New Prius XLE - Wheel Question
Discussion in 'Gen 5 Prius Main Forum' started by sparkydog, Jul 26, 2023.
  1. sparkydog
    sparkydog Junior Member
    Maryland
    2023 Prius
    Picked up a new 2023 Prius XLE yesterday. It's the daily driver for commuting from MD to the DC area. I want to order a spare XLE wheel since the roads around DC have world-class potholes. Last car (VW GLI) received 3 cracked wheels in 5 years. Does anyone have the part number for the XLE 19" wheel?
  2. Hammersmith
    Hammersmith Senior Member
    2,451
    2,515
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Either 42611-47551(Dicastal) or 42611-47671(not Dicastal).
    Toyota sources the wheel from two different manufacturers, so there are two different part numbers. I'm sure they're 100% mechanically interchangeable, and probably 100% cosmetically interchangeable as well. But if you want to be completely certain they're cosmetically identical, you'll need to pull off a wheel and check the back for which logo it has. It will either say Dicastel or have a logo that looks something like ( S ), where the S part is shaped like the Sennheiser logo. I tried to find out which brand the logo belonged to, but I hit a brick wall. One source said they come from Thailand, but I couldn't narrow it down beyond that.
    sparkydog likes this.
  3. sparkydog
    Maryland
    2023 Prius
    Is the spare (wheel only) the same for all 2023 Prius? Is 42611-21280 also correct for the XLE with 19" wheels?
  4. Hammersmith
    2,451
    2,515
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yes. One wheel to rule them all, one wheel to bind them.
    Mendel Leisk, sparkydog and Trollbait like this.
  5. Fz6r
    Fz6r Junior Member
    Las Vegas
    2023 Prius
    Does anyone happen to know the part number for TPMS?
  6. sparkydog
    Maryland
    2023 Prius
    Great - thanks, appreciate the response!
  7. Hammersmith
    2,451
    2,515
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    42607-47020 VALVE SUB-ASSY, TIRE PRESSURE MONITOR - $100.02 MSRP
  8. Mendel Leisk
    42,264
    If this is for a temp spare, I would just use a regular valve.
  9. Hammersmith
    2,451
    2,515
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    For a compact spare, absolutely. I don't even know if the sensor fits in a compact spare.
    For a full-size spare, it depends. If you're going to be keeping the spare in the car at all times and/or rotating it with the other four tires every 5k miles, it's probably worth installing the TPMS valve and getting some sort of scantool that allows you to register them yourself(so you don't have to pay a dealership to do it for you a couple/few times a year). But if you plan to just leave the spare out of the car most of the time and not rotate it, then it's probably not worth the hassle/money to use a TPMS sensor over a regular valve.
  10. Mendel Leisk
    42,264
    When our TPMS fail, I'll probably just go to reg valves. AFAIK that's still legal up here.
  11. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    That's not required - the manual explains how to register them yourself, and switch between 2 sets, via the multi-information display.
  12. Hammersmith
    2,451
    2,515
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Nice. I had heard that, but hadn't checked the manual yet to be sure. Way nicer(and cheaper) than the old days. I like that there's the option for two sets of tires, but I wish there was an option to include a spare tire. You can still use a fifth wheel/tire in a rotation, but it looks like each rotation will involve more programming steps.
  13. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    Apparently the catch is you need to make sure you've got new-enough sensors (post-2018?). So make sure no dodgy dealer tries to give you an old part.
    Although maybe that's not really an issue, due to non-removable batteries? Old ones should be well past their best-before date...
  14. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    @KMO how did you managed for the winter tyres 19". Now in EU prices went bananas.
    And i do not know if the various ADAS or sensors get confused passing to a 17" set..
  15. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
  16. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    I got the 17" optional 5-point dark metal rims from the EU accessory/option brochures, fitted with 215/55R17 Nokian Hakkapeliitta 10s.
    Rims shown here:
    Wasn't particularly keen on that wheel style, but I think they look better in the flesh. And I guess it's nice to change style occasionally. I'll certainly know which season it is.
    That came to just under €2200, I think, including TPMS and installation.
    Although Toyota Finland are now including winter wheels+tyres free on Priuses along with various other models: https://www.toyota.fi/tarjoukset-kampanjat/toyota-talvirengaskampanja
    Site doesn't say what exactly they're specifying beyond "winter tyres with alloy rims €0", but I imagine it's the same as what I got, possibly with friction rather than studded. (They say "worth €2372", and my bill indicated a couple of hundred euro discount. My first estimate for 19" was over €3000).
    Overall wheel circumference isn't changed significantly by the 17"/19" change, so shouldn't be any sensor issues.
    I had been expecting to need a "change inspection" for the rim size change, but that was waived - I think Toyota Finland did their type approval paperwork.
    #16 KMO, Oct 24, 2023
