New to forum
Discussion in 'Gen 4 Prius Main Forum' started by bugsy57, Feb 23, 2019.
  1. bugsy57
    bugsy57 New Member
    Four Touring
    I’m going to make this as short as possible, I drive a Toyota Camry 2017 and I’m looking at trading it for a 2016 Prius four touring, my question is should I or not I know the maintenance on the camrys are very good but I only get 27-30 mpg and I drive around 90-120 miles a day so would it be worth it to go to a hybrid. I know the gas savings would be better but I’m not sure on the batteries and all the technology with the hybrids. But from what I have read and found on this fourm there are all kinds of problems with the hybrids from little rattles to stuff just breaking down r whearimg out so in the long run will the Prius last 300 or 400k like my Camry should or would the maintanence be more with the Prius.
    #1 bugsy57, Feb 23, 2019
    52,801
    Welcome!
    There is no way to know how one individual car will hold up.
    Overall, I suspect Prius is similar to Camry reliability, but if something does break out of warranty, there are several items that are much more expensive ona Prius to repair.
    Also, anyone can repair a camry, but hybrid techs are few and expensive.
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    The only thing that worries almost everybody who owns a Prius is the traction battery. Typically it lasts the 150k miles that it is warrantied for. Some have found that the battery lasts much longer, some have experienced it dying just after that mark. YMMV.
  4. bugsy57
    bugsy57 New Member
    Four Touring
    Thank you
    Thank you
    #4 bugsy57, Feb 23, 2019
  5. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    Well from my experience my last Prius was beyond amazing. Having several other high mile Prius in the family with similar results- I see no reason you would be disappointed. One other option is getting a 2018 Camry Hybrid. The new version is rated at over 50 mpg too. My sister has one and is getting the rated economy and very close to Prius territory. Either way Toyota Hybrids are amazing and super reliable. If you look at Consumer Reports Reliability records the Toyotas and especially their hybrids have exemplary records.
  6. bugsy57
    bugsy57 New Member
    Four Touring
    Cool thank you
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Really, I suspect that 99% of PRIUS on PriusChat are absolutely loving their cars, and they've been ultra reliable. Any car will have the odd little problem. There are PRIUS out there which have lasted a million kilometers, almost all batteries last well beyond the warranty.
    Gen 4, in 2016 was brand new, a totally new platform for TOYOTA (which now is in quite a few cars) - they always suggest don't buy the first of any model, but they've been great.
    But, the reality is - people who are ecstatic with their cars - will often say nothing - but those who have a problem will talk about it. It's human nature - we want to fix problems.
    Mine had a brake-light switch fail - I think I'm the only one on PriusChat. And 2 recalls which 1) affected the park-brake on early cars and 2) the wiring harness on early cars.
    There are some things to check - I don't think the seats are the most comfortable I've had - check they suit you. The foot-parkbrake is a dumb idea. If you lived in a hilly area, the hill-holder only works facing up a hill forwards - so if you're parked facing downhill and someone parks close in front and you have to reverse back, it's not the easiest.
    Oh - and fuel economy is great.
    #7 alanclarkeau, Feb 23, 2019
    Elektroingenieur and krmcg like this.
  8. Tideland Prius
    16,674
    Prius and Camry Hybrids are used as taxis so mileage/distance doesn’t seem to be an issue. All the Gen 2 Prius cabs are gone now (there might be a few left but they’ve mostly all been replaced with Prius v’s). That doesn’t mean they were unreliable as many have done 600,000-900,000km during their life. (5-7 years). I’ve seen a few Gen 3s and 2 PiPs.
    Anyway, the statistics show that it’s generally reliable. Some of those cabs have had their Hv battery replaced but that was at anywhere between 500,000 and 750,000km. That’s a drop in the bucket compared to all the tires and brake pads that they save. As well as maintenance and gas compared to the previous taxi standard, the Crown Vic.
    alanclarkeau likes this.
  9. alanclarkeau
    7,045
    7,593
    And bear in mind - the petrol motor only runs about 75-80% of the time, and is un-stressed. There is no gearbox - but a clever, but simple epicyclic transaxle - which will be far more reliable than the new CVTs and Twin Clutch - or 8 speed Autos which are inordinately complex. Brakes are likely to last the life of the car.
    Should it ever need a battery - they're cheap relatively - cheaper than fixing an auto gearbox or several full brake jobs - and the saving on fuel will have been far more than the cost of the battery.
  10. bugsy57
    bugsy57 New Member
    Four Touring
    Very good thanks for the information
  11. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Did you trade out? From a 2017 to a 2016? Your profile shows you’re driving a 2016 prius 4 touring. I have the same model and I love it.
  12. bugsy57
    bugsy57 New Member
    Four Touring
    No I’m looking at trading my 2017 Camry for a 2016 Prius 4 touring, how many miles can you go on a full tank of gas
  13. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    I personally have gone over 600 miles on a tank, with a bit more than 2 gallons left in the tank. That was some hypermiling and in warmer seasons. If I really tried, I bet I can do almost 800 miles on the 11.4 gallon tank.
    It all really depends on how you drive.
  14. alanclarkeau
    7,045
    7,593
    I got 1116 km on a full tank of petrol. It took 41 litres - 3.68l/100km. But that was the best tank I've ever had - see my average below on Fuelly. I wouldn't normally let it go that empty either. Depends on how you drive too.
  15. krmcg
    2,592
    2,393
    Whittier, CA
    I have three 800+ mile tanks. But it wasn't easy and requires driving past DTE of 0. I would say that most people can get 600+ miles on single tanks with moderate hypermiling techniques and little or no risk.
  16. bugsy57
    bugsy57 New Member
    Four Touring
    Very good information thank you all 90% of my driving is highway driving 65-75 mph so I was hoping to get at least 600 miles per tank.
