newbie looking to buy 1st Prius...need feedback :)
Discussion in 'Gen 2 Prius Main Forum' started by Deva, Jan 12, 2015.
  1. Deva
    Deva New Member
    Hello All,
    new here 1st post on prius chatt...yay
    looking to buy my 1st used prius porb. a gen. II 2005 to 2008 any feedback on things I should look for in a used prius? how many miles are to many? looking to keep the car as my main car for the nest 5 years. hopefully more.
    thanks!
  2. JC91006
    16,936
    8,647
    Depending on your budget and how much you'll be driving. If it were me looking for a car that would last 5 years without much repair, I would look for one with no more than 100k miles on it.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    This is a tough one. You are potentially talking about a car that is 10 years old and might be on the verge of needing a new main battery, which would run from $1500 to $3000; probably closer to the high end.
    It is highly unlikely that a conventional car with similar age and mileage would be needing an expensive repair like that.
    While I have two hybrids, I don't think they are good choices for everybody.
    Given your target years, I assume that the budget is somewhat tight. A good used Corolla might be a better choice overall.
    52,822
    welcome! all the best.(y)
  5. GregP507
    GregP507 Senior Member
    3,002
    481
    On the plus side, Toyota is known for building superb reliability into their cars (Obama asked the Detroit automakers: "Why can't you build a Corolla?") but on the negative side, electrical components are harder to build reliability into. The truth is that the hybrid components, especially the battery are prone to fail due to the most subtle and inexplicable of reasons. For that reason, most of us rely on the long manufacturer's warranty on hybrid components that comes with a new car. If you examine the repair issues in the older Prius cars, there seem to be fewer problems with the mechanical components and more problems with the electrical components, therefore buying an older Prius is more of a gamble than with most conventional cars. However, if you are handy with diagnostics and doing your own repairs, the Prius may be a good bet.
  6. Deva
    Deva New Member
    I am looking at an 07 with 152K miles. its a bit more than I would like, but my budget is only 6K. I am also considering a Scion with only 84K I fancy the prius more as it's get a bit better MPG and I have always wanted one. hmmmm
    if I do have to replace the battery it there online tutorials that show you how to do it? can it be done by someone with little car knowledge?
    thanks
  7. GregP507
    3,002
    481
    I don't think it's too difficult if you follow the directions, with particular attention to the safety precautions. The voltages involved can be lethal.
  8. Deva
    Deva New Member
    thanks Greg. that is what I am thinking too. wish I had the funds for a new prius C or a leaf.
  9. JC91006
    16,936
    8,647
    If you have only a $6000 budget and you are limited on funds for high priced repairs....I would suggest you look at the Scion instead of the Prius
  10. Deva
    Deva New Member
    what do you guys think about 5K for a 07 with 152K on it? car looks clean form pics...no service records.
  11. JC91006
    16,936
    8,647
    For someone that's familiar with the car, this would look like a good buy. However, since you are not familiar with the car and the known problems, I would stay away......especially with no service records.
  12. Deva
    Deva New Member
    yeah the more I think about replacing the battery the scion might be a better choice ...I know its a gamble could last well in to the 200k or it could be going out now. is there a way to tell? if I took the car to a dealer can they check the battery?
    I thought I read on here you could pick up a battery for 800? I see green tech has them from 1200 to 2200. is there any where else that has good prices?
  13. GregP507
    3,002
    481
    The Prius will still function with reduced battery capacity. The regen-reserve will be less, therefore the fuel economy won't be as good, but as long as the system doesn't shut out the battery, it should still give you good fuel economy and performance.
  14. Deva
    Deva New Member
    is there any data on the % of prius that need a battery replacement at certain miles? I know what a wire question. but if say 50% of car needs batteries at 150K it will give be a better understanding of my over all desirability of getting one,
  15. JC91006
    16,936
    8,647
    Let's say the number is at 5%, and you end up being in that 5% with the car you buy. What would you do then? Play out the worse case scenario and if you can handle it, buy the car. It's like rolling dice, can you take the loss if it happened to you?
  16. Deva
    Deva New Member
    ^ good point just like to know my odds ...to make more of an informed choice one basted on facts not of fear or pure desire to have a prius...haha
  17. GregP507
    3,002
    481
    Kudos on that, lad.
  18. JC91006
    16,936
    8,647
    Also in many cases when buying used (higher than 5%), the car will most likely have a problem (how severe??)....that's why it's being sold.
  19. GregP507
    3,002
    481
    Would that it were as low as only 5%.
  20. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The warranty on the battery is 10 years/150000 miles.
    Do Prius batteries fail out of warranty? Yes.
    Do parts on other 10 year old cars with 150000 miles fail? Yes.
    Chances are a higher mileage Prius will need more maintenance than a newer one. How old are the brakes, tires, and 12v battery? When were the fluids replaced? Dealer service history can be found at Toyota Owners Official Web Site: Service Coupons, Owner's Manuals, Service Scheduling And More by entering the VIN.
    How much work will the 84000 mile Scion need? When were the belts replaced, especially the timing belt?
    You could get a flat tomorrow. It could be a $10 patch or a $100 tire. How much money is in your repair fund?
    Personally, I believe that Prius will outlast the Scion and cost less to maintain over the same period. It will definitely be cheaper to operate.
    Depending on the package, $6000 could be a fair price. Download the brochures for the model years so you know what you are buying. The packages are not the same year to year.
