New production OEM primearth modules question?
Discussion in 'Gen 3 Prius Technical Discussion' started by Spaminacan, Aug 14, 2025.
  1. Spaminacan
    Spaminacan New Member
    Hello I am going to pick up a new hybrid battery from Toyota for a 2014 Prius.
    I have used the OEM packs for second generation repair in the past. I was wondering if there is any difference in the modules the put in the gen 2 and gen 3. I'm aware of the case and connection differences but are they using the same primearth modules for both versions?
    Why not use a gen 3 pack? A $500 difference for 28 modules, so I'd like to know if there is any good reason to pay the extra money. I've rebuilt several traction batteries so a module swap to different case is not an issue.
    Thank you
  2. Tombukt2
    Tombukt2 Senior Member
    13,836
    2,512
    Durham NC
    Modules same but in gen3 case you get parts you do not in gen2. If not plug in same thru at least 16 I believe .
  3. Tombukt2
    13,836
    2,512
    Durham NC
    You'd be able to lv bus bars etc undo the I do t know how many tee niny screws on bottom tray and lift racked assembly .
  4. Spaminacan
    Thanks, If the modules are exactly the same, stripping and replacing the old modules+bus bars with new takes about 30 minutes, well worth the the savings.
  5. Tombukt2
    13,836
    2,512
    Durham NC
    I've never heard the modules called prime Earth but if that the Panasonic 200 volt DC prismatic modules 28 assembly then yeah . I was just saying if one of the batteries is way cheaper like that like the generation 2 you could just lift the rack of 28 modules all with the bus bar still intact and the squeezer rods still on
  6. PriusTech
    PriusTech Active Member
    264
    133
    Reno
    modules are the same
  7. Hayslayer
    Hayslayer Active Member
    529
    320
    Panasonic was the original manufacturer "name" of the prismatic modules used in the Prius and many other hybrids, etc. After a handful of years, Panasonic spun off their battery division and partnered with Toyota to form PrimeEarth. You probably just never noticed the name Panasonic was replaced by "PrimeEarth" on the exterior hybrid battery model number/serial number labels, etc.
  8. Spaminacan
    Hello, a quick update on the swap. The gen 3 Prius has been running with no issues for the last two months on the new gen 2 modules. Thanks everyone for the info.
