New to me 2012 Prius V 245k miles // $4500
Discussion in 'Prius v Main Forum' started by MilkyWay, Feb 3, 2022.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,159
    6,316
    Texas Hill Country
    I guess you may learn the hard way that a gen3 head gasket seep that initially fouls the plug and then clears is a common early hg sign for these engines. Ignore it and you will get the common hg symptoms including loss of coolant, smoke, fouling at each stop start as you drive along with a warped head, possible broken rod and or hole in the block.
    Tim Jones likes this.
  2. Tim Jones
    Tim Jones Senior Member
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Classic Symptom..... very common on 1.8 with 240,000 miles.
    Easy to diagnos..... examine antifreeze level VERY closely for one week.
    If it's down at all then it's the headgasket.
    I changed mine and it was a bitch... .
    Better off getting a low miles engine.
    #22 Tim Jones, Feb 5, 2022
    Georgina Rudkus likes this.
  3. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Examine the coolant ("for 1 week") for what? I'll be driving this for months/years without checking.
    Btw --- My mechanic just finished a gen 2 engine swap for me. He has a gen 3 of mine doing a gen 4 swap. And another gen 3 doing gen 4 engine swap in it. I rent them out I have a fleet of them.
    That's his current tasks for the next couple weeks. Very used to putting gen 4s in gen 3s.
    Literally doing that to 2 of my gen 3s right now.
    I would be a little annoyed biting the $2500 repair but wouldn't be new to me. And I'd much rather have a gen 4 engine in it.
    But, I'm gonna put 80 to 90% odds not a thing wrong with my Prius V. The first clue will be when I go to start it tomorrow morning.
  4. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Answer to your question : To see if it's low.
  5. rjparker
    10,159
    6,316
    Texas Hill Country
    It seems you would know about the early hg symptoms if you have all those gen3s that were bad enough to need replacement engines. Early on the rattling can go weeks between episodes and usually clears for a while after swapping plugs.
    v's do have differences over the hatchbacks such as Pitch and Bounce control, stronger ac and a lower final drive ratio. Head gasket issues are the same.
  6. MilkyWay
    823
    359
    23
    MI
    I haven't even popped the hood on my car yet (it's cold). I know the oil won't burn because the guy has a 5000 mile interval sticker from the Toyota dealership (and 2nd clue is he takes his car to the Toyota dealership to begin with lol).
    More I think about it this is 100% a brand new bad plug issue. Only happened after sitting 5+ hours (I'll say overnight).
    It is actually physically impossible for the issue to have been present before. It was brought in from a new car dealership to the auction. Definitely sat many days. If they "cleared the code" it'd come right back and be misfiring like crazy on the cold start for a couple seconds.
    It didn't arrive like that. It arrived with no cold start issue and no engine light (again, if they deleted code it would have came right back).
    There is only 1 other possibility: "The earliest sign of a gen 3 headgasket issue magically happened 2 days after I bought it".
    I'm gonna go with common sense and say it was shot plugs with 150k miles on them.
    #26 MilkyWay, Feb 5, 2022
  7. MilkyWay
    823
    359
    23
    MI
    I buy them as new car trade-ins (seller is a new car dealership) from dealers auction. I don't see the early symptoms. 99% of time nothing major wrong but you get screwed once in a while. They'll come in smoking (minor and sometimes major smoke) and it is completely obvious.
    I plan on keeping this one so I'll know soon enough.
  8. MilkyWay
    823
    359
    23
    MI
    1st issue with the car. Went to warm up the car from 8am to about 8:20am......Very frigid temperature.
    Approximately 0 degrees.
    Buttons on dash were even a little frozen as I set to high temp defrost.
    Came back out at 8:20am car still cold and I noticed: "Hmmm...A/C button accidentally was on I've been running it with AC for 20 minutes".
    Press button off and still cold.....Drive 5-8 minutes to drop daughter off at school.....Realize obviously a problem cause it is still blowing cold.
    Drop her off, go to parts store suspect low coolant.....Pop hood, reservoir appears to be frozen!
    Drove back home and got back around 8:40am....I know not good to run 40-45 minutes with frozen coolant reservoir but didn't have dash lights, no funny noises, still the indestructible Prius engine running as smooth as new.
  9. MilkyWay
    823
    359
    23
    MI
    About 26 degrees today and I started by adding a splash of coolant (pic of level in case "HG" and drops over time...you can see prior level from video above).
    Heat works strong. I suspect it was frozen or partially frozen yesterday cause it idles and/or ran for 45 minutes with ice cold "heat"!
    I didn't exactly place a stick inside the reservoir and poke it to see if it was indeed frozen/solid....But appeared to be and there was ice around the top.
    Question: What does the "B" line indicate on the reservoir. I am definitely a little past full but well below the "B"
  10. Mendel Leisk
    41,467
    @ChapmanF sussed out the purpose for B, with a close reading of the Repair Manual instruction (attached). In that document, they say to fill to B line after a coolant drain, and then run the engine in maintenance mode (runs continuously), and hopefully as it warms up the air pockets work out and the level settles to the full line.
    Air_Boss likes this.
  11. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
    So 'B' is for burp. The burp line.
  12. ChapmanF
    18,216
    Yep, that's how I'd say it. :)
    You can help it along during that maintenance mode warmup cycle by squeezing and shaking some hoses some.
    Be very careful with your body parts that close to the radiator fans.
    Timing lights used to come with warnings about how the strobe effect could fool you into seeing the fans as stopped. The same thing can happen if you're working in the dark with, say, modern LED headlamps or flashlights, which sometimes drive their LEDs on rapid pulses.
    Tim Jones and Mendel Leisk like this.
