internet. Especially thanks to @PriusCamper , pnw to the rescue!
    #32 BuildingInspectorBrian, Jul 27, 2021
    SFO and PriusCamper like this.
  13. BuildingInspectorBrian
    32
    Tacoma
    Okay, I'm going to make some assumptions here.
    #1 the battery pack was already failing when I bought the car
    #2 that I filled the gas tank as much as possible (one "top off" attempt, I was incredibly surprised when it shut off, more of a "it can't be full" than a top off, should be full full. When I filled the tank after the repair I did not try to top it off, just fyi and i now know topping off is bad thanks to this forum).
    #3 the lie o' meter lies both ways on the prius(it showed 55.8 mpg average prior to filling tank)?
    I'm a "it's 1/4 I'm going to fill it" kind of guy (I hate stopping at inconvenient times to fill up). So prior to my pack repair 350 miles was 7 gallons ish(just explaining my early fill up). The gas gauge showed I still had plenty of fuel, but based on my prior driving experience I fueled up same as usual. I was shocked when it first stopped at less than 6 gallons of fuel pumped.
    Did I not fill it up full, or is my fuel mileage really 59+ mpg?
    (Yes I know the fuel gauge in the picture shows the tank less than full, it hadn't fully registered yet and I was in a hurry to get out of the way at the fuel pump. Busy station even at 04:45)
    #33 BuildingInspectorBrian, Jul 29, 2021
  14. BuildingInspectorBrian
    32
    Tacoma
    The more I read on here, the more quirks I learn about this old Prius. So because of the gas tank bladder you can't actually do the mpg math reliably, just keep track of it and hope it's fairly close?
  15. BuildingInspectorBrian
    32
    Tacoma
    Also, I've been doing a bit of research on getting a new battery for this old Prius. I'm finding it difficult to wade my way through this site in terms of finding the different options. I've seen several online, yet I only see one thread for an aftermarket battery on this site mentioned. Is there a single thread that has all the traction battery replacement options(maybe user experiences as well)??
    @ericbecky @PriusCamper
    #35 BuildingInspectorBrian, Jul 29, 2021
  16. PriusCamper
    13,476
    5,441
    It's all about using google search with the right keywords...
    In order of cost from lowest to highest... Your options are
    --rebuilt pack like via Craigslist, Dorman, Green Bean and others...
    --NewPriusBatteries cylindrical cells.
    --Brand new OEM pack
    --ProjectLithium.com pack.
    SFO and BuildingInspectorBrian like this.
  17. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    It would be hard to keep track of all the good (and bad) options out there.
    As much as possible, of you swing ~$2,000 and have skills to do it yourself, I'd say stick with OEM from dealership parts department.
