New Tank Record! 3536 miles 314MPG in a Prius II PHEV
Discussion in 'Gen 2 Prius Fuel Economy' started by TheForce, Jul 12, 2010.
  1. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Once again Hybridfest has forced me to fill up early. But not by much this time.
    Today I have set a new distance record on my 2006 Prius Plug In. 3536.4 miles and 313.51MPG. This tank started out on February 6th and ended today July 12th. I had about 5% fuel remaining according the the CAN-View. At the rate I was going I could have driven about another 50-100 miles. This tank was about 99% my commute to work and back.
    Here are some stats.
    Distance: 3536.4
    Calculated MPG: 313.51
    MPG Equivalent: 115.43MPGe
    Gallons gas used: 11.280 @ $2.779
    Watt hours used: 650379.9 @ 8 cents per kWh
    Watt hours per mile: 183.91
    Total tank cost: $83.38
    Cents per mile: 2.4
    Here are some pictures.
    Miles
    MFD
    Sorry no CAN-View or Scan Gauge pictures because at these high numbers the CV and SG are so far off on accuracy it not even worth mentioning.
    According to the Scan Gauge my daily trips resulted in about 500-600MPG. I feel that a 4000 mile tank is doable. A 5000 mile tank is possible and 6000 mile tank it just with in reach but would take a lot of work. The only way I would be able to reach anything above 4000 miles a tank is to not go on any long trips between March and November.
    DIGG IT!! http://digg.com/autos/314MPG_3536_miles_one_a_tank_of_gas_in_a_Prius_II_PHEV
    10 people like this.
  2. drees
    drees Senior Member
    1,782
    247
    Nice - you've got a Hymotion installed if I remember correctly, no?
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    That is correct, at least to my recollection.
  4. Codyroo
    1,826
    515
    Pleasanton, Ca
    Did you have to put gas extender in with your fuel?
  5. savrip
    savrip Junior Member
    56
    Louisville, KY
    I
    Congratulations, that's quite an achievement. I look forward to seeing some more high numbers. I'm happy just traveling an 800 mile round trip this weekend and only needing to use a tank and a half.
  6. nahtanoj
    nahtanoj New Member
    36
    san diego
    is it bad for me to hope my 2010's batteries go bad so i have an excuse to upgrade to a plug in system?
  7. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    He's totally going to kick my butt at the MPG Challenge.
  8. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    You sure do not drive much:eek:
  9. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Crikey that is excellent! I assume your commute is done in forced EV below 52mph?
  10. JeffreyDV
    JeffreyDV New Member
    81
    New Milford, NJ
  11. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Yes
    No. I was running straight winter gas.
    YES! YES I WILL! HAHAHAHA :evil: Unless you want to trade. I would not mind driving an official plug in Prius for 30-40 miles. One thing your going to have to figure out is how to keep it charged as you make it to the starting gate. You should ask if you can get a 4kWh Enginer kit temporally installed. :D
    Mostly forced EV with the EV button until I reach the highway. Then its about 3 miles with the engine on then back to EV.
  12. hill
    8,189
    Makin' my measly 725 mile tank look pathetic . . . one gallon at a time.
    I am not worthy!
    :hail:
  13. TonyPSchaefer
    14,816
    2,498
    66
    I just signed this just this morning.
  14. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Well that sucks. You cant even add an Enginer pack. :(
  15. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    Congratulations! I love to read these success stories so I hope you keep 'em coming.
    I had no idea that the electricity needed to recharge the Hymotion battery was so inexpensive. We don't drive long distances except to commute between our summer (CO) and winter (AZ) homes, so a plug-in would work well for our purposes.
    Hmmm . . . I wonder if that Tom Hanks Prius is still available. Wish it was Superwhite.
