New Prius...what is this
Discussion in 'Gen 2 Prius Main Forum' started by Dirtnapper, Apr 2, 2007.
  1. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    <div class='quotetop'>QUOTE(derk @ Apr 3 2007, 12:11 AM) [snapback]416820[/snapback]</div>
    You do realize there is a sunglass compartment on the top area of the car where the reading lights are don't you? There is a compartment door, that when you push it, it drops down for a storage area for your sunglasses.
  2. jiepsie
    jiepsie New Member
    267
    <div class='quotetop'>QUOTE(adam1991 @ Apr 3 2007, 02:46 PM) [snapback]416956[/snapback]</div>
    Soon they will tell us not to drive the car, because a moving car is dangerous and you might kill someone or be killed.
  3. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    <div class='quotetop'>QUOTE(lowlander @ Apr 3 2007, 10:27 AM) [snapback]416982[/snapback]</div>
    That's not a bad suggestion, actually. They should also warn us not to purchase the car because the expense could put your financial security in peril.
  4. Sarge
    Sarge Senior Member
    1,323
    778
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(hyo silver @ Apr 2 2007, 11:45 PM) [snapback]416843[/snapback]</div>
    I use 'the shelf' for my digital tire pressure gauge and my small change pouch, since there is no coin holder in this car. <_< Works great.
    As far as the "orange glow" from the glovebox, I must say I do not have this problem with my '06. I seem to recall there is a foam liner around the seal for the glovebox that prevents the light leak...? I do not know... would need to take a closer look.
  5. Dirtnapper
    Dirtnapper Member
    104
    MA
    2014 Prius v wagon
    Thanks...I'll check in the glovebox to see where it might attach. I have a tray inside the arm rest compartment.
