, New to prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pablo1914, May 27, 2015.
  1. bisco
    52,854
    when it's on for a minute, can you put it in drive and move?
  2. Pablo1914
    Pablo1914 Junior Member
    35
    Atlanta, Ga
    Yes, I can put in in drive.
    I can drive all I want as long as I don't turn the car off.
    IF I turn it off, it won't go into drive. I'll go to neutral.
    If I take out the orange thing in the battery and I disconnect the 12 volts battery, I can turn it on again, and drive. after one minute or so, the triangle will come back on.
    52,854
    that is very interesting. so, when you drive it, are the mpg's good? does the battery indicator act normal? does the engine operate as expected?
  4. Pablo1914
    35
    Atlanta, Ga
    Everything shows normal.
    Except that the triangle turns on and when I turn the car off it won't come back up. I guess is a feature that prevents the car from shutting off in the middle of the highway..
    The code still is the same.. P0A80 pd
  5. bisco
    52,854
    how is the 12 volt health? and fob batteries?
  6. Pablo1914
    35
    Atlanta, Ga
    12 volt battery...
    so so..
    I died twice in this process of me fixing the battery. I started in April.
    What are FOB batteries?
  7. Pablo1914
    35
    Atlanta, Ga
    I thought that the 12 volts battery dying for not being used was "normal"..??
  8. Pablo1914
    35
    Atlanta, Ga
    Now that you mention the 12 volts, I remember that one time when I was charging the 12 volts battery, I turned the prius on, and when I disconnected the 12 volts battery charger, the triangle came back right away..
    It may have to do with that..
    I thought It was because the 12 volts battery was weak, which it was..But I assumed that it would have been charged afterwards when I tried the prius again.
    I'll test the 12 volts battery tomorrow.
    How much should it read? I know you can do that with the screen of the car but I don't exactly remember how.. I'll google it.
  9. bisco
    52,854
    the best way is with a digital volt meter. read it in the morning before the car is turned on. don't open the driver door, that activates electronics. pop the hood tonight, so you can access the jump point in the fuse box. it should read 12.6 volts or better.
  10. bisco
    52,854
    fob battery: do you have sks or do you put the fob into the dash slot? the fob battery is inside the key fob.
  11. Pablo1914
    35
    Atlanta, Ga
    I have those wireless keys. Batteries may be low in that too.
    I'll check with the multimeter tomorrow as you suggest.
    Thanks and have a good night!
  12. Pablo1914
    35
    Atlanta, Ga
    I checked the 12 volts battery today. Voltage is 12.36.. Any thoughts?
  13. bisco
    52,854
    how old is it?
  14. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    That is low, you need to charge it up using modern charger for AGM batteries with a 4 amp output. Once removed from the charger and been left sitting for about 2 hours, the voltage should be ~12.9-13.1.
  15. Pablo1914
    35
    Atlanta, Ga
    This is going to be a bit scary
  16. Pablo1914
    35
    Atlanta, Ga
    For what I see, it's the original one. last picture has a date: 04/12/10 (I think it's a date)
  17. dolj
    dolj Senior Member
    8,645
    4,396
    I don't think it is the original one but it is coming up for 5 years in Dec. That date code decodes to Dec 4, 2010. At coming up for 5 years old, this battery may have seen better days. You can try charging it, but I wouldn't hold my breath.
    Is that the bottom of your battery tray all rusted out, and can you see through to the ground below? Ye-ouch!
  18. Pablo1914
    35
    Atlanta, Ga
    I don't what happened to this poor car. I bouth it two years ago and I'm trying to take good care of her..
    Thanks for your help with the date. I was reading it wrong. I bet that happened before the previous owner replaced the battery..
  19. dolj
    dolj Senior Member
    8,645
    4,396
    Gen II Prius are known to leak at the joint at the top of the hatch where the black roof strips end. Search (using Google) on Prius chat for water in battery compartment tire well. Is there any water in there, or is any water that leaks in there just going to drain out the holes?
    #39 dolj, Jun 16, 2015
  20. bisco
    52,854
    yes, you'll want to do some repairs to the battery area, very common to have water. find the leak and repair that, and buy a new battery, that one is toast.
    Pablo1914 likes this.
