New work record - 74.9 MPG!
Discussion in 'Prius c Fuel Economy' started by KYBlue, Aug 29, 2013.
  1. KYBlue
    KYBlue Active Member
    227
    112
    Will post pic later, but roughly 33 miles to work Tuesday morning.
    I had been meaning to jack my tire PSI up to 40, and when I checked I had some at 30 and 32 :-o
    The change has made a big difference in all my trips, but I went from a high of 72.x to almost 75 to work - I'll take it!
    Sadly, summer heat is back here, so low 90's are killing me on the way home, only getting 58-62 on the way back :-( The cool mornings are awesome though!
    52,855
    saweeet!(y)
  3. coyote303
    coyote303 Member
    112
    64
    Colorado
    Is there an elevation difference that would be causing the majority of the difference? Or is traffic simply worse in the evening?
    Regardless, congrats on the great mileage!
  4. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    My best MPG is 161.0 on a 9,2 mile trip to the movies. It was downhill (1028 ft. drop in elevation) found using the Google Earth App. Coming home uphill the MPG was 54.8 MPG. I have made this drive along the same route many times with about the same results!
  5. KYBlue
    227
    112
    Niiice. The biggest difference I believe is that on the way in - I'm driving windows cracked, no AC, way home, instead of say 70 out, it 90+, AC on. There is an elevation difference which probably plays a factor but on a few cool days when I don't need AC on the way home I can see the MPG jack up to mid to high 60's.
    Chris
  6. Phil 29 Palms CA
    119
    44
    From my garage to the first stop sign is about 1.8 miles. Driving this distance the car loses about 800 ft. When I make this stop my EV battery is always fully charged. The Prius C is always then in the EV stealth mode. Even in the desert winter time. That is why I can create large MPG's. Experience climbing the 800 ft. going home has taught me 35 mph is the best mileage speed going up my hill.
  7. Species5618w
    Species5618w Member
    140
    50
    What about the cars behind you?
  8. I swear, every single time I see the title, I read it and it says "New world record..." o_O mainpagehastinyprint
  9. SDBoltsFan
    SDBoltsFan New Member
    17
    Wow, that is impressive!!! I hope I get remotely close to that!
  10. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    I just put gas in for the first time. calc. mpg 61.05. I drive a lot of short trips in town.(y) I think I can do better so I am going to work on that and see how it goes.
  11. KYBlue
    227
    112
    61 out of a tank is my typical average..... I think some of the smaller trips that are sub 2 miles, and mid-day at work for meetings + my return drive home (58-65 depending on the day, temperature etc) kill it.
    Chris
  12. xraydoug
    571
    176
    Roseburg, Oregon
    In my routine I drive 3 miles to work then 3 miles home, 4 miles to pick up my son from practice then back. then another child to practice then back home an hour later. the mpg is great when I go round trip without the car cooling off. Also the A/C when it is really hot can drop mpg to 40 or less and that is in eco mode. so I try to just put the window down.:)
  13. Michael M. Maslowski
    29
    Halifax, Nova Scotia
    Excellent, thanks for sharing!
    TatumRob likes this.
