Newbie in trouble: "Check hybrid system"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RogerHq, May 22, 2015.
  1. RogerHq
    RogerHq Junior Member
    70
    SWEDEN
    Well, the battery packs are the same AFAIK, it will come next week.
    The error codes looks slightly different in my list, I'm not sure what the" Interlock switch" means, There is an orange thing on the battery pack I thougth it was the 120A fuse?
    P0571 is listed, as I have mentioned, under the cruise control header, is that wrong?
    #21 RogerHq, May 30, 2015
    51,937
    it might be different, but i wouldn't take the dealers word for it. perhaps someone from europe can help, or when you open the battery up, you can compare.
    51,937
    the orange thing is the interlock switch. there is a specific method for closing it when you wrap things up. it's not intuitive, and the car won't become ready if you do it incorrectly.
  4. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    You might want to PM GrumpyCabbie who knows a lot about EU Prii.
    We've had almost no Gen3 batt failures in the USA on PriusChat.
    However, EU Gen3 taxis have had some battery and inverter issues, you'll see a bunch of threads on that.
  5. RogerHq
    70
    SWEDEN
    Used Hybrid battery pack approaching... How to install?
  6. JC91006
    16,768
    8,565
    There's an excellent video at Dorman hybrid website
  7. RogerHq
    70
    SWEDEN
    Thanks for warning me Bisco ;-)
  8. RogerHq
    70
    SWEDEN
    Thanks JC
    Looked at the GenII Installation, seems rather straightforward, differences to GenIII is I guess minor.
  9. RogerHq
    70
    SWEDEN
    Hybrid Battery arrived! Now, How to Install? There is some obvious physical differences between GenII and GenIII.....
    #29 RogerHq, Jun 2, 2015
  10. RogerHq
    70
    SWEDEN
  11. RogerHq
    70
    SWEDEN
    IMG_0630.jpg I hope it will look like this, the broken one....
  12. RogerHq
    70
    SWEDEN
    Another question is if some prepraratory measurements can be made before installation using a simple Voltmeter?
  13. Patrick Wong
    18,210
    6,510
    The physical design of the G2 and G3 traction battery cases differ. So you will need to open both units, and substitute battery modules from the newly arrived battery case into your original equipment battery case.
  14. RogerHq
    70
    SWEDEN
    Well, this might be true for US vehicles but late 2009 cars in Sweden appear to have the same battery pack. Their physical appearance are the same and the part number too. My battery is unpacked and tested now and my meter reads 217 Volt DC from two thick cables coming from the cell stack, that's fine to me. Now I might need the installation procedure for the G3 car or maybe it's just to do it:
    1) Remove the orange thing
    2) Remove all cables (but first make sure no High Voltage are left on the main power cables and connectors)
    3) Remove all relevant Nuts&Bolts
    4) Change packs
    5) Inverse 3-2-1
    Or maybe I should disconnect 12V first?
    #34 RogerHq, Jun 3, 2015
  15. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    2009 Prius in Europe = Gen III
    2010 Prius in USA = Gen III
  16. Mendel Leisk
    41,457
    I like the picture of your car. It looks to be still a cab at heart. :)
    Yes, you need to disconnect the 12 volt battery early in the process. Here's instruction for North American third generation Prius, hopefully very similar:
  17. RogerHq
    70
    SWEDEN
    Thanks Mendel!
    I read the 30 pages, well most of them, it looks familiar, there will be some investigation and disassembly tomorrow.
    Yes, I like my yellow cab, there are 1300 of them in Stockholm from different carmakers, a lot of them are Toyota Prius!
    / Roger
  18. RogerHq
    70
    SWEDEN
    Resetted the error state and run the the car some weeks only to return to the same error. That was of course expected. Alas, today the car refused to start and I have to dig into this thing again, wish me luck!
  19. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ Good Luck!
    You will be so much better off with a VCI cable and software to read DTC codes.
  20. RogerHq
    70
    SWEDEN
    Hybrid Battery successfully replaced but the system ignores it. According to the manual "some systems have to be initialized" So how do I do that?
