New to owning a Prius - Noises are they Normal?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sdrocker, Feb 2, 2015.
  1. sdrocker
    sdrocker Member
    166
    San Diego
    Oh that is great advice. The only issue is that my driveway has a little slope so i'd have to start it and park on level ground and then check. hmmm. or maybe i can check after work since i park at level ground at work?
    #41 sdrocker, Feb 4, 2015
  2. alekska
    alekska Active Member
    435
    138
    Atl
    This is normal. As the ICE warms up, it goes into stage at which it can shut down completely at the stoplights. That requires some kind of self-calibration of the engine idle speed. It revs up a little, and then down and then shuts up completely. Mine does it but only once over my trip to work.
    P.S. - You have a very sensitive ears for all these noises :)
    - Alex
    Britprius likes this.
  3. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Once you find out what the normal (full) level is on your drive. As long as the car maintains that level you are ok even if it is not the level the dipstick reads on level ground. If it goes down top it up to the driveway level.
    John (Britprius)
  4. sdrocker
    sdrocker Member
    166
    San Diego
    I normally hear few noises because I have music playing but I wanted to listen to all the noises to make sure everything was good. I'm glad to know this is all normal :)
  5. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks so I should make sure it's at the right level on leveled ground, then check when it's on my driveway and keep a visual image in my head of what the level should like when on my driveway and use that as a reference?
  6. Britprius
    5,194
    1,921
    Exactly. It does not matter if the level falls as you use the car a little as long as it is not below the low mark, but it should preferably be half to full. It s better to be slightly under full than over full. Over filling the oil on the Prius causes problems, and should be avoided.
    John (Britprius)
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Preferably to the full mark dimple. Very easy to hit that after you check in the am. Don't be surprised if its eating alot of oil.
    Change the oil asap and use Mobil 1 5-30 and the oem filter found at the dealer for $4.50. Buy a few.
    The car takes exactly 3.7 quarts of oil with a new oil filter.
  8. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Yeah checking at work is fine just make sure the car has sat for a few hours. Check it every other day for a while. You may be lucky and own the only 150K+ Prius that does not consume oil.
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    you know, I've been using synthetic and never really noticed them using much oil. and, every 5k when the maint light comes on, the old oil isn't even very dirty looking.
  10. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    I was getting this on and off for quite some time and never figured out what it was. It was very faint and I could only hear it when the car was at a stop and the engine was off. I think I realized at some point it was come from or near the inverter area. Interestingly it has not returned since the inverter pump recall was performed.
    This is not the same loud annoying beep you get when backing up.
  11. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks,
    This is interesting for sure. I pressed the brake pedal a few times and it makes that buzzing noise I was talking about so that is good to know. The other noise that is faint but sounds like a copier machine is still a mystery but the owner said it made that noise from the beginning of owning the car.
  12. sdrocker
    sdrocker Member
    166
    San Diego
    I just checked the carfax history and the service records the lady gave me. They both say the oil was changed 11/18/14 when it had 161,290 miles. Right now it has 163,040 miles. Should I really change it right now?
    In the future I should use Mobil 1 full synthetic 5w30 correct?
    I'm guessing I should keep an extra 1 or 2 quarts in the car at all times? I heard a light comes on when the oil gets low, is that true at all?
    #52 sdrocker, Feb 5, 2015
  13. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    No Prius has only low oil pressure warning. When it comes on it may already be too late.
  14. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks. Once I get the hang of it, will checking the oil level once a week on a 163k miles Prius be enough?
  15. Mendel Leisk
    41,463
    You can find the answer to that question yourself, grasshopper. ;)
    Check it weekly at the outset, if there's not much drop, you're overdoing it, increase interval.
  16. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks I overthink things sometimes, same on the 53 chevy hot rod :)
  17. sdrocker
    sdrocker Member
    166
    San Diego
    The oil was changed 11/18/14 when it had 161,290 miles. Right now it has 163,040 miles.
    This was done by San Diego Trux "Independent toyota, lexus and scion service and repair center"
    I'm guessing I just need to check the levels and not change it until the maint req. light comes on?
  18. valde3
    2,002
    749
    Finland
    Prius doesn’t have any smart monitor on oil change interval. So just select interval that you like and use that.
  19. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Sounds ok to me. Hopefully it wasn't changed at a dealer which means it got vat oil. Getting it changed at the dealer is somewhat troublesome to a car that may be eating oil as the oil change guy will never check the oil before he dumps it so it could be running very low all the time and the owner never knows it till one day they hear a engine knock. They bring it to the dealer and get the bad news and trade it in on the spot. Dealer sells it at auction. Guy buys it and we get to meet him here with a sad auction story and a car that has a bad knock. Lots of folks keep driving it and that ends not well. Seen lots of those guys. They think they stole it auction. Not so much.
    So many people think this car is so special only the dealer can open the hood. Which is great for the owner as it relieves them of all responsibility. Till the engine blows up and dealer says you should have checked your oil its empty. Then there like hey only you guys changed the oil. Dealer says so what...we didn't empty the oil.
    When I buy a used car I change all the fluids. Because just in the mechanical of changing the fluids I sometimes stumble across issues. Your car may have its original transmission fluid. In fact if all the receipts you have are from a dealer I can almost guarantee it.
    Yakoma likes this.
  20. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Oh and the oil idiot light comes on after the car is almost empty of oil. It really sucks. That one time light on event usually cause it to eat oil as it damages the oil rings. Unless you keep driving it and then it damages the mains.
