, New to prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pablo1914, May 27, 2015.
  1. Pablo1914
    Pablo1914 Junior Member
    35
    Atlanta, Ga
    I took the battery to advance, and they told me that its ok.. It needs to be a bit recharged, that's all.
    Any thoughts about the code P0A80 pd?
  2. JC91006
    16,936
    8,647
    If you are still getting P0a80, you got a bad battery on ebay.
    Pablo1914 likes this.
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    Isn't the year first on those date codes on the battery? I'm pretty sure it is and that would make it the original (Dec 10th 2004). Which makes sense for an 05 Prius. Its not unheard of for a Prius battery to last 10+ years.
    52,855
    might be time to pick up a mini vci.
  5. Pablo1914
    35
    Atlanta, Ga
    I'm getting one of those.
    do you know about one that works with mac?
  6. bisco
    52,855
    no, but there are some threads.
  7. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    The software only runs under Windows -- either Win XP or Win 7 32-bit -- BUT you can setup bootcamp (or another 3rd party VM software such as VMware, Parallels, etc) and then install your windows in there.
    I know for sure that it runs on a MacBook in either Bootcamp or VMware.
    hope this helps.
  8. Pablo1914
    35
    Atlanta, Ga
    Hi guys!
    I bought a used battery and after installing it in the car the triangle came up..
    This is the reading for the battery I bought:
    1 7.6
    2 7.68
    3 7.68
    4 7.68
    5 7.68
    6 7.68
    7 7.68
    8 7.68
    9 7.68
    10 7.68
    11 7.68
    12 7.68
    13 7.68
    14 7.68
    15 7.68
    16 7.69
    17 7.68
    18 7.68
    19 7.68
    20 7.68
    21 7.68
    22 7.68
    23 7.68
    24 7.68
    25 7.67
    26 7.68
    27 7.68
    28 7.21
    I see number 28 low, and number 1 a bit low.
    I have replaced number 28 and now it has 7.68 like the others.
    I have discharged and charged number 1 a couple of times to try to bring it up, but it's not going above 7.60 (I did it with a 12v battery charger at 2 amps. is this acceptable?)
    Any thoughs?
  9. bisco
    52,855
    why not replace 1? are they expensive?
  10. Pablo1914
    35
    Atlanta, Ga
    I replaced 1
    Now I'm getting the triangle &a red power light and the word "problem" on the display.
    Car won't start.
    If I disconnect the battery and connect it back it starts for one minute and then the triangle, "problem" appears again. If I turn the car off, I get the red power bottom and it doesn't start again.
    I went to check mode pushing the display and lights on off 3 times to check the battery.
    It reads 12.3
    It reads 11.8 under load (pushing power bottom again)
  11. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Too funny. 12V charger at 2Amps, despite the individual module is rated at 7.6Volts! Try some some thorough research before attempting the whack-a-mole module replacement.
    1) Get mini VCI
    2) Buy a temporary subscription to techinfo.toyota.com, to get the complete repair procedures, illustrations, and many other useful aspects.
    3) You never read this thread, as it contains a how-to, and necessary equipment (definetly not a 12V battery charger). You should read it in its entirety to learn and gain a thorough understanding.
    Gen II Prius Individual Battery Module Replacement | PriusChat
  12. Pablo1914
    35
    Atlanta, Ga
    Thanks bro! I know I'm a mess..
