New to me 2012 Prius v, a few questions/repairs
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ak907, Apr 6, 2017.
  1. ak907
    ak907 Junior Member
    27
    DC
    Hey all I recently purchased a new to me 2012 Prius V 5 (56,000 miles), big upgrade from my previous no a/c, no power anything, manual tranny, previous ride. Loving it. On my first tank I got 42 mpg in coldish (30s-60s) weather with mostly highway driving. It need a little work though and I have a few questions.
    My most pressing question is about the headlight washers. The drivers side headlight washer is broken. Specifically the little color matched blister is broken off. This causes it to spray forward instead of back onto the headlight like the passenger side one. I have the blister, but I cannot figure out if fixing this this means I will have to replace the whole sprayer unit (~$300) or if there is some subcomponent that connects sprayer and blister that I can get. I also can find no videos or documentation on how to work on the things. Anyone who has dealt with these and can advise me on doing so would be greatly appreciated.
    Sorry for the book of questions below, read or don't as you like.
    Other work I plan on doing: oil change and tire rotate (obv), tranny fluid change (still a little on the fence on this, why fix what isn't broken. But on the other hand I don't buy that the fluid is good for life, and for longevity it does make sense to replace it at least every once in a great while. I tend to like to do lots of stuff up front when buying used as I don't know the previous history), drivers side brake light change as the housing on the current one is smashed out over the signal bulb (still fully functional).
    On operating the Prius:
    1. Tire pressure. This is the 5 with the 17 inch wheels, a good mix of harsher and better handling than the too squishy normal wheels on another V I tested. I have read a lot of posts on tire pressures and know it can get pretty controversial, have not seen much on the V and specifically the 17 wheels though (just this thread). Toyota recommends 33 front, 32 rear, the tire have a MUCH higher max of 50. Tire rack recommends what is on the sidewall (the one problem I have with this is that Toyota cannot possibly anticipate the dramatic changes in tire technology that will occur over the possible lifetime of a car). Most on the forums seem to be 38 to 42 psi that I have read, anything new on this? Just experiment?
    Tested rear after drive at ~36 recently, before reading that should leave psi at b pillar level, decided to wait till cold and have not yet got back around to messing with them. Not sure I want to make a whole lot harder, not interested in wearing out suspension faster in pursuit of ultimate mpg as I plan to run into ground, but would like to protect wheels from damage, get good braking, good handling and good mileage.
    One issue I have noticed is tire spin on hard take off (run across two lanes, silly road designs), eco tires I guess, still seems silly to have traction trouble in dry with a not that powerful vehicle.
    2. Auto Headlights: The V has auto headlights, pretty sweet, but in reading it looks like the LED's are not user serviceable, and the auto function even on the lowest setting seems to turn the headlights more that I would have done so on my own. Will this burn out the LED's eventually? Seems that not being user serviceable makes it likely an expensive replacement. Will it reduce mileage (old school headlights could take 1-2%)? In addition I cannot tell for sure but auto does not seem to use daylight setting for lights when appropriate. Maybe a bad habit to use this?
    3. Software updates, and secret key words to weasel updates for head unit/system out of dealer (without paying tons of money)/get reverse beep turned down to single beep, when it is being serviced for recall this weekend?
    Specifically there seems to be no way to reduce the number presets for the radio, there are to many using the wheel controls it's to easy to get lost. Have seen others post on how to reduce, but my head unit does not seem to have the option. Also sometimes my phone calls don't get picked up over bluetooth by the headunit, hoping updates might fix things up a bit.
    4. Seat heater: love it, but it seems to start out strong, then down temp to almost imperceptible then then cycle back up to high. Understand it will try to keep from overheating, but can manually kick it back into high by switching off and on again. Is cycle normal/anything to adjust it?
    5. Nav: How to update? Or is it not worth it and should just use google maps with traffic? I would do a head swap (sheesh entune is terrible, how it is supposed to be better than just using bluetooth?) and get android auto, but I would hate to loose the settings and mileage displays.
    6. OBDII: Best cheap bluetooth OBDII device for monitoring? Best app? Best for being able to do things like change backup beep (scanttoolII)? (read you could do so with some of them and some of the phone apps available)? Best app? Best mount for monitoring and maps while driving in prius?
  2. ak907
    ak907 Junior Member
    27
    DC
    Oh I would also be curious if anyone has opinions on best placement for a bubble mirror on the mirrors to help mitigate the annoying lack of lane change visibility.
  3. Air_Boss
    Air_Boss Senior Member
    3,941
    1,079
    New Yawk
    We run 42psi Front / 40psi Rear on the v Five's 17" tires. No harsher ride, improved tracking, improved mileage.
    Tire-spin on take-off? Is that in wet or dry conditions? Wet, sure, especially if you launch in "POWER" mode. Dry is unusual, unless launching off a contaminated surface (sand, for example). How's the tread depth?
    No idea on the headlamp washers. Can't recall ever using them.
    LED driver and lamp life are probably 20,000+ hours MTBF, and could be far greater. >13 years assuming 4 hours nightly (365 days/year). Proportionally longer life if used less frequently (or duration).
  4. ak907
    ak907 Junior Member
    27
    DC
    Awesome. I will give those pressures a try, thanks for the input.
    Yes, in dry I seem to be able to spin the tires in power mode quite easily, its a tad frustrating. Perhaps something I will simply have to address when the next set of new tires are needed.
    To bad, I cannot seem to find anything on the washers. Not convinced I would use them all that much either, but for now I am stuck with a black hole on the bumper until I can fix it.
    Hmmm good to know on the LED's, maybe worth trying to be a bit more conservative in their use given I can find no information on their replacement (actually just found a thread stating that they are ~$800 each to replace, yikes, bit scary for a vehicle I planned to run until the wheels fall off).
    #4 ak907, Apr 7, 2017
  5. Air_Boss
    3,941
    1,079
    New Yawk
    We tend to keep 'em til they drop, too. Our v Five ownership experience has been encouragingly low cost (knocks on wood).
  6. ak907
    ak907 Junior Member
    27
    DC
    Great to hear! Love all the extras, but have been worried about what they might cost long term to upkeep/repair/maintain.
  7. ps54888
    ps54888 Junior Member
    US
    Head light washers come on as you use the washerfluid on windshield
  8. Air_Boss
    3,941
    1,079
    New Yawk
    They shouldn't. They are separately triggered by a lower dash toggle. If they do, someone has mucked about in the wiring harness.
  9. ps54888
    US
    Mine does i found out hard way was standing by front tire and wife turn on windshield wipers to clean them i got wet from them
  10. Air_Boss
    3,941
    1,079
    New Yawk
    We have a 2012 v Five as well. Isn't there a toggle on the lower left dash panel for the headlight washers?
  11. mikefocke
    3,692
    1,644
    Sanford, NC
    Are you both right? Could the toggle tell the system to turn on the headlight washers whenever you use the windshield washers or, in the other position, allow the windshield washers alone? Or is the toggle a headlight washers now switch?
  12. Air_Boss
    3,941
    1,079
    New Yawk
    On ours, it is a "wash headlights now" switch.
  13. ak907
    ak907 Junior Member
    27
    DC
    Well I got the inverter software upgrade on by dealer Sunday. Talked to to the service and parts folks quite a bit. They were happily quite un-pushy and helpful. Also turned backup beep to single beep for me.
    Software head/system upgrade would be ~$100, nav would be ~$275 :S. Wish I could find one of those usb upgrade drives, but they seem to maintain very tight control of them.
    Washer is apparently only sold in two parts, the blister and the sprayer ($300). Let me talk to mechanic but had no suggestions. Later working on car with buddies, found we could pull the thing out and look at more closely and it looks like the top part of the sprayer is twist lock removable, so could conceivably replace just that big which is what had the plastic snap. Unfortunately no one seems to sell them separately. Going to try and look on ebay for something. If I can't find anything I may try to take it would and find the best plastics glue/concrete I can to join them. Maybe drill a small hole and use some twine as well.
    I changed the oil (not the prettiest color coming out, fairly dark coffee) and filter, and the transmission fluid (more purple from dirtiness than red) thanks to the help of my giant of a buddy, the filter had been torqued on so only his massive strength could loosen it, ran into the same with what I presume was the factory tightened bolts on the tranny. Also rotated tires. Turned out don't need to front rotors or pads I bought :S, rotors cleaned up on some braking, front pads are maybe a bit past half life upon closer inspection.
    On the somewhat concerning side I was able to put the whole 4 quarts of tranny fluid I purchased into the car without spillage out the fill hole. Manual specifies 3.6 quarts. Car was as level as could be reasonably be expected I believe, coolant in tanks looked quite level. Quite odd, not sure if I am low or high on fluid now.
    In addition I put a whole 4 quarts of oil into the engine, slightly less than the 4.4qt specified with filter change, but about right on fill bubble (would prefer a bubble followed by a line like on my old ford), some streaks slightly above, will be checking again soon.
    Engine is a bit quieter, and transitions between electric and ICE are smoother.
    Interesting note, disconnection negative 12v battery terminal in prep for brake change cleared the maintenance light, did not expect that. It also somehow confused the rear hatch electronic release which refused to work until the car was driven for a short while.
    #13 ak907, Apr 10, 2017
  14. ak907
    ak907 Junior Member
    27
    DC
    I have not tested this to confirm my memory, but I am pretty certain on mine the headlight washer button is an on/off which turns the use of the headlight washer in conjunction with the windshield washer on and off. The headlight washer only goes off the first time you hit the washer fluid, if you do second wash it will not activate again for some time.
  15. Mendel Leisk
    38,653
    That is a bit of a head scratcher. Did you do a very thorough drain, maybe that made a bit of difference. If you got 4 quarts in, and none spilled, you should be good.
    If you also changed the engine oil filter the level will be a little high until you've run the engine: about a cup of oil resides in filter cavity. Also be sure the car's on the level. My take: do a good drain, then slam in the spec'd quantity, check it after the next drive, on level ground. As you mentioned, the dipstick can be "streaky". I would suggest to pull the dipstick, wipe it, then wait 5 minutes before reinsert to check level. This gives fluid hung up in the dipstick tube time to drain, gives a much cleaner read.
    Good job. In my experience, the drain and fill bolts take a little oomph to brake loose. Installed torque spec is 29 ft/lb. Having a long handled ratchet wrench helps immensely. Then it's not that much effort. Full disclosure: I weigh about 150 lbs, lol.
    There's more to brake inspection than just checking pad thickness. It's good to pull the caliper off, clean the pads and shims, relube the pins, every 2~3 years, depending on your conditions and usage. Be careful with the rears, they likely have similar parking brake mechanism as regular third gen Prius: there's a cross-pattern on the piston that must mesh properly with the pin on inner pad backing plate. The pin needs to be located and firmly seated between the piston face spokes.
    Regarding the headlight washer: on our regular 3rd gen Prius, the headlight washers only activate if you use the dedicated switch, not with the regular washer stalk. Also, I believe for the headlight washers to activate the headlights have to be on?
    Raytheeagle likes this.
  16. ak907
    ak907 Junior Member
    27
    DC
    Thanks for the tip on checking the oil, had forgotten that, got used to filling the oil filter before install on Ford. I added the additional .4qt and its good.
    Thanks, next rotation maybe I will disassemble, lube and check them out. And thanks for the heads up on the weird rears, I remember reading about that.
    I believe you are right, still have not tested, I will try to remember to do so this evening. I think the washer button has to be on and headlights on, then when you activate windshield washers the headlight washers will go off as well.
  17. Mendel Leisk
    38,653
    When I've opened up our brakes, ie: taken the caliper off the rotor, as a precaution I disconnect the 12 volt battery connection beforehand. There's outside possiblity the system will try to pressurize while you've got it open, which could be disastrous, pop a piston out of caliper. The main way is if you open driver's door, but who knows, so I play it safe. It's a bit of a pain: you lose trip meter, radio presets, (possibly) window auto up (that can be retaught). Also, the car behaves a bit strange, the first start up and drive after, does some odd revving, seems to be relearning.
    Leave the battery disconnected till you've completely reassembled the brakes, and before reconnecting be sure top pump the brake pedal multple times, to ensure there's no excess travel in the pedal.
    Also, when dealing with the rear brakes, pay special attention to the inner pad backing plate pin, and orientation of the caliper piston spoke pattern. Ensure it's assembled in correct orientation, and well seated by pressing the brake pedal multiple times. Delay using the parking brake pedal, till you've subsequently taken the car for a short test drive. You want to ensure the pin is solidly seated in the caliper piston's spoke pattern before applying parking brake, which will attempt to rotate the piston. See attachment for explanation of the piston orientation.
    I use Sil-Glyde brake lubricant on the caliper pins, and Permatex Anti-Seize compound (sparingly) on contact surfaces between pad backs, shims and caliper points of contact.
    I'll attach the regular 3rd gen Prius Repair Manual section on brakes. Prius v may have some differences, but I'd suspect this document is applicable for most all.
    Jason Beauchamp and Air_Boss like this.
  18. Air_Boss
    3,941
    1,079
    New Yawk
    Great point about the risks of powered hydraulics.
    Jason Beauchamp likes this.
  19. mikefocke
    3,692
    1,644
    Sanford, NC
    Most Engine Control Units (the computer brain that listens to the sensors and adjusts the fuel/air mix) have to run a few start drive stop cycles to relearn what is normal before they function effectively. Until they learn, they run on some default settings.
    Air_Boss likes this.
  20. Mendel Leisk
    38,653
    Interesting. I guess battery disconnects give it's head a shake, might be good idea periodically. @MSantos (patron saint of IMA and HSD) was always an advocate of that. Yeah, I noticed a significant rev up, a few times, once right after start-up, and during the next half hour or so, running some errands. Did settle down.
