New to me owner with red triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sandmanx, Jun 22, 2026.
  1. sandmanx
    sandmanx New Member
    Hello everyone. I picked up a 2009 Prius a month ago with 272K miles on it, and now I have close to 275K miles. When I was driving the car on Saturday back from my nearest town(I'm in rural Texas), it all of a sudden threw up a red triangle about 4 miles from home, and I limped it home and parked it. It won't start up now, and using the OBD Fusion app on my phone I am reading these codes: P0137(an oxygen sensor, it threw this on Thursday last week and I haven't gotten a replacement ordered yet), P1121(it's been on and been low priority) and P0AA6. It seems that my app can't read the sub code on that last error and I think that's what's causing the issue. What would be the best move from here to get it back up and running? I typically do my own mechanical work and I'm experienced with DIY off grid solar for my house setup for what's that worth.
    Thanks
  2. ChapmanF
    18,970
    The P0AA6 is why the triangle is on, yes.
    The INF code just saves time in your diagnosis by placing the fault in one of these four areas, so you don't waste time looking for it in the other three.
    If you aren't at all able to get your hands on a scan tool that shows you the INF code, you can still find the fault, it's just more work.
    You can look for threads on how gen 1 owners had to proceed (they didn't have the handy INF codes yet, and the code was P3009 in that generation, because SAE hadn't standardized P0AA6 yet). You'll have to adapt what you find there a little, because gen 1 didn't have electric air conditioning (the INF code 611 area).
    Oo, I didn't realize 'til now there's also a Carolyn Coquillette video about that. You're in good hands now.
    #2 ChapmanF, Jun 23, 2026
    sandmanx likes this.
  3. JC91006
    16,935
    8,646
    At 272k miles when you bought it, these cars usually will have problems. If you were able to drive 3k since, I am guessing your most likely cause to be a bad Hybrid Battery causing that error. A leaking module inside the battery. But that's just a guess, at your mileage it could be anything that's causing that (transaxle, AC, battery, inverter)
    When you get this error, you can start the car once before it disables itself again. To start it, you would have to disconnect the 12v battery and erase the code. Once erased, the car will start 1 time. If you need to move the car, that's the method you would use.
    sandmanx and Brian1954 like this.
  4. sandmanx
    sandmanx New Member
    It looks like this may have been super simple. I went to pull the 12v terminal connector off and it was super loose. I restarted and was able to move and start/stop it multiple times. I'm going to see if I can find a replacement tomorrow when I go to the auto parts store. The problem happened immediately after hitting a large pothole on a dirt road so that seems plausible.
    I know it has a boatload of mile, but everything on it runs well, and I think the first owner kept up with maintenance on this car and the last owner treated it like a beater. I changed the plugs when I got it and they looked well worn but the engine looked healthy, along with engine and cabin air filters. A wheel stud was broke off on the front passenger and when I changed that out it had been broke for quite some time, but the brake pads looked good. The oil drain plug was stripped and a universal plug is on it, so I have a new oil pan bottom and some rtv to change that out, and I started to flush the brake fluid but need to finish that too. After that and the O2 sensor I'm hoping to get a bunch of miles out of it, as I have an extra 2500 miles a month that I used to not drive added recently, and all my other cars/truck get way worse fuel economy. I just wanted a cheap car that gets incredible fuel economy, and an old Prius works great. We will probably get another one soon to add to the fleet too.
  5. Brian1954
    Brian1954 Senior Member
    2,667
    1,066
    South Central PA, USA
    A loose connection to the 12v battery will not cause a P0AA6 code. The code will probably return again. Be prepared.
    #5 Brian1954, Jun 25, 2026
  6. sandmanx
    sandmanx New Member
    Thanks, I'll work on troubleshooting this weekend, probably starting with a physical look at the HV battery pack. So far today I went around 55 miles without issue, and have another 80 miles tonight. Luckily I know the local tow truck driver if I need him too.
