New to me Prius, not good mileage :(
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Friend of Bill W., May 5, 2016.
  1. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    When you turn the Prius off, it displays the mileage and some other data for that specific trip, from power on to power off. What kind of mileage numbers are being displayed? The data is only displayed for a short time after power off.
    Also, what does the battery charge indicator look like before you power off? If it's lower the next morning, then something is discharging your battery over night. If the same thing is happened during the day while you are at work, the engine has to run too much to recharge the battery.
    What does the circuit display show as far as energy going back into the battery, etc.?
    51,953
    one suggestion, read the owners manual. the advice here is all over the board, because we have very little information. and also, study the other 10,000 why is my mileage bad threads. perhaps you can learn something from others in the same boat.
  3. Friend of Bill W.
    109
    164
    Elkhart, IN
    Yes I am pressing the power button and shutting down the car. Every morning when I start the car it's at 2 bars, but once I drive awhile it starts to go up. Thought this is normal.
    51,953
    nope. how about before you power down at the end of the day?
  5. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    The only way that would be normal is if you always drive quite awhile in EV mode before you park the car for the night. And it shouldn't take too long for it to recharge when you start up in the morning, especially if your drive is 25 miles. Normal level is about 2 bars from the top and that's pretty much where it stays if you are going over 42 mph during your commute. In the winter when you're using the heater, it's not unusual for mileage to be down in the 30's, especially if you hop in the car and quickly get up to speed before it's had time to warm up.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    We are all guessing, but I suspect he is looking at an average for the life of the car, not an average of each tank.
    If he is on cruise control on level ground he should get 50 MPG at 70.
  7. Former Member 68813
    3,524
    983
    US
    no, the 27mph is for that specific trip of 220 miles that you have in the picture. sorry, the picture doesn't agree with your story, there is something amiss here and that something explains the low mpg figure.
  8. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I agree we're all guessing, he hasn't answered one of my questions. ;)
    However, since his Trip A display shows only 220 miles at 27mph, his fuel gauge shows less than half and his daily commute is 25 miles, it looks to me like he's resetting Trip A to record mileage for individual tanks, but he probably isn't recording the odometer reading between fill-ups to manually compute the actual mileage.
    The battery status gives me pause and I think there might be something draining his battery, like the dome light being left on, but I can't tell because he's never said what the status is before he turns the power off. It's not rocket science to look at the display to see what the battery status is and to look at the mileage displayed when you do turn it off to see what the mileage was between power on/off. It also doesn't take a lot to watch the energy usage display to see if the charging system is working properly.
    I have a 1 mile stretch before I get to my house where the car uses EV mode. My battery doesn't get depleted and is still full the next time I use the car, which can be as long as a week. When I take my wife to some appointments, it's not unusual for me to sit in the car with the radio and AC on. It takes about 20-30 minutes for the battery to get depleted and the ICE to start up to recharge it. Recharging only takes a short time though, the ICE only runs a minute or so. Living in Phoenix, that's one thing I really like about the Prius, being able to sit with the AC on and not have the engine run the whole time.
  9. Toppcat
    Toppcat Member
    223
    69
    Northern California
  10. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    The Prius teaches you how to drive. How to efficiently accelerate....when to brake....when not to brake, etc.
    Can I assume that you are driving this car like a "regular" car? This would explain poor MPG. 70mph highway should yield at least upper 40's if not 50 mpg. I have done several 1000+ miles road trips with mine....where I have the cruise set at 70mph, yielding 50-52 mpg on the trip.
    My daily commute is 15.5 miles each way. I am in Colorado, so my commute TO work goes from 5950 ft to about 5300 ft. I frequently get upper 60's to low 80's mpg.
    Trip home, mid 50's to low 60's.
    Check your car for brake/wheel drag....but a 3 year old car should not have any worn hubs or dragging brakes
  11. Mendel Leisk
    41,467
    I too wonder about the low state of charge, think that might be behind the low mpg, if indeed that's what happening.
    Still, leaving lights on would only drain the 12 volt, AFAIK.
    CR94 likes this.
  12. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Duh, senior moment. :)
  13. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    My wife does not like driving my Prius because the way the gas pedal responds is too slow for her taste. Every time she does drive my car though, she kills the mileage for that tank. I honestly don't know how she does it. She does the same on the Suburban too. I think the Prius taught me how to drive more efficiently.
    I often times have similar readings like the 27 MPH average speed. Mine is due to the time at stop lights and such getting from the house to the HI way and the traffic on the HI way.
  14. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Personal opinion is that if she is driving like that, you're probably better off showing her how to use Power mode to make the accelerator behave more like what she's used to. Trouble is once you show her, you can't "un"show her. :)
  15. Friend of Bill W.
    109
    164
    Elkhart, IN
    Well I'm on tank 3, I'm 67 MILES on and at 36.8 mpg. I've been driving like an old lady n keeping the pedal light. I'm done whining about it now. It's still way better than my old Honda Pilot. Plus I'm falling in love with it more every day. Man I've never been tail gated so much in all my life, even if I'm going fast lol.
  16. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I don't think you ever said what tires you put on or what tires the previous owner had on. The Prius seems to be affected more that other cars by different wheel/tire combinations, but that mileage still seems awfully low given your temps in the 50's and 60's, though I don't know what they are during your commute or if you have the heater on.
  17. Friend of Bill W.
    109
    164
    Elkhart, IN
    17" sumotomo. 225/50/17. And I don't really run the heat but I usually have the fresh air on medium
  18. Former Member 68813
    3,524
    983
    US
    same with my wife. she drives so bad, she managed to overheat the HV battery once. my daughter also gets only about 40 MPG. On the other hand my son drives reasonably and gets 50-50MPG, almost as good as I do.
    i'm glad you like the car. the common mistake is keeping the pedal too light in a prius. you discharge the HV, wear it too much, and lose MPG. look up pulse&glide driving.
    sounds like part of the problem. oversized wheels with non-LRR tires and probably aired too little.
    Friend of Bill W. likes this.
  19. Friend of Bill W.
    109
    164
    Elkhart, IN
    What are LLR tires? And I think I'm just gonna drive it like I have any other car, I'm obviously not bright enough to catch on to all these tricks, I just want to drive lol. Even if I get 35 mpg it almost triples what I got in my last vehicle, so I'm learning to just be humble and enjoy the ride...or glide whatever that is!
  20. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    foBW,
    LRR is Low Rolling Resistance tire, which enhances MPG because they have less rolling resistance.
    Don't be discouraged.
    If all the basic stuff like spark plugs, air filter, alignment, etc. is good, then you are o.k.
    Just enjoy driving the Prius.
    stt
    #40 sttkailua, May 10, 2016
