New (to me) Prius Questions
Discussion in 'Gen 2 Prius Main Forum' started by cgm55082, May 5, 2013.
  1. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Please let us know how things turn out. Of course the problem will now hopefully be is what caused your dramatic improvement in mpg.
    John (Britprius)
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    102,000 the ICE is close to a tune up, new plugs etc. my car is new and put 4 people in it and did a 200 mile road trip. Only got 44 MPG on that trip
  3. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    John. You are right... I was just speaking from my experience with my '07. When I tested it, it did not drop to 10.9 it stayed around 11.9, and that was with the HID's... Unless the OP has a failing inverter, dragging rear brakes, failing wheel bearing...
  4. Britprius
    5,194
    1,924
    My calculations go like this:-
    Ignition on load with HID's = 20 amps (measured)
    The OP stated front and rear demisters.
    Rear demister estimated at 20 amps (supplied by 40 amp fuse)
    Front demister estimated at 30 amps (PTC heaters on engine cold not run, 15 amps each supplied by 30 amp fuse each)
    Fan motor on full estimated 6 to 8 amps.
    Because rear demist on the heated mirrors will be on estimated 2 amps each = 4 amps
    Total 80 to 82 amps.
    I believe these figures to be conservative given the fuse ratings so that the figures could be higher.
    John (Britprius)
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Wow you are an effective person. I would have procrastinated for at least 6 months, if not life of vehicle. Important, do not be upset by the first tankful or two. Apparently the system takes a few tanks to recalibrate after the new battery.
  6. PopsicleMud
    PopsicleMud Junior Member
    Seattle, WA
    Also, from what I've read, new tires, even LRR ones, tend to give you slightly worse mileage at first and then improve over time.
  7. cgm55082
    cgm55082 Junior Member
    Thanks wjtracy, but I don't know if I'm effective or just obsessive/compulsive. I think the latter. Once I get my mind on something, especially a problem or issue, I can't let it go until I have it resolved. I just want this car to be in great shape and getting the best mpg it can, so I can move on to something else to obsess over.
    I put the new 12v battery and sparks plugs in and just got back from a short 18 mile drive on the highway. I employed my best hypermiling techniques (which isn't saying much) and kept the speed a shade under 60 mph. According to the display, my mileage was 43.9. I realize it will take time for the new battery to take full effect, but that's already 2 mpg over what my best was before. Keep in mind, I was babying the car and trying to squeeze the absolute most out of it. Under normal driving conditions, I'd probably still be around 40 mpg. I'll give it time, but at least it's moving in the right direction.
    Agent J likes this.
  8. techntrek
    techntrek Member
    263
    84
    MD
    #1 rule in troubleshooting a problem (what I do for a living, with code), only make one major change at a time. Hold off on the tires until you get a few tanks in it with the new battery and plugs.
    mmmodem likes this.
  9. cgm55082
    Okay, here's the update: After replacing the 12V battery with a yellow top, I saw about a 2 mpg gain. Was averaging 41 at best prior to changing it. Then, after the new LRR tires, my mpg average hit 45 for the first time. I've had to drive very carefully to get 45 mpg, but I was never able to see that number before. So it seems my 12v battery, even though it tested okay, was partially to blame. The other half of the blame seems to be the tires. Both of these each made about a 2+ mpg improvement so far. I'm definitely a believer in changing the 12V battery if you're experiences unexplained mpg losses. I just hope my mpg numbers continue to rise. Thanks to all for the suggestions so far.
    dorunron and Jamesb93612 like this.
  10. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Glad to hear the changes seem to be helping you. You may see more improvement once the tires are broke in.
    It might be a good idea to do a wheel alignment. Better for the new tires plus bad alignments also cause MPG to fall.
    Good luck to you.
  11. cgm55082
    Thanks for the suggestion. I did do the alignment at the same time I did the tires. The car feels a little strange though. It tracks straight, but seems like it has a sticky spot right in the middle and doesn't want to stay there. Hard to explain, but, while it tracks straight, it also feels like it wants to slightly pull to either the left or right as opposed to straight down the middle of the road. I say this, but it also could simply be the fact that it's been very windy here all week.
  12. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    Could be the toe-in specs. Do you have the print out report?
  13. cgm55082
    I have the print out report but I'm not sure how to read it. It says:
    Left Front Actual Toe -.05 Right Front Actual Toe -.04
    Left Front Before Toe -.07 Right Front Before Toe -.07
    Specified Range Toe -.10 to .10 Specified Toe Range -.10 to .10
    Front Total Toe:
    Actual .09
    Before -1.14
    Specified Range -.20 to .20
    Does this make any sense?
  14. Agent J
    294
    111
    Sydney, Australia
    They look to be well within specs and almost dead straight.
    a negative (-) toe means the wheels are pointing outward.
    positive (+) is inward.
    Give it probably some time for you to accustomize yourself to the new tires and settings. New tires still have tall treads on them which make it a bit fiddly. Once they've been broken in, they'll be more stable.
    Or maybe you're right. It's probably just crosswinds you encountered on the highway. But if you use the highway often, you may want to try and have it changed to a slightly positive toe where it gives you more straight line stability.
    Another way to improve it is to upgrade the mid-chassis brace to the stiffer kind as what many have done with great results.
    In my current setup, I no longer feel crosswinds on the highway. It progressively went away as I upgraded little by little. The cheapest being alignment and the under chassis brace.
    My current toe is +0.4mm and it made a huge straightline difference after coming from a -1.7mm. Although it sacrificed my turn ins a bit. It feels not as sharp as before. I might dial it down back to a negative next chance I get as I only use the highway only 15-20% of the time.
  15. cgm55082
    Thanks Agent J. I'll give it some time. Will also look into the mid chassis brace you mention.
  16. Eclipse1701d
    645
    224
    Three Touring
    I am happy to hear about the improvement in your mileage! Your new tires are going to impact mileage for the next few thousand miles. Once they settle in, you will see another improvement. I used to keep my 07 at 42psi front and 40psi rear. That will also help with the MPG's. Good luck and enjoy!
