New Registered key is not being detected
Discussion in 'Gen 3 Prius Technical Discussion' started by Gourockian, Jun 23, 2023.
  1. Gourockian
    Gourockian Junior Member
    75
    23
    New Port Richey
    I've just bought a new off-market smart keyfob for my 2013 Prius and registered it using Techstream Ver: 12.20.024. It locks and unlocks the car from over 50ft away but doesn't work via the door handle sensors.
    Also, when trying to start, it displays 'Key not detected" so I have to touch the power button with the key to enable the start procedure. This does not always work right away and can take up to about a minute and during this time, the tiny red LED flashes.
    I've checked the keyfob battery and it's at 3.3V. Is it possible to have two fobs set up differently in that I need to customise the new one to match the original? I did notice when checking the battery that the ciruit board contains four switches, although the case only has three buttons so I'm assuming that the same board is used for models with A/C control.
    Any help would be appreciated.
    Thanks,
    Al
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    From what I was told, a dealer has to "fully unlock it". Techstream work around isn't permanent. But I may be wrong. I had to go to a dealer when I lost a key and needed another one.
  3. Gourockian
    75
    23
    New Port Richey
    I think that would be the case where the key has been previously registered to another vehicle but mine was new. I'm not sure what you mean by "Techstream workaround not being permanent" as that is what the dealer techs use.
  4. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Take it back to Toyota where you had it done and tell them.
    They programed it, they should make it right.
  5. Gourockian
    75
    23
    New Port Richey
    Toyota didn't program it, in fact the keyfob does not actually get programmed. It gets registered so that the car recognises it and I used Techstream to do this myself. It is a straight forward process and there was no indication that there was any issue. The fact that it can lock and unlock the car remotely suggests that it is correctly registered but possibly not configured to match the original one.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    Sounds like the op did it himself
  7. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Those smart keys are two keys in one. There's the long range active radio that lets the fob buttons work, and there is the much shorter range passive RFID system for the ignition lock and proximity door handles.
    You registered one of the two parts of your new key. If you still have the old key, you can physically transfer the RFID capsule from the old shell to the new one. If this was due to a lost key, it'll be a different procedure.
    I don't know the full details of that procedure, but that's what's going on.
    Montgomery likes this.
  8. Gourockian
    75
    23
    New Port Richey
    Thanks for that information. It certainly matches what I'm experiencing so maybe I'll need to try and re-register it. Swapping the old module into the new shell is not really an option as I'm trying to provide a separate key for my wife. We downsized recently to only having one car and I feel that there is now a greater chance of the original getting lost (that's all I'm prepared to say).
  9. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    You have to have the little tiny RFID chip in the remote that someone's going to carry so little trapezoidal shaped plastic things usually in the bottom of the remote I think you want to be having that in your new remote or something along those lines. Are two remotes for my Gen 2 they're silverback logos they're supposed to be proximity sensing I never have to withdraw the remote from my pocket for the car to unlock when I get to it and for me to sit down and start it without touching the remote in my pocket My broken remote Will open and unlock the car if I push the buttons on the remote meaning I have to reach into my pants and touch the remote If I don't pull the remote out before I sit down I have to fumble around to get the remote out of my pocket and insert it into the slot to start and use the car because there's something wrong with its board in the remote the one that I have to insert and push the buttons on The other remote that came with the vehicle I don't have to do anything it can stay in my pocket it unlocks it starts does everything I have not tried to clone or make a copy of the remote that's broken since I have one that works. Which will probably start a similar fiasco . Hopefully I'll make it to 666 before I need a new remote or such .
  10. Gourockian
    75
    23
    New Port Richey
    My original OEM one works exactly as what I think you are saying except the Gen 3 does not have the slot to insert the remote when proximity sensing doesn't work. With these, you have to touch the power button with the remote to start. I'm just trying to get the new non-Toyota one to work the same way as the original.
  11. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    I think most locksmiths would tell you they have lots of issues with aftermarket keys. Maybe it's a sale tactic, but I had pretty much the exact same issue with a Mazda aftermarket FOB. I got a OEM one and it worked fine.
  12. Gourockian
    75
    23
    New Port Richey
    Yes, you may be right, although others seem to have had no issues doing it themselves. I'll persevere with it for now and pay closer attention to the Techstream options. I need to wait until my wife gets back home later today.
  13. ASRDogman
    8,067
    4,089
  14. ASRDogman
    8,067
    4,089
    You have to COPY the original one, then PASTE it to the new one(clone).
    From what I understand, you have to wipe it clean so it is as a new never been registered
    one, then copy the one working fob.
    Did you "erase" the one you purchased first, so it is completely blank?
    If not, then do that first. Then you READ your working one, then copy that to the erased one.
  15. Gourockian
    75
    23
    New Port Richey
    I’ve not come across any reference to copying and pasting from one key to another so if you can share any further information on how that is achieved, it would be very helpful.
    My key is new, never used, so why would I need to erase it?
    My understanding is (and I may be totally wrong here) that the new key does not get programmed to the car and I’m not sure how Techstream could do that, as the key is not connected in any way to my laptop. As far as I know, it’s the other way round where the key transmits ID data which then has to be registered in the car’s computer via Techstream, to allow it to work with the car. The nearest analogy that I can think of is where a new garage door remote controller has to be ‘registered’ to work with the garage door opener. The remote doesn’t get programmed.
    At the moment, my new key is recognized in that it can lock and unlock the doors but as Leadfoot J. McCoalroller points out, I need to also register the RFID to allow the proximity sensors to work. So that’s what I’m about to try and do in a few minutes time.
  16. ASRDogman
    8,067
    4,089
    All I can tell you is what I've read. Using Techstream, they COPIED the information from
    the working key into Techstream, then PASTING that information into the NEW key.
    And if they were using an old key, or used key, that key needed to be erased and made unused.
    Perhaps if you search youtube on how to programme a NEW key.
  17. Gourockian
    75
    23
    New Port Richey
    Okay, I'll do some more research on this. Thanks.
    ASRDogman likes this.
  18. Gourockian
    75
    23
    New Port Richey
    Well, I just spent a few hours in panic mode, thinking that I had well and truly bricked the car. I had decided to unregister the new key and start afresh so I used the Techstream Erase function to do that. Previously, it had shown that I had 3 keys registered, presumably, the two originals plus the new one. I held the new one up to the power switch, as directed and in a second, I was down to one registered key instead of two - and it was not my original one as it had stopped working entirely!
    I immediately thought that it must have been the other original that was the 'master key' and as I had never owned that one, I couldn't see how I could re-register any of the two I had without a 'good' key. Not only that but I had turned off the ignition by this time and had no way to get auxilliary power back to raise all four windows, which I had opened because of the heat. At least there was no rain forecast for a few hours.
    As the panic increased it became rather obvious that I would need to reset the codes but that requires a 96-character Seed Number followed by a Passcode. Although the ignition had been turned off, Techstream was still connected and generated the seed number. I found a site which sells a minimum of 5 tokens to allow the Passcode to be generated but after numerous attempts, Techstream showed that the code was incorrect - further panic!
    Without going into even more boring detail, I finally discovered that somehow, the new keyfob was actually the one that was still registered - what a relief! This allowed me to turn on the ignition and re-register my old one which is again fully functional, whereas the new one is still not being recognized by the proximity sensors. I'm not too inclined to mess with it any further so will maybe contact the ebay seller, as it was supposed to be identical to my OEM one.
    I hope this saga will be of some useful help to other Gen 3 owners.
  19. ASRDogman
    8,067
    4,089
    OUCH! Like playing with fire....
    I'm glad you were able to use one key.
    You should search youtube on this matter and watch several videos on how to
    activate a new key.
  20. Gourockian
    75
    23
    New Port Richey
    Yes, I felt like throwing this new key into a fire! Believe me, I have spent hours watching every YT video I could find on activating a new key. It's not difficult to do with Techstream, providing you have the correct replacement key. I just noticed half an hour ago that, despite the ebay seller claiming that his had the same printed circuit board number, it is totally different so I've sent him an email regarding that, asking for a proper replacement this time. Thanks for following along.
