New Video: Toyota EGR Diagnosis Tips and Repair Tips
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Georgina Rudkus, Jul 8, 2021.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    Merkey and Grit like this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Nutzandbolts video is more deep in detail
  3. ChapmanF
    15,433
    At the same time, interesting to see a Toyota dealership mechanic's take on it.
    Merkey likes this.
  4. Georgina Rudkus
    3,148
    2,202
    Taylors, SC
    When I'm ready to do this, like the dealer mechanic, I will bite the bullet and spend the $200 plus dollars for the new upgraded intake manifold,
    At nearly 10 years old and just half a thousand to 26k miles, I might not even get there to service the egr in another 10.
    Merkey likes this.
  5. Mendel Leisk
    38,644
    The upgrade on the IM is EGR passages go to 1>2>4, vs 1<4, AFAIK. Simply cleaning the old one is quite easy too. I’d be more inclined to change the valve and cooler, especially if it’s high miles and REALLY socked in with carbon.
    DanWF likes this.
  6. Georgina Rudkus
    3,148
    2,202
    Taylors, SC
    I have a fully cleaned egr and cooler. At just a little over $200, a new intake manifold is chump change compared to the price of a new car.
    Rebound and Grit like this.
  7. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
    Its interesting the Toyota mechanic does not see the relationship between a hg problem and a sticking open egr other than one being mistaken for the other. He seems to believe the biggest egr issue is the valve sticking and not the cooler buildup. He replaces rather than cleans the egr valve, intake manifold and emphasizes loading the egr software update.
  8. Paul E. Highway
    Paul E. Highway Active Member
    200
    127
    Hawaii
    I installed updated intake manifold, new EGR cooler, new EGR valve, new EGR pipe, new water pump and oil catch can in March 2020 at 155K. COVID 19 cut back my driving a lot, have only driven about 10K since then. I wanted to have a baseline on all the EGR issues. Car runs super smooth on Costco gas and Techron fuel injector cleaner every 3 months. Hopefully dodged the EGR bullet, plan to check the EGR stuff at 50K mark.
    Georgina Rudkus and Mendel Leisk like this.
  9. Mendel Leisk
    38,644
    “This is the exhaust; it’s never going to be clean”, “as soon as the customer drives it, it’s right back as it was”, and “the intake’s very difficult to clean”. I’m maybe paraphrasing a little, but anyway:
    no, no, and no.
    Rebound likes this.
  10. ChapmanF
    15,433
    I can imagine the 'tournament' intake design being tougher to clean out than the old straight one.
  11. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    FWIW you can verify that the intake manifold's EGR ports are equal-ish by putting a water hose where the EGR pipe would feed in. Use a spirit level to keep the manifold flat and you should see equal flow out each of the four ports, which is easy to judge by how far each stream falls. Doing that before cleaning is also revealing.
    Yeah it's not a lab-grade experiment, but it can put your mind at ease over whether the internals are cleaned fairly.
  12. ChapmanF
    15,433
    I'm a big fan of not-quite-lab-grade experiments.
    Rebound likes this.
  13. wheezyglider
    247
    178
    SF Bay Area
    You should have been there when I took a hacksaw to my first-iteration 2010 intake manifold.
    For the record that plastic is tough as hell. (Personally I would no longer hesitate to clean the EGR passages with a brass bore brush if nylon didn't do the trick.) I never did get to see the innards before my 1-year-on-the-shelf rule kicked in and I binned it. Kinda regret that I never tested it with a torch.
  14. Mendel Leisk
    38,644
    One fat and one skinny bottle brush, a few rags and some brake cleaner: it’s clean.
    wheezyglider likes this.
  15. Georgina Rudkus
    3,148
    2,202
    Taylors, SC
    Cleaning the intake is fine, if one has more time than money. If you have both to spare, I'd go with the upgraded one.
    Toyota spent millions of dollars designing and making the new upgraded manifold. They don't take this expenditure lightly. I will still buy and install the new one.
    #15 Georgina Rudkus, Jul 9, 2021
    Rebound and nedear88 like this.
  16. Georgina Rudkus
    3,148
    2,202
    Taylors, SC
    It is made of 35% glass filled nylon.
  17. ASRDogman
    ASRDogman Senior Member
    6,054
    3,251
    Why did you replace the egr pipe? They are easy to clean and don't wear out.
  18. Paul E. Highway
    200
    127
    Hawaii
    there was some stubborn crusty stuff in the pipe so I added one to an Amayama order I was preparing, I think it was $27 and the shipping charge stayed the same. So entire EGR system new and pristine.
    ASRDogman likes this.
  19. ASRDogman
    6,054
    3,251
    So you saved the cooler and pipe to clean for next time?
    Georgina Rudkus likes this.
  20. Georgina Rudkus
    3,148
    2,202
    Taylors, SC
    Bought mine complete with the egr, the tube and the cooler as an assembly off of eBay, when it was apparent that there may be issues. They were cheap back then. The whole set was $120 delivered. All have been cleaned to "as-new" condition.
