New Tires Lowered MPG UNTIL...
Discussion in 'Gen 4 Prius Fuel Economy' started by Flo Samuels, May 1, 2019.
Tags:
  1. Flo Samuels
    Flo Samuels Junior Member
    9308 Pebble Beach Drive, Santee CA
    My son drives a 2017 Prius. I drive a 2007. For both cars the mpg were 46.something until we got new tires. My son's mpg dropped to 37, mine dropped to 41. Both the new tires were from Discount not the brands that were on the cars.
    Now here is the kicker. My son took his into the dealership, they had it a week and no fix. He said in a survey he would never recommend the dealership to anyone. In fact he would ensure no one went to it for a Toyota. So the service manager drove the car, they had it for a day and suddenly the mpg were back to 46.something.
    My question is pretty simple. What could they have done to my son's car to fix the gas mileage issue? It obviously has to do with the new tires. And is something I want done to mine.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    New tyres need running in - but only 500kms I think.
    Do you keep accurate records of your fuel use - or just the dashboard display which is only a calculation from a number of sensors, and sometimes errs considerably?
  3. krmcg
    2,592
    2,393
    Whittier, CA
    The type of tires is most important. Low rolling resistant tires will help get better mileage - sticky or winter tires will hurt. Run-flat tires are especially bad delivering economic good news...
    alanclarkeau likes this.
  4. alanclarkeau
    7,045
    7,593
    I didn't realise that run-flats were worse - I've seen them on cars which I wasn't really considering. But it stands to reason, they're usually on prestige or sporty cars.
    knockknock_2 likes this.
  5. krmcg
    2,592
    2,393
    Whittier, CA
    Especially heavy.
  6. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Tyres can and do affect fuel use.
    But, if the dealer is using the same tyres at the same pressure, and gets different MPG than you, then it's likely down to one of the numerous factors that could on their own, or combined, easily make the difference you're seeing.
    These include driving style, the music you're playing, your mood, wind direction, wind speed, temperature, humidity, wet or dry roads, traffic conditions, battery level at the start and end of the journey, and of course tyre pressure and types. Most of these are really hard to control for.
  7. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
    Did you check the tire pressure before and after the service visit? (When I purchased my 15 Prius, I was getting low-40s mpg while my 11 Prius regularly got low-50s.) Couldn't figure out why the new car had such poor mileage. Then I checked the tire pressure and the pressure on the new car was around 30 psi. Brought those up to 40/38 and mileage was up to high-40s/low 50s.)
    IamPrius, kithmo and krmcg like this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    My answer is pretty simple:
    Maybe you should ASK THEM instead of speculation and guessing in a place like this.
    Then......what appears to be the obvious conclusion is sometimes dead wrong.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    As said above, probably the dealer upped the pressures (and then did a few doughnuts around the car park to bed the tyres in :whistle:).
  10. a_gray_prius
    2,927
    783
    IL
    Did they do an alignment? Do you know what the alignment values are on your car?
  11. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Tires are the most important item for MPG. Live and learn like I did. LRR, weight of tire, brand, where it is made, and PSI all have a large impact on MPG.
    Recently I have discovered Pirelli LRRs do a great job for replacement tires from Sams club. Your mozzarella may vary.
    To be totally safe, buy your tires online and get the OEM MIJ and pay someone to install them. Walmart will work as they normally carry those online for most cars. Tire rack for you exact tire to look for in your research.
    Be careful, as where a tire is made maters.
    Also the rears do not affect MPG like the front do. In a pinch, Put your new tires on the back and keep the OEMs on the front as long as you can.
    42 is the ultimate answer to everything. 32 is the wrong answer. 44 is for the brave and 50 is for certified insane people.
    Next is Earl!!!! Make sure you use 0W20 full synthetic earl as any thing else will drop your MPG big time.
    #11 ETP, Jun 20, 2019
    Spooled and alanclarkeau like this.
  12. alanclarkeau
    7,045
    7,593
    Good with the tyres, but with oil, best to stick with TOYOTA's specification for your country, particularly if it's under warranty - this is Australia - it differs around the globe:
    ETP likes this.
  13. ETP
    2,804
    1,170
    Auburdale FL
    Good to see you alive. Wish I had an old car like me to drive around.
  14. alanclarkeau
    7,045
    7,593
    Yep - think I'm alive, was last time I checked in the mirror. You?
    I noticed your Benz - bet that chews through the petrol!!!!
    My Avatar is much more modern - my Dad's first car - which he bought from my Grandfather, a '49 Austin A40 Devon - mid green. This colour, but this isn't the car.
    ETP likes this.
  15. ETP
    2,804
    1,170
    Auburdale FL
    Those cars from the 30s and 40s had class. With seat belts, safety glass, and airbags they would be a classy ride. Usually you can retro fit most with those items. Collapsible steering wheel would be more difficult.
    BTW did you see EndGame? Harry James music at the end was priceless. Had a joint replacement at VA in my foot two months ago. I seem to have survived the experience.
  16. alanclarkeau
    7,045
    7,593
    No - didn't see it (haven't seen a movie for years) - but found it I think - nice:
    Though - I can't picture your Benz with seat belts, safety glass and airbags :rolleyes::rolleyes:
    ETP likes this.
  17. ETP
    2,804
    1,170
    Auburdale FL
    Music from WWII was perfect as the world struggled to survive.
    Bought the album on Amazon.
    New James/
  18. Flo Samuels
    Well if he had changed any of the above after he got the new tires, you would be correct. But he didn't. There is something going on with Prius that the dealers know but won't tell the buyers.
  19. Flo Samuels
    If they had told him what they did I wouldn't be on the forum. Note they had the car fora week with no results and it was only when my son said he would start posting bad reviews that the Service Manager took the car for a spin and miraculously the mpg went back to normal. The Service Manager said they did nothing to the car but it is pretty obvious that he knows what the issue is and DID do something to the car.
    Now I have the same problem with my 2007 Prius. Old tires, Cooper, 46.9 mpg. New tires Discount Tire, 41.8. Complained to Discount, they replaced the tires WITH THE EXACT BRAND AND SIZE COOPERS THAT WERE ON IT BEFORE. MPG is now 38.6.
    Costco replaced my son's tires with Michelin, no problem with the mpg going down. IMO there is a design issue that requires some kind of adjustment when new tires are installed and Toyota is keeping it quiet to promote more repair revenue. Costco evidently has figured this out.
  20. krmcg
    2,592
    2,393
    Whittier, CA
    New tires take a mileage hit. There have been so many threads about this that it is simply a proven point. But then again, some more than others. If there is any air pressure difference in the old tires and the new tires adds to or reduce the delta.
    I don't believe that there could be any "adjustment" that either the dealership or Costco could do other than pumping up the air pressure to increase gas mileage. Perhaps tracking mileage over a longer period of time and looking for trends could help. But weather, terrain, and speed play roles and that cannot be easily captured.
