New SGII- What settings do you use?
Discussion in 'Gen 2 Prius Fuel Economy' started by Sheepdog, May 14, 2008.
  1. PaulHS
    PaulHS Member
    200
    SE PA
    The scangauge - OBDII interface is rather delicate. Unplugging or reconnecting (with power off) alone can throw error codes and the !Triangle! You may want to experiment first with one scangauge to see how well it behaves with your car.
    Paul
  2. Rotorhead
    Rotorhead New Member
    79
    Kalamazoo, MI
    I attended the ScanGauge talk at Priusfest and one of the things mentioned was that numerous ScanGauges could be connected together.
    Mike
  3. Rotorhead
    79
    Kalamazoo, MI
    Did I say PRIUSFEST!!? Should be Hybridfest. So many Prii attended that it seemed like Priusfest. Sorry.
    Mike
  4. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    Good news!
    Any details about how to connect them? OBD2 splitter or RJ45 splitter? Daisy-chained -- Scangauge has 2 ports: Can you use one for input and one for output?
    I'm thirsty for more info on this topic as I don't want to damage my Prius circuitry, or the Scangauge.
  5. Rotorhead
    79
    Kalamazoo, MI
    I think daisy chained is the plan. Think I'll open a bottle of wine, pour my wife a large glass and tell how much we need a second ScanGauge.
    Mike
  6. dogfriend
    7,512
    1,191
    Carmichael, CA
    I know that at least one other PriusChat member is using multiple ScanGauges. I am pretty sure that he has them daisy chained together. It is an RJ-45 connector. I have considered buying a second SG2, but haven't done it yet. I would also like to monitor SOC and battery current, but I find the 4 gauges that I use (RPM, WT, IGN, GPH) so valueable that I don't want to lose any of them for another gauge.
  7. carz89
    444
    47
    San Diego
    There's a post at TDIClub Forums - Powered by vBulletin that says "according to Rod at Scangauge (I think he's the R & D guy there.) He knows of several Prius drivers who run two scangauges for a total of 8 displayed gauges".
  8. mnky357us
    mnky357us bweverka
    42
    Cornelius, Oregon
    I have a question about the sgii here it is....
    My brother bought one for his Prius and it
    seems to shut off while the car is running
    is there a setting for that or does he have
    to send it back? Mine does not do that
    and I do not remember any setting for that.
  9. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Yes, there's a setting for 'hybrid' somewhere you have to set, otherwise the SG thinks the car is shut off every time the ICE shuts down. I forget where it is, and my SG manual is out in my car and I'm not...
  10. kayak_hauler
    kayak_hauler New Member
    48
    San Diego
    Setup - Fuel - Type - Hybrid
    I am also still looking for codes for the MG1, MG2 and inverter temps. To Jimbo, no this wouldn't really help w/ fuel econ., but I'd be interested in monitoring them. Id also like to see MG1-2 RPMs since I often neutral glide....
  11. Flying White Dutchman
    4,376
    313
    @kayak
    if i m correct the MG1 and MG1 and inverter temp are not present on the canbus bby themselfs
    the SG needs to be apple to send a message on the canbus to ask for the info and then capture the response.
  12. ias513
    ias513 New Member
    Hershey, Pennsylvania
    2001 Prius
    I just got a SGII and I understand how to use the XGauge function. (I think)
    I want to monitor SOC and other battery functions, but I get no battery % to readout.
    Other XGauge functions seemed to worked like horsepower for example.
    Does SOC work on a 2001 Prius?
    Any ideas?
    Thanks everyone...
  13. jps000
    jps000 No Exit
    109
    Connecticut
    I did a fair amount of reading on this and settled on IGN, TPS, RPM, and MPG when I first got my Scangauge. I think these have made sense. To me, there is some redundancy and it's a matter of what readout is easiest for you. Posts describe an ideal 14IGN/18TPS for <53 mph and 15IGN/19TPS for >53mph (this is for SHM--super highway mode). I pulse with IGN 18 and then settle on 14 or 15 and let it bleed (go down in MPH while maintaining IGN 14-15). RPM and IGN (and TPS) are also related and so you may prefer to watch RPM. I find it easier to use IGN and TPS (the key is really the IGN, and the TPS just helps with the visual focus for me--seeing that 14/18 combo on the Scangauge). Very low RPM in steady state (1200-1400), which generally corresponds to IGN 14, results in excellent MPG (the Prius is NOT inefficient at RPMs less than 1400 contrary to what some posts have said). The MPG setting is nice because it goes up to 9999 and so you can see nuances above 99.9 of the Prius readout.
    I don't agree with the post about GPH. Maybe it's me, but I can't use that readout in any useful way.
  14. jps000
    jps000 No Exit
    109
    Connecticut
    I should add for the newbies out there (I am one), it seems that GPS (gas pedal position) is also useful for SHM. GPS has to be programmed in as an xguage function. For this and other additional gauges see Dan's fine work:
    The SGII Xgauge Database - CleanMPG Forums
  15. jimsoh
    jimsoh New Member
    30
    west central Ohio
    Am I the only one that finds horsepower helpful? Seems like it's a good indicator of instantanious fuel consumption.
  16. jps000
    jps000 No Exit
    109
    Connecticut
