New to hybrid
Discussion in 'Gen 2 Prius Main Forum' started by Honey2017, Jan 20, 2017.
  1. Honey2017
    Honey2017 Junior Member
    71
    17
    US
    Hello all
    As of right now i have an 06 odyssey. Iam selling her because all the motor mounts keep going an iam tired ofpayong $2600-3200 every time. Anywho, my sis in law recommended a prius. I came acros and 08 prius 141k looks brand spanking new inside an out. She runs pretty smooth from what i can tell. First time with a y hybrid. Breaks are touchy nice and new. Since i dont know much about the hybrid because i never owned one i been looking on thsi forum and reading. Iam excited but at the same time really nervous. The diy repairs once i get correct tools i can do. The hubby and i been learning. I guess i need to know which is the best diagnostic to buy for myself incase i need to figure out whats wrong with the car if i come across any problems. What spark plugs oil tranny fluid etc is best to use as well as i will be doing the oil, transmission fluid and spark plugs as soon as i get her. The dealer iam getting her from buts from auctions there is a tag inside window which states oil was changed in dec 2016 but i would like to redo it all for my own peace of mind. I gotta pretty good idea how to change the 12v. I wont be doing that right away but it is on my list to do. I also been studying the whole replace cells on the battery but iam not grasping what to use or how to use a thing( sorry cant think of the name) to properly charge an discharge before reinstalled. Got a lot of learning to do. The car is originally from florida but iam moving back to knox tennessee. I heard wether can have an impact on my battery. Idk iam so nervous with this buy. It feels right. The car is silent no noises or shaking etc soni think i might have gotten lucky. We will see. Will take me a bit to understand this car but i need a gas saver. I drive alot. This will cut down once i move to tennessee. I guess iam looking for the need to haves with tools and what the car needs etc . now iam babbling. Does this sound like a good deal 08 prius 141 k for 4400
  2. Honey2017
    71
    17
    US
  3. JC91006
    16,939
    8,647
    You have to first find out why this was at auction. Was it a repaired wreck? If you think the odyssey was bad, it'll be really good compared to a problematic prius
    Montgomery, Honey2017 and srellim234 like this.
  4. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    I am no expert but if it feels good and drives good and you have warranty, enjoy your car.
    My 2009 that I just got from a private seller (no warranty) had 230,000 Miles but it felt right on the test drive. It needed a few things and I was able to negotiate that in the purchase price.
    Simba
    Honey2017 likes this.
  5. Honey2017
    71
    17
    US
    It was a repo for non payment. Ill have to post pics almost looks like showroom clean
    Simbaboy likes this.
  6. Honey2017
    71
    17
    US
    What kind of spark plugs, oil,tranny fluid an coolant is best for the 08 prius? I would like to put to notch stuff
  7. bisco
    52,904
    go with toyota oem, available at the dealer, online, and some can be had through auto parts stores.
  8. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    What do you mean by 30 warranty on Battery?
    We need to know what state you are in re: CARB warranty length can be up to 150k miles, if the car qualifies.
    Gen2 spark plugs iridium last 125k miles even up to 141k+ and fairly easy to replace DIY. I just used my old Sears wratchet wrench and spark plug socket.
    Some of big things typically going bad in that miles range are HV battery, speedometer/combo meter display (9 yr warranty), also check the visual display pushpad for correct operation as those go bad sometimes. Seems like those of us buying new rarely have those issues, whereas used buyers see those things more oten.
  9. Honey2017
    71
    17
    US
    30 day warranty. Its a small bizz dealer. No dealer fees etc iam in flroida.
  10. Honey2017
    71
    17
    US
    Thank you all for your help. Im sure ill have more questions along the way as iam still learning.
  11. bisco
    52,904
    you need mini vci with tech stream software and an old windows laptop to diagnose most problems on a prius. check it out on other battery threads here, or on line. all the best!(y)
  12. Honey2017
    71
    17
    US
    Thanks. So the tech software does that just verify the codes i get from the mini vci
  13. Honey2017
    71
    17
    US
    I know how to check my 12v batter but is there a way to check the main batter i dont know what that one is called. But do i have to completely take it out to check it or is there a way i can check its running properly like you can with the 12v thru the display screen?
  14. bisco
    52,904
    you can check it with tech stream. mini vci is just the cable from the obd to the laptop.
    for repairs, you can subscribe to toyota tech info for $15./day.
  15. JC91006
    16,939
    8,647
    Who's the dealer in Florida?
  16. Honey2017
    71
    17
    US
    Awesome. Ill have to learn. I wish i was home in boston not to sure if their are hybrid shops in knoxville tennessee. Lots of homework ahead of me. I got till tomorrow to decide to vuy this 08 prius or not
  17. Honey2017
    71
    17
    US
    I believe its called olavto export inc hes in hollywood
  18. bisco
    52,904
    make sure it's not salvage or flooded. did you run a car fax?
    you wish you were in boston, and i wish i were in florida!:p
  19. Honey2017
    71
    17
    US
    Yes clean car fax clean title. I wish i took pictures. Shes surprisingly nice an on my test drive i could barely feel her unless i was a stop sign waiting so i can go i can tell when electric kicks in. I thought the car died but its to my understanding that is a normal feeling.
  20. Honey2017
    71
    17
    US
    Idk know why iam calling the prius a she hahah must be because iam a female lol
