NEW!!! Service Bulletin for Engine Knocking at Startup T-SB 0012-10
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by seilerts, Jan 12, 2012.
  1. Mendel Leisk
    41,442
    Did they change the EGR valve only, or both the valve and cooler?
    It's good that they've cleaned the intake manifold, hopefully thoroughly: it really is part of the EGR circuit.
    Also, how many miles on the car?
  2. Abdi85
    Abdi85 New Member
    Northampton
    2012 Prius+ MPV
    Hi they change both and my car miles 191000 and also the change spare plugs today and still have the knock. Thanks
  3. cmderks93
    cmderks93 Junior Member
    Midwolda, Netherlands
    How cold is it now in your area? In my case, there is no knocking anymore when it's warmer outside. ( warmer than 10c or 50f)
  4. Mendel Leisk
    41,442
    Is engine coolant level in the reservoir stable, not always dropping? If everything else is addressed, could be overheating from chronic EGR neglect, and just age/miles, has tipped the the head gasket to failing.
    Still, as long as it's the dealership that's doing all the EGR and intake manifold work, I'm really sceptical. I'd want to open it up and see for myself before dismissing problems in those areas. I don't trust them to do it right, in particular because it's so labour intensive.
    #1044 Mendel Leisk, Apr 5, 2019
    Tande and Raytheeagle like this.
  5. icewater
    icewater Junior Member
    I noticed this one morning this past winter! I had no idea what it was and was highly worried my engine was damaged.
    Is this still something that the dealership will repair (on a 2011 Prius with 120K mi)?
  6. Mendel Leisk
    41,442
    Easier, and likely way more effective, to read up on the system, DIY.
  7. Tcortez
    Tcortez Junior Member
    25
    42
    Lancaster
    Did you ever find the problem with your car? I have the same symptoms.
  8. cmderks93
    Anyone had changed the intake manifold to the new designed one? With partnummer ending on 54?
  9. JC91006
    16,768
    8,565
    I just got this notorious knock on my 2010. It seems after the knock, the coolant level in the reservoir had slightly increased. Not sure what that means.
    It's at the dealer now getting the warranty enhancement for the sticking egr valve. But I'm sure that won't solve the problem
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Time for a circuit cleanse (y).
    JC91006 likes this.
  11. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I will be in your area next week. We can do the head gasket.
    JC91006 and Raytheeagle like this.
  12. JC91006
    16,768
    8,565
    I don't think it's the head gasket yet. I don't drive this car enough for it to go bad. It seems to have a slight knock when it sits for a few days. It just developed that big knock a few days ago.
    I've checked the entire egr/intake circuit a few months ago, it's not the issue.
    I've also moved house last month, but I'm very close to my old house, now I'm JC91007
    Mendel Leisk and Raytheeagle like this.
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Hopefully you have the same or greater space available for your Prius “collection”:).
    I left our 2010 for 10 days last year at the Oakland airport and when I returned, it was the loudest, most violent knock I’ve had:eek:.
    That was with an oil catch can installed:cool:.
    Just keep an eye on the coolant level(y).
    JC91006 likes this.
  14. JC91006
    16,768
    8,565
    Yeah that's the violent knock I got. I have it at longo Toyota right now, hopefully they can figure out the knock. I know my egr circuit is clean, just the valve is the unknown. And there is a warranty enhancement to get that replaced
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Did you actuate and clean the valve when you did the intake manifold and cooler cleanse?
    JC91006 likes this.
  16. JC91006
    16,768
    8,565
    I didn't clean the valve as there was nothing visibly wrong with it. It seemed to have functioned properly as well.
    But since Toyota says the valve is an issue with the warranty enhancement, it might be the problem. Which makes sense the car only knocks after sitting for a while (valve has a chance to stick)
    Raytheeagle and Mendel Leisk like this.
  17. Tcortez
    25
    42
    Lancaster
    B02D46BE-8341-4076-A6AC-86B3F1FA3152.jpeg 3604E945-71DB-45C7-A73F-FD4371784D1C.jpeg 922EF2C5-960F-4189-9BDE-BA3953D23C0A.jpeg I bought a cheap boroscope that hooks up to the iPhone and found my startup knocking system in cylinder 2 , I have 220000 miles , I poured k seal in yesterday and this morning it started up as normal. I know this is a bandaid fix , the k seal stuff is a real small bottle, probably like 8 ounces. I got it at Autozone, I’m just glad I looked in the cylinder and did not start buying all kind of new parts at this Lemmon. The car still drives great when warmed up. The other 3 cylinders looked good.
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    If you have an impact screwdriver you can remove the 2 machine screws and push on the plunger and get it to go;).
    The carbon deposits get everywhere, and the valve seat isn’t exempt :cool:.
    JC91006 likes this.
  19. Tcortez
    25
    42
    Lancaster
    Check each cylinder with a boroscope in the morning or when it sits for a few days , see if it’s oil or coolant.
    JC91006 likes this.
  20. JC91006
    16,768
    8,565
    I think Toyota will give me a new valve
