New to prius. I have an 08 model. Seem to be having trouble with abs actuator. Need help
Discussion in 'Newbie Forum' started by Clay D Robinson, Jan 6, 2021.
  1. Clay D Robinson
    Clay D Robinson New Member
    Durham
    Hello. I'm new to prius and chats in general. A couple of weeks ago several lights came on dash. ABS, CBS and brake light. I added some fluid (slightly low) and all lights went off. The ABS pump seems to run almost conatantly. Other than that I seem to have no problems braking or otherwise. Could it be something else. I bought a used actuator and am waiting for it to arrive.
    Thanks.
    Clay
  2. henry ortiz
    henry ortiz Junior Member
    texas
    Hey there this is common problem with a Prius but I think probably it could be the brake booster you should get a diagnostic to see what code do you have.
    you can find many info in this forum
    Best luck
