New shoes - crap mileage!
Discussion in 'Gen 4 Prius Fuel Economy' started by Zipy, Jun 7, 2022.
  1. Bob Welcher
    Bob Welcher Junior Member
    Columbus Ohio
  2. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    @Zipy I could be way off, could the mileage hit have anything to do with the time of year? I think if you ask anyone that lives in the northern half of the US is also seeing a mileage hit even without new tires.
  3. sylvaing
    sylvaing Senior Member
    1,221
    517
    I switched to Michelin X-Ice and with the lower temperature, my Prime EV range went from 42 km this summer to 32 km now :(
    vvillovv likes this.
  4. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Unfortunately it will get worse when you hit the peak of winter:(.......cheer up in spring ;)
    sylvaing likes this.
  5. vvillovv
    4,337
    1,519
    NY
    I have Nordman 7 s inflated to 40 lbs. I run the engine for heat more this year than previous years and so far my electric range hasn't dropped as much as it usually does when the weather gets colder. I still use electric, but I save it for times when I wouldn't take such a hit on EV range, letting the hybrid system do it thing the way Toyota designed the Prius to do.
    Louis19 likes this.
  6. Louis19
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Indeed , you truely understand the difference between a BEV and a PHEV , hauling an ICE and trying not to use it , is counterproductive in some conditions
    #26 Louis19, Nov 28, 2023
  7. sylvaing
    1,221
    517
    When I know I'll need the ICE, I'll turn it on before my drive (ie, use Defrost) so it's already warm and ready to go when I need it later on in the drive. Having a -5C cold engine starting to spin on the highway isn't the best the best way to wake it up!
    Louis19 likes this.
  8. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    Because cold weather has a bigger impact on mpg than tires.....
