New Vehicle Shopping, Considering Prius V
Discussion in 'Prius v Main Forum' started by Point37, Sep 20, 2024.
  1. Point37
    Point37 New Member
    MA
    the problem i am finding is a used 2020s rav4 with about 80k miles is about $28k-$30k while a used 2020s crv with about 80k miles is about $23k-$25k...the rav4 is so popular they can still sell them vs the less pricey crv...for around the same range as the rav4 i can get an outback with 20k miles
  2. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    Honest question: Why not do that?
    They aren't terrible, the newer ones are better than the older ones with specific regard to oil consumption and transmission wear, and by now you know them pretty well- you know when it's time to trade it for something else.
  3. Point37
    Point37 New Member
    MA
    this may make the most sense...i am just very fearful of the oil consumption when i get into higher miles...i also read about a lot of head unit/infotainment issues...my gas mileage will be about the same so not really an improvement there...but an outback would be exactly what i'm looking for...i hear the hybrid outback version is coming in 2026...i also hear that the outback will no longer be a wagon in 2026...will be more of an suv
  4. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    That's the root of my suggestion: don't keep it until the miles are that high.
    Trade it earlier, which would mean a larger trade-in on whatever is next after. You don't have to use it all up- it is possible to own a car for a shorter window of time and not waste money. Heck, sometimes it gets you further ahead to trade earlier.
    I loved the old Outback, when they were still real wagons. Ever since they started with that big SUV body in 2010 they've been dead to my dollars.
    Point37 likes this.
  5. Point37
    Point37 New Member
    MA
    i usually like to bury cars cause i like to see how far i can get them to go plus i hate car dealers...yea the 2009 or earlier body style is the best but they are a little long in the tooth at this point...i don't like the look of the newer version but i'm not overly fixated on looks if it does the job for me...i would like a honda element which are ugly but i like the doors, cargo space and the flip up rear seats...but they get horrible gas mileage and are also old so they were removed from my list
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,140
    6,985
    Texas Hill Country
    If you need a reliable budget 10 year old car I would get a conventional Honda CRV or if a hybrid floats your boat, I would get a Prius c which had none of the gen3 problems.
    You don’t want the 2017 up Honda CRVs with the 1.5L direct injected turbo. Fuel dilution and direct injection carbon plus a conventional cvt tranny. 2017s and up also have the new r1234yf refrigerant which is $49 for a small 12 once can.
    #26 rjparker, Sep 26, 2024
    Point37 likes this.
  7. Point37
    Point37 New Member
    MA
    thanks everyone...ended up putting down a deposit on a '25 cx-5 preferred...seemed to meet a lot of what i was looking for...
    needs:
    check - reliability
    check has 40/20/40 - 60/40 folding second row
    check - pleather/leather or seat covers (because dogs)
    check is 15' - be able to fit in the garage have about 18’ of space would like to have 2’-3’ of that to walk around the front or back
    check has awd - awd or fwd
    check - not a cvt transmission if i can avoid it (toyota's planetary style cvt is fine though)
    check - timing chain, not belt
    probably not - would like 30+ mpg
    check 17s - smaller wheels with more tire
    check add on - splash guards
    check add on - all weather floor mats and trunk tray
    check - no lights in bumpers
    probably not, will need adapter - aux input
    equalish - more cargo space than my legacy (more cargo floor area, not necessarily height, hence the want for a wagon)
    check on this particular trim - no engine autostop without a button control with memory
    wants:
    check - dual driver memory settings
    i think so - dual bluetooth phone connections
    can add on but probably won't due to noise - window rain guards
    check wired carplay but can get a wireless adapter, will most likely be inconsistent - CarPlay
    can add on - 2nd row seat back protection (rubberized)
    check - heated seats
    nope - cooled seats
    check - backup camera
  8. bisco
    52,891
    congrats, all the best!
    Point37 likes this.
  9. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Just piping in that I recently tested a 2012 v hybrid battery with Dr. Prius paid app. The car had 135k miles on it and the hybrid battery tested at over 85%. Car was mostly driven in Wisconsin and Minnesota. Don't count them out just because a car hit some milestone. There must be other factors at play and some will go a fair distance.
  10. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    For those recommending the 2016 and 2017 v, is that just for lower miles? Or is the 2015 inferior somehow as it was a slight design change year?
  11. Mendel Leisk
    42,373
    Toyota revised piston rings (and pistons to accommodate them), on Gen 3 and the v. For the Gen 3 it was at a particular VIN, in model year 2014, and I believe the specific factory is a factor too. Similar story for the v; I’ve got a pdf here “somewhere” with explanation; will try to find later, if I get a chance (turkey day here…).
    I think it’s a safe bet the last production year of v would have the revised rings, and “possibly” the next to last model year as well.
    the older style rings are described as “low tension”, used due to lower friction. Toyota’s motivation to use these was undoubtedly to gain a few tenths of a mpg, which wears thin when you’re having to dump in quarts of oil every 1000 miles.
    #31 Mendel Leisk, Oct 12, 2024
  12. rjparker
    11,140
    6,985
    Texas Hill Country
    Some 2014 gen3s received the new rings and pistons. The last gen3 hatchbacks were 2015 while the last gen3 v’s in the US were 2017.
    If I had to buy a used v today it would be a 2016 or 17, even though the production numbers were small and their current availability is low because of the better Rav4 hybrids from those years. I might buy a 2016-17 v because of lower miles allowing 5k oil changes earlier in its life and less chance of the brake booster problem which still existed. Plus most had advanced safety features by then.
    Design issues in a gen3 engine still existed even though one factor, the rings and pistons, were updated. The gen4 engine revised those parts again along with significant changes to the cooling system, cylinder wall temperatures and egr take off points. Along with revisions to the egr* valve, intake and more.
    The gen3 problems were multifactorial and required a complete redesign of the 1.8L engine used in Atkinson cycle. Problems that were not issues in the earlier conventional ICE applications of the engine without stop start and thermal cycling.
    * For more egr information see the “EGR Fanatic” above
    #32 rjparker, Oct 12, 2024
    PriusPaddler and Air_Boss like this.
  13. Mendel Leisk
    42,373
    Attached is a pdf of the info @rjparker has supplied in past. It's basically this jpeg:
    I've just incorporated into pdf, maybe more portable.
    PriusPaddler likes this.
  14. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Thanks - I've seen that before. Is a Plant J any different from Plant 3 in terms of preference or reliability??
    My next car to visit is a J039225 from 2015. Two other vees I considered were Plant 3.
  15. Mendel Leisk
    42,373
    No clue, but wouldn't think so. It's necessary to note that "plant" digit/letter (7th from the end) to determine which sequence number (the last 6 numbers) is applicable.
