New Visitor Need technical help and advice on 12v battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lbarrack, Nov 13, 2018.
  1. lbarrack
    lbarrack Junior Member
    34
    San Diego
    First, I want to thank the contributors here. I have read through the different threads and have tried using the knowledge gained to solve my problem but I have hit a point where I need some direct advice. I will give you my situation as brief as possible.
    Car - 2007 Toyota Prius Model 5 w/259000 miles.
    I took my car in to get an oil change at Walmart and was informed they could not start the car. They tried jumping it from the jump terminals and the car would not start. I believe they may have set off the alarm system and that is why it wouldn't start.
    To make a long story short, I replaced the battery and my gas mileage dropped. Reading the forum it was definitely under voltage (12.1 on, 11.7 - 11.4 on accessory and 14.1 on charging). I bought a new battery from Amazon, an ACDelco Yellow Top. Same thing happened. I paid attention to the energy readings and it seem to spend most of it's time charging. The battery would go from 1 purple bar to full green in a matter of 5 to 10 minutes of driving. I got a replacement with the same results. I bought a black and decker trickle charger and charged the battery. The readings after that were 12.6 ON, 12.3 Accessory and 14.1 charging. When fully charged, the car started running more on the electric motor and the gas mileage improved but after a few days of driving the voltage went down and the same symptoms appeared. Is it another bad battery - time to spring for the Optima, or could it be something else. Gas mileage is off by 5 mpg and dropping.
    Thanks for whatever suggestions you can give. Prior to the Walmart incident, I never had any trouble with the car.
    52,841
    welcome!
    1) the display is for the hybrid (traction) battery, not the 12 volt.
    2) sounds like your new 12 volt is fine
    3) your hybrid battery is on the way out. this often happens to old batteries right after a service because of the way they are treated, but was inevitable anyway.
    4) you can try a battery conditioner, cell replacement with balancing, or a new hybrid battery
    5) all the best!(y)
    edthefox5 likes this.
  3. lbarrack
    34
    San Diego
    Thanks for the fast reply Bisco. This is not the answer I was hoping for but such is life. I have a few more questions for you.
    1) I mentioned the display only to note the changed behavior of the hybrid system. I read somewhere on the forum that a low 12 volt battery would fool the system into going into charge mode to stabilize the 12 volt battery even though the hybrid battery was charged and that the hybrid battery would also discharge to charge a low 12 volt battery.
    When the 12 volt battery was fully charged after I charged it and showing 12 .6 volts (measured at the terminals using a voltmeter and using the diagnostic screen under 'Signal Check) I was back to 38 to 42 mpg. As soon as the battery voltage dropped back down after a few days then the mpgs went down and the electric motor was used less and the system went back to mostly charging.
    2) From what I've read, a 12 volt battery that is at 12.3 volts is low and with accessory button on down to 11.4 - 11.8 is also low. The recommendations on this site is the battery should be replaced.
    3) I hope not but if true, what service caused this so I can avoid it in the future.
    4) Do you think a battery reconditioning would work given I haven't had any errors related to the hybrid system. Is this a do it yourself project or do I take it somewhere. I live in San Diego, any recommendations and what is the general cost for this?
    5) Thanks for you comments, I really appreciate your help.
    52,841
    the 12v is charged by the hybrid battery. so a weak 12v requires more charging, and the engine runs more to charge the hybrid battery. it is too subtle too notice, except in lower mpg.
    sometimes a service tech leaves the car on in neutral, which doesn't allow the engine to run, but the hybrid battery is charging the 12v, and not getting recharged itself. same thing can happen in a car wash where you have to be in neutral to pull the car through, because prius has to be in ready to be put in neutral.
    if the hybrid battery is weak, this can put the weak module(s) out of balance.
    a conditioner, see @jeff652 for prolong model, can rebalance if the module isn't too far gone, or if it is replaced. usually, tech stream software is used to determine the bad modules. i can't say whether it would work or not.
    @Raytheeagle has some experience. all the best!(y)
  5. Mendel Leisk
    42,338
    There was another story here, in the last year I think, someone getting a Walmart oil change and ending up with a dead battery. They had messed up in some way. Maybe someone with better memory can find it? I googled without success.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    @Mavi is in your area and is working on his pack reconditioning. He’s local and might be equipped to answer tor questions ;).
    I have used the Prolong equipment successfully and share with 2 other members here:).
    Good luck and keep us posted (y).
    SFO likes this.
  7. Kal Of The Rathi
    Kal Of The Rathi Junior Member
    28
    Anywhere but New Eden
    So, how much luck have you had with reconditioning?
    My 2008 is at 190K, low HV to full green on a downhill ride into town. I have both Prolong bits, discharge and charger. I have yet to discharge down to the lowest setting. I am hesitant to do it, some of the comments weren't positive it was a good move. Past that, it does seem to settle it down a bit.
    I am planning on replacing the HV battery next year, just saving up for the replacement from here (not OEM).
  8. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Had really good lick:).
    If you discharge down to the lowest setting, you’ll definitely disturb any undesirables in the modules and remove any cell “memory”. The 84 volt setting isn’t low enough to do this.
    I have not taken it down to the lowest setting before, but that doesn’t mean I wouldn’t. Our 2010’s hv battery is performing well and haven’t had a need to. But if the circumstances were different, I wouldn’t hesitate.
    Hope that helps(y).
    Kal Of The Rathi and SFO like this.
  9. lbarrack
    34
    San Diego
  10. bisco
    52,841
    there are a lot of hybrid battery rebuilding threads here with great detail. i'll give you an overview:
    1) new oems battery $2-3,000. last 10 years or so, no problems.
    2) new aftermarket around $1,600. not much long term data, but lots of factory testing and good reputation
    3) reconditioned battery: prices all over the place, warranties all over the place, mostly bad reputations.
    only as good as the company standing behind the warranty, and you have to be prepared for downtime every time they need to replace it under warranty, which may be often
    4) diy rebuild: this is the cheapest avenue and can be as good as your willingness to read and learn, investment in some tools, and the time you are willing to put into it. the longer and more patient you are, the longer the rebuild will last. but it's not new, and the older cells will still fail now and then, and you have to keep taking the battery out and repeating the process.
    m.wynn, Raytheeagle and Mendel Leisk like this.
  11. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    I successfully did rehab my pack.. but then I was given 2 newer 2013 battery packs.. so I sold my working 2007 pack, with just one cell changed out, with the 2013 packs. To cut my story short, I couldn't ever get them to work for long. I purchased the $1600 batteries shipped from Toaster here, installed them, and been good since. So in short.. if changing out a cell and balancing out doesn't fix your issue.. or if all your cells look fine. Don't waste you time and swap the batteries for Toaster's new ones.
    Note I did manage to sell the cells over time on ebay for around 700-800 a pack.. so thanks to god.. it all worked out. Life is good ;)
  12. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    I too did the "full recondition" about Aug of 2017, Sept of '18 I was back in replacing another module. I and other PC members spotted the 3rd affected module in '17, but having only two on hand at the time, I did not replace the 3rd (it was well within spec, but at the bottom of average).
