New Rotors at 45k??
Discussion in 'Gen 2 Prius Main Forum' started by AaronA, Mar 13, 2012.
  1. AaronA
    AaronA Junior Member
    55
    Boston
    I brought my car to Toyota to check out another issue and they told me I need new brakes, which I knew. But they told me I need new rotors as well because the rotors are "too corroded to turn" or something like that. Anyone heard of such a thing?
    The rotors have a craze of rust on them which I'm not used to seeing on rotors, and they have some slight grooves, but no major corrosion or wear. (sorry - I can try to post a picture later, but they weren't coming out well).
    I'm used to Volvos where the rotors get replaced every other brake job, so this is a new one on me. I wasn't sure if rotors get replaced more often due to the lack of brake wear.
    Also - can anyone recommend the best place to buy new pads? And rotors too - if I need those.
    Thanks,
    Aaron
  2. richard schumacher
    7,683
    1,064
    United States
    It's very unusual to need new pads at 45K, and new rotors even more so. Did something happen to damage the brakes? Do you drive like a maniac with nothing but panic stops? If not I would get an opinion from another shop; this one may be trying to pad his income.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Before you go replacing those rotors, you might try several hard stops while in Neutral. You're such a careful driver that you just haven't used the friction brakes enough to keep ahead of the rusting.
  4. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    If that were true, it would be hard to understand why the car would need even pads at under 50k miles...
    Something strange in the neighborhood...
  5. fuzzy1
    10,687
    Can OP yank a wheel and check the pad thickness for himself? Or get a 2nd opinion somewhere else?
    Make sure this is not a shop creating unneeded business under disguise of the many other cars needing brake jobs at this age. More than one Prius owner has had 'worn' pads magically return to serviceable thickness on a later visit.
  6. AaronA
    55
    Boston
    I can see that the pads need replacing (that's the nice thing about Prius rims - good sight window!). I just bought the car a month ago, so have no idea how the two owners before me drove.
    I can take off the tire and measure the rotors, but don't have a micrometer. I guess it's time I finally bought one. I always have done it visually. These rotors don't look like they need replacing.
    If the car is in neutral, does it shut off the regenerative braking?
    Thanks!
  7. AaronA
    55
    Boston
    They did try to get me to turn my rear drums to "get the rust off." to the tune of $200! That one I knew was just padding. But this one seemed like it might be a weird Prius thing....
  8. Patrick Wong
    18,210
    6,517
    I suggest that you see whether you can get the rust off the rotors by finding a road without traffic, getting up to 50 mph or so, then shifting to N and braking moderately hard. Repeat a few times. See if that helps to remove the rust.
    If you still see substantial rust then you probably should replace the rotors when you replace the pads. It is unusual for a Prius to require new pads at only 45K miles but since you have visually inspected the pads and found them to be low, who knows what abuse the car had been subjected to.
    Regarding where to purchase new brake parts, I buy from Champion Toyota (Houston) which discounts parts ordered over the web ~25%.
  9. AaronA
    55
    Boston
    I took another look at it this morning after braking in neutral a few times (though not from high speeds). There seems to be a black crazing on the rotors.
    I think what I really need to know is if it's a known prius thing that the rotors corrode faster than normal due to the low brake usage? Or if I can just treat them as regular brakes and turn the rotors if they are thick enough?
    Thanks!
  10. cnschult
    cnschult Active Member
    772
    97
    Michigan
    is there a material alternative to cast iron avail for brake rotors, that will not rust?
    Obviously there's carbon ceramic, but that's too expensive and only found on porsches, ferraris or race cars. Can't these get made in China cheaply? Or is there something else that makes them so expensive?
  11. bisco
    52,758
    aarona, i'm not sure there is anything wrong with your brakes at all. you should try another shop like the car guys in hyde park? or an AAA certified. i wouldn't trust looking thru the 'sight window to determine pad thickness, they should last 100,000 miles. the rotors are as good as anybody's and even tho they develop a bit of light rust, it comes off quickly and should not be a problem. grooving is different and if they are too deep to turn the rotors or if the rotors are warped too much, they may have been mistreated and do need to be replaced. all the best!
  12. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Over tightening wheel installations has been known to cause problems with rotors. Since you see rust it suggests there has not been a lot of mechanical braking recently (who knows about what went on in the past)
    Follow Patrick's suggestion (I would) and if needed get at least one additional reliable opinion on a complete brake job. It might be a little more expensive but a certified Toyota Service Dept might be worth the cost.
  13. AaronA
    55
    Boston
    It was a Toyota dealership that made the recommendation. Looking through the rims at the pads gives a nice idea of how much wear is left. I bought the car knowing that it was going to need front pads soon.
    I'm guessing from the reactions to my post that this is not a common Prius problem. I'll yank the rotors next week and bring them to my local machine shop and see if they can be turned or if I need new ones. I'll also try to get some good pictures when they are off.
    Thanks for all the advice!
    Aaron
  14. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    In areas that use winter salt (and especially cars that sit outdoors overnight) this isn't that unusual. I had to replace the rotors on my daughter's Protege after 22,000 miles. It would sit in an outdoor lot for days at a time without being driven.
    The worst corrosion is typically on the "hidden" side of the rotor, usually covered by the splash shield.
    - Chris
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The front brakes on a Prius typically last 100k miles or more. The rear brakes even longer. Mostly they rust away from lack of use. If yours truly need to be replaced, the previous owner must have worked overtime to abuse them.
    Tom
  16. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Check Ebay for disc (rotor) prices. I just changed mine front and rear on a UK gen2 due to heavy rust paid £30 for pair of fronts £17 for pair of rears. Both sets made by well known UK manufacturer total £57/$90.
    Toyota wanted £400 just to supply.
  17. usnavystgc
    3,159
    990
    Tucson, AZ
    AaronA,
    I know you've gotten a lot of replies but I just wanted to cut to the chase and answer your question
    No: This is not common to the Prius. I'm not sure why your pads need replacing because that is very uncommon to the Prius. As for the rotors, I could possibly chalk it up to road salt or if your car was left to sit for a while with salt on the rotors (might cause deep pitting).
    The reason your seeing these replies is because it is so unusual.
  18. cnschult
    772
    97
    Michigan
    since there are different grades of rotors and pads, is it worth it to buy higher grade brake parts on a prius if they are just going to just rust away?
    and you can't buy premium pads to last 150K miles and change cheap rotors every 75K miles, can you? because the pads after 75K miles will be deformed to match the old rotors, so throwing new rotors on will make the old pads not have good contact with the new rotors and thus creates a serious safety issue.
    obviously with pads the different grades typically indicates how quiet they'll be in operation, not longevity, so I would just buy the cheapest pads that don't result in any "brake barking". As for rotors, yeah you could buy thick heavy rotors that will resist "rusting thru", but the extra weight would hurt your FE, so IMO it would be better to use cheap rotors and just replace them as needed.
    I'll wait for the "expert" opinion from Patrick or someone else very knowledgeable. and nobody has answered my previous question about why carbon ceramic is so expensive, because that material won't rust and is super light and would solve all our problems
  19. Cory151
    Cory151 Member
    102
    27
    Las Vegas
    Why does it matter "why" carbon ceramic is more expensive? Is that going to change your cost? No, they cost more because they are much harder to produce.
    Lastly, I just did my brakes last night and it took about 1 hour, I used the Bentley Prius manual as a guide and Im glad I did. I highly recommend getting new pins as well as all new backing hardware (anti squeal plates etc) from Toyota.
    Why? because the shop that did these brakes (before i owned the car) ordered parts from Autozone/Advance and they either didn't come with or the mechanic neglected to install the 4 (thats right I said 4!) anti squeal plates making my brakes extremely noisy. Torque you lugs in a star pattern to 76ft-lbs.
    Unless your a woman, (no offense if you are) I highly suggest you save yourself the $300 in labour and just do the brakes yourself, it is extremely easy and its one of the first things my father taught me how to do when I was 15. Dont overcomplicate things, to me and you the brakes on this care are the exact same disc and drum setup on my 1986
    Mustang. Who knows you might even learn something????
    KK6PD and usnavystgc like this.
  20. Britprius
    5,194
    1,922
    The brakes on the Prius are not difficult to change but if you do them like the Mustang or most any other car I guaranty you will through brake fault codes, or worse pop the pistons out of the calipers, more than one person on hear has done just that. Then you cannot bleed them in the normal way ether, so a little research before you start would not be a bad idea.
