New Scan Gauge II
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Drdiesel, Aug 1, 2013.
  1. Drdiesel
    Drdiesel Active Member
    585
    153
    Monterey CA
    I was reading the manual and thought I would ask the Scan Gauge users on PC what their
    Fuel Cut setting is ? The book says 4 above the TPS at closed throttle. My closed throttle
    TPS is 17. I set the Fuel Cut @ 21
    I was just curious what your TPS is and what you've set your Fuel Cut at. Thanks :cool:
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    On my 2010 Liftback my TPS at closed throttle is 15 and I have the Fuel Cutoff at 19. No problems.
  3. Drdiesel
    585
    153
    Monterey CA
    Thanks! :cool:
  4. garm
    garm mpg + cool = win
    215
    TPS 17 have not set fuel cut. Explain the purpose.
  5. jdcollins5
    5,131
    1,346
    Wilmington, NC
    My guess is to let the SGII know that you are off of the throttle in case the fuel usage does not go all the way to zero.
  6. garm
    215
    You mean, some kind of control over DFCO? Interesting.
  7. jdcollins5
    5,131
    1,346
    Wilmington, NC
    What is DFCO?
  8. garm
    215
    DFCO = Deceleration Fuel Cut Off (where the car uses zero fuel on deceleration)
  9. jdcollins5
    5,131
    1,346
    Wilmington, NC
    OK. I am not sure how the SGII calculates miles or mpg. I have asked and they say it is proprietary !
  10. Drdiesel
    585
    153
    Monterey CA
    Yes (y)
    garm likes this.
  11. mdgates
    mdgates Junior Member
    67
    23
    Buffalo, NY
    The Fuel Cut setting is only used for the ScanGauge's instantaneous and average MPG readouts, which I don't use. Average MPG is already provided by the Toyota display, where it is a measured value as opposed to the ScanGauge's estimated value. Instantaneous MPG is not a metric that tells you how much energy you're using, as it neglects energy stored in the battery, kinetic energy, and gravitational potential. It doesn't tell you how efficiently you're using the energy you have, either. What might be useful is "grams of fuel burned since last stop light", so you could try different techniques for each segment of your trip. Sadly, there's no such XGauge.
  12. mdgates
    67
    23
    Buffalo, NY
    We have the best kind of DFCO: the engine comes to a stop, too.
    The ScanGauge is a read-only device. It can affect the behavior of the driver, but not of the car. It doesn't give you control over any engine settings.
