New to Me 2008 Codes and torque app readings
Discussion in 'Gen 2 Prius Technical Discussion' started by Challett, Apr 22, 2018.
  1. Challett
    Challett Junior Member
    Maryland
    Hi All,
    Hybrids are a new world to me at this point in time. I've been reading obsessively for at least a month to try and familiarize myself with these cars. I have a lot to learn..... Checked out a car today and have an agreement to have it delivered in a week. While I was there I ran my obd2 BlueDriver code reader (see attached report) and downloaded the torque pro app late last nightand added the hybrid battery voltage blocks (see pic)
    All the blocks were within .1 of each other. I'm thinking this meas the traction battery is ok. Someone please take a look at the values and give me your opinion if I am correct or not.
    The codes I read on the BlueDriver concern me the most B0178 shows up under "Tire pressure warning system code" "Air Conditioning code" "remote Keyless Entry code" "Immobilizer Code" and "Power Code"
    B1400 "Air Conditioning codes"
    B1271 "Gateway Code"
    P1378 "Body Code"
    C1241 "Antilock Brake System Code"
    I can still walk away from the agreement, however, the car runs fantastic, Starts and stops at redlights, and no dash lights were on.
    52,814
    welcome!
    did you run the hybrid battery test under load?
    the other codes may be nonsense if everything is working. how many miles on her?
  3. Challett
    Maryland
    I didn't run any specific load test. I just observed the blocks while it was running. They were all 15.7v and varied by .1 or less. It's got 127K on it. I'm pretty mechanically inclined and I got what I believe to be a good deal @ $4600.
    #3 Challett, Apr 23, 2018
  4. bithead2
    bithead2 Junior Member
    Orange County
    I have a vehicle with similar codes littered throughout several categories just like this. The B0178 shows up but it seems ambiguous. I'm thinking that perhaps the hybrid battery has a bad cell in it and needs repair. Not sure what to do in order to make the issue more clear, what further tests to try, etc.
    CJ
  5. bisco
    52,814
    are you using a prius aware scanner? once you have the correct codes and subsides, you can go to tech info.toyota.com and download the service manual with code troubleshooting tree.
    all the best!(y)
  6. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    How do you know if you have prius aware scanner?
  7. bisco
    52,814
    tech stream, you can get it on amazon
  8. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Someone could have reset the codes but not disconnected the battery. That’s why the scanner could see them but the lights are not on. Look around this site on how to check the standing battery voltage. A low 12v battery could cause some of those codes. That c1241 code could be an expensive fix it it was not caused by low battery voltage.
  9. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    There are several different tech stream Toyota cables listed, how do you know which is correct one?
  10. bisco
    52,814
    best you can do is search here for what others have purchased.
  11. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    You can interrogate all 11+ ECUs that are on the Gen 2 Prius.
