New ScanGauge codes for 2016 and up Prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Fester, Jun 1, 2019.
  1. Fester
    Fester Active Member
    201
    198
    Ohio
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Is there any way to convert these for use in Torque (Android)?
  3. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    Very useful thanks.
    Is there anyone who can assist the the maths (MTH) to convert the Fuel level ScanGauge from Gallons to Litres please?
  4. TR738
    TR738 Junior Member
    Ithaca, NY
    Has anyone successfully used Hybrid Battery Current HBC from the list on the Scangauge website?
    This is for a 2016 Prius Two, NiMh battery.
    I tried this from the list and got odd numbers -
    TXD: 07D2227A53
    RXF: C32180000000
    RXD: 2010
    MTH: 000100010000
    Tech support suggested this one, and also trying RXD: 3808, but no luck.
    TXD: 07D2227A53
    RXF: C562067A3753
    RXD: 3008
    MTH: 000100010000
    I also tried this one from a different thread "ScanGauge II – Prius Gen 4 XGauges – Observations on Hybrid Battery Current"
    TXD: 07DF0153
    RXF: 432180000000
    RXD: 1810
    MTH: 000100018000
    I've got the latest firmware update, and most other codes are working well. Any other choices out there for battery current?
    Also, has anyone used the A/C power consumption gauge? It always reads zero on my car -
    Thanks -
    Tom
  5. Fester
    201
    198
    Ohio
    Main battery current is working OK for my 2017 Prius 2, the AC Power, like yours reads 0.
  6. TR738
    TR738 Junior Member
    Ithaca, NY
    Thanks for the confirmation on your 2017.
    I wonder if the 2016 varies in subtle ways. Does anyone else have 2016 X-Gauge experience to report?
  7. TR738
    TR738 Junior Member
    Ithaca, NY
    I had some correspondence with Scangauge folks but no joy. After experimenting with various combinations listed on their X-Gauge page for Toyota hybrids I settled on this one for hybrid battery current HBC:
    TXD 07D2227A53
    RXF C32180000000
    RXD 2010
    MTH 000100018000
    It might be giving credible values, or might not. HBC does switch sign between charging (-) and discharge (+). The observed change in SOC seems to approximate what would be expected for a fairly constant charging current sustained on an extended downhill regen. But I'm surprised at the high (but brief) C-rates for a 6.5Ah NiMH battery.
