New to Prime driving advice
Discussion in 'Prime Main Forum (2017-2022)' started by Lievre23, Aug 17, 2017.
  1. Lievre23
    Lievre23 Junior Member
    Wading River, NY
    Just purchased a 2017 Prime (traded in Prius 2012).
    I will be driving 42 miles (each way to work), 30 of it on the Long Island Expressway (60+mph)
    Looking for advice on best tips to get most MPG? (Electric is .20kwh here on LI).
    HPrimeAdvanced likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  3. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Congratulations! If you can keep speed ridiculously slow, 55-60 on the LI Expressway, you should eventually get to 30-35miles of EV only range (no A/C), and 60-70mpg overall.
    If you don't want to mess around with hypermiling, just let the car do the calibrations, and you'll still get great mileage! Read other posts here where owners will post tips. Have fun!
    joachimz and priuscatprimeguy like this.
  4. Lievre23
    Wading River, NY
    Thanks...
    Not sure about Charge Mode? HV Mode? EV Auto? Which is best for my drive?
  5. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    The car will default to EV mode each time you restart it; just leave it in that mode for starters, and watch your range. Learn A/C, radio controls, especially on left side of steering wheel (voice commands, etc.) There's a ton of stuff to learn; early on, I just turned on the car in the garage, with owner's manual on my lap, and started playing with the buttons; spent several hours doing that and learned a lot. Again, have fun, it won't be boring!
    priuscatprimeguy and Lievre23 like this.
  6. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    agree with @HPrimeAdvanced ... lots to learn, suggest you download the pdf of the manual.
    No one can tell you what will work best for you (unless they have the same commute, driving style), you'll have to try things out on your own and see what works best for you, if you get free EV charging at work, that is a no brainer ... I have an even longer commute than you, you can start reading here but there are many many more posts with great advise
    My EV range story | PriusChat
    Lievre23 and HPrimeAdvanced like this.
  7. Mark57
    2,945
    2,740
    OK
    I've driven the LI Expressway. Don't be that idiot driving so slow below the flow of traffic that you become a problem just to save a little gas. Be safe first. If you're dead, it doesn't matter how much gas you saved.
  8. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    My commute is a little shorter than yours (~37miles), and more rural highway than expressway, but I get the best gas mileage by using EV on the slowest parts of my drive, especially when going through a town. My last tank I got 89MPG (calculated). Coming from home, it's the fastest part of my drive, so I always start out in HV for about 13 miles, then switch to EV until I run out on my return trip home.
    I also don't drive any different than anyone else on the road, but if someone's going a bit slower than normal traffic, I use them as an excuse to go slower myself. :)
  9. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    Just drive you new car. Start off in EV mode and just drive it. There is a switch that gives your choice of 3 acceleration modes, econ, normal, power. These just give you more acceleration for the same pedal position. Pick the one that best suits your drive. Your choice isn't a big deal. Your ability to safely merge into traffic is a big deal.
    After you get accustomed to your new car, try different modes. Toyota's engineers did a good job of programing the car, so just drive safely and see how you like things. EV Auto gives you a battery plus gas engine option when you need it. HV gives you gas engine all the time plus added battery power when needed.
    NJ-PrimeAdvanced likes this.
  10. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Echoing a lot of people here. It’s more efficient to drive in ev mode in stop and go or under 50mph even though it can go up to 82. I tend to drive in HV mode on the highway as the car’s ICE is just so efficient for highway driving.
    john1701a likes this.
  11. Lievre23
    Wading River, NY
    Charging? In NY - it is .20kwh - is it worth charging or just using the cars technology to save most $ ? How much energy is used per charge?
  12. bps
    bps Active Member
    304
    119
    The Prius Prime has a 8.8 kWh battery. It’s fairly easy to do the math from there based on what kind of mileage you’re getting in EV mode.
  13. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Ummm knock it down to about 6.6-6.8 kWh for the true usable part that's rechargeable or usable. Some of it is for HV and the other is the reserve portion that we don't access to protect the battery. According to my logs the most I've ever charged is 6.8 kWh's.
    After that... calculate away!
  14. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    You have to take into account charging-losses and climate-prep.
  15. bps
    bps Active Member
    304
    119
    Yes, you certainly need to account for your own personal use of climate control, charging loss, etc.
    I guess in answer to the original question, one needs to measure how much electricity they draw and then balance that against the actual amount of miles you get based on the variables unique to you. (Road topography, how you drive, use of climate control, etc.)
