NEW strange brake noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by molain, Nov 6, 2004.
  1. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    How do you know it is the same issue? Have you had the codes read?
    Get the codes read and then start a thread in a relevant Prius c forum.
  2. ChapmanF
    19,020
    Well, if it's the clown-horn honk, it doesn't necessarily come with codes.
    But the c forum would be a better place to follow up. Maybe also check existing threads in the Gen 3 (liftback) forum. For Gen 3 liftback, there was a firmware update released that reduces the honk. (I had the update installed, and it worked.)
    I don't know if there is a similar update for the c. If there isn't, or if the firmware is already the fixed version, the next thing I would try would be the "long form" bleed procedure, the one meant for after the actuator has been replaced.
