New tires at 105 k mpg is way down from 52 to 46 and the drive is off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jendbbay, Jul 25, 2013.
  1. jendbbay
    jendbbay Member
    223
    You are correct! They do not have a kit. The mechanic told me that he always does it the old fashioned way and he isn't confident that the people who have only worked on the special alignment machines actually know what they are doing. He said he would be able to use such a machine, but that they cost 80 grand. I am astounded that they cost that much. He uses the same paper that they generate, but he enters the results he gets via his manual method onto the form online. Its supposed to be in my email right now, I guess. They do not generate any paper at the shop at all. If one needs paper, one has to print the receipts after they send them to you -- I love that about them. I will be printing this receipt so I can get Firestone to pay for the alignment.
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Yes, the Hunter racks do cost in the neighborhood of $80k, which is why they are often found in the big-name franchise shops -- they are the only ones who can afford them. Unfortunately, these big name places are often the same ones who employ the least competent individuals to do the alignments. Due to the sophistication of the Hunter software, it can be operated by the most novice technician...which is an issue since these same people do not understand the most basic alignment concepts (all they do is follow the screen prompts).
    What did Luscious Garage charge for the alignment?
    iPhone ?
  3. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    I have a local shop that I work with. I do a lot of diagnostic and programing work for them.
    They're really good for the tire and alignment service and have the proper equipment with tech training.
    I know the owner and all the techs. It would save you a lot of time instead of driving to SF.
    I know the job would be done properly too. I refer a lot of my own customers to them for tire,
    alignment and maintenance service. If you would like to talk with me about it, drop me a PM.
    jendbbay likes this.
  4. jendbbay
    jendbbay Member
    223
    how do I pm you again? Are you kidding me? Am I interested? Please let me know ASAP!!!!!
  5. Drdiesel
    585
    152
    Monterey CA
  6. The Critic
    3,193
    2,333
    CA
    Sure, please send me a PM. Your profile won't let me PM you.
    iPhone ?
  7. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    This is also an interesting point. I've read that tire pressure gauges are notoriously inaccurate, especially the mechanical ones where the measurement indicator slides out to show the pressure amount. I doubt whoever checked the tire pressure at the Firestone place intentionally put too much and then too little air in. It may have been two different guys with different gauges, both wrong. A good digital gauge kept in the glove box I have found to be helpful.
    So, I know you were very pleased with the MPG going home, how about the handling; did you notice any difference? And does your husband, since he is most familiar with the handling characteristics of the car?
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Which is code for: he still works there, but isn't man enough to come out front and talk to you about his stuff ups.
    Great result. (y) You'll have to let us know if your husband finds the handling is improved after he has had a chance to drive it.
  9. jendbbay
    jendbbay Member
    223
    My husband said its no better. Hah! I'm ignoring him now. 180 miles 80 dollars for the alignment, 30 dollars for the inspection to find out whether we would align it, 10mpg better mileage, I'm done. I can't print the receipt to go get my money back from the tire store, because my printer has run out of ink, but details, details, more consuming details.
  10. jendbbay
    jendbbay Member
    223
  11. jendbbay
    jendbbay Member
    223
    Yes, husband does not like the handling, still. I'm ignoring him. I am an MPG addict. That's why we got the car in the first place, but it makes no sense for me to use it when he drives 80 miles a day.
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes, there was a huge clue right back in your first post when you said: " they showed me that there was a tear between the bottom and the side, which they claimed had occurred because I had failed to get routine alignments." What they told you there was complete nonsense. There is no way that the lack of wheel alignments caused a sidewall tear. More likely this was just related to whatever incident gave you the flat.
    What DrDiesel said above, these guys where just taking your money and giving you lip service.
