New to me 2010 T spirit in grey metallic
Discussion in 'Gen 3 Prius Main Forum' started by adrian-gregory, Jul 31, 2021.
  1. Mendel Leisk
    41,512
    This is a good tactic. It's funny how many here have asked what will happen if you remove just the oil filter; it's well above the sump which is holding the majority of the oil; you only lose about 1/2 cup, removing the filter.
  2. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    And you can always add that oil back in again.
    #22 adrian-gregory, Aug 6, 2021
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,165
    6,319
    Texas Hill Country
    Try running it without the oil filter
  4. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    No thank you.
  5. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    guess I’m not the only one asking trick questions for quotes :eek:
  6. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Looked back through all the receipts on the car tonight. cant see the water pump ever being replaced. Have just ordered one from Amayama.com. (I used to buy parts for them for my Landcruiser 80 series) several years back.
  7. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    ASRDogman likes this.
  8. ASRDogman
    ASRDogman Senior Member
    7,606
    3,915
    They look nice! What brand are they? Were they difficult to install? How long did it take you?
    Did you have any help or did you do it by yourself?
  9. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    They do look nice, thank you.
    Make is Auto Clover.
    Easy to fit in about 20 minutes working alone.
  10. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    Why are you replacing the water pump
  11. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    i cannot see a receipt for it in my file of receipts. from what i have read it has a service life around 100k miles. car is sat at 185k miles so i will replace it.
    #31 adrian-gregory, Aug 8, 2021
  12. douglasjre
    2,181
    720
    Null, NL
    Can you please provide a link to the person who provided the service life information...
  13. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Ordered a stainless steel cat cover plate last night.
  14. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Welded up a broken exhaust bracket.
    More rust treatment under the rear whilst it was up off the ground.
    Fitted the cat plate
    Raytheeagle and bisco like this.
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Mendel, remember Steve McQueen in the movie called "The Blob"? That oil gloop looked like it!
  16. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Or the more recent movie Venom.
  17. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Thought I would take a look at the battery bus bars before hitting the road today. Pulled everything off (left battery in car and just removed the back seats) and found some corrosion and discolouration.
    cleaned the copper bars in a mix of white vinegar, sea salt and a little bicarb, simmered for 10 minutes. brushed clean the nuts. Rinsed off in distilled water dried and refitted.
    Should help the electrons flow a bit more easily.
    Easy enough job.
  18. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Swapped out the water pump this morning. thought it would be a quick job, has turned into a mission. bottom bolt was mis-threaded - took ages to wind it out. waiting on a pal of mine now to come round with some heicoils so i can complete the job.
    #38 adrian-gregory, Aug 14, 2021
  19. Mendel Leisk
    41,512
    Just editorial: did you mean mis-threaded, cross-threaded? You can likely edit for about 12 hours.
  20. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Thank you - edited. My pal never turned up to help so I went to another garage i know and borrowed some taps and on the off chance ran a tap through the threads taking my time. good news is the bolt torqued up fine (gave the bolt a dose of blue thread lock for good measure). car is all back together and road tested and seems fine.
    Also did another oil and filter change - found a tiny amount of that jelly stuff in the oil that came out with the oil filter but nothing in the filter. car has done about 400 miles since the last check. So I reckon we are good to go to the next oil service.
    #40 adrian-gregory, Aug 14, 2021
