Newbie. Need advice on buying a used prius.
Discussion in 'Gen 2 Prius Main Forum' started by Ramie Khung, Jan 31, 2018.
  1. Ramie Khung
    Ramie Khung Junior Member
    47
    17
    Montreal
    Another question for you guys. Its -5 degres F outside and i noticed that the engine is always running..except when at full stop. Drove for around 20 min and electric is only working from stop only if start off realllllly slow.
    Dont prius run only on electricity under a certain speed? Does the weigh on the pedal affect its operation?
    Thanks
  2. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Yes, and yes. Try turning off the climate control system and see what happens.
  3. Prodigyplace
    12,540
    11,767
    Central Virginia
    You may also want to try some foam pipe insulation to block part of the lower grille to help the engine heat up faster. Toyota actually has active shutters on the new Prius.
    Raytheeagle, Ramie Khung and SFO like this.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    A simple "YES" doesn't really cover it.
    The gas engine needs to run to keep the HV battery warm......in addition to warming other parts.......and YOU.
    In a lot of conditions, the slightest little bit of acceleration kicks it on.
    Perfectly normal.......probably.
    Ramie Khung likes this.
  5. dolj
    dolj Senior Member
    8,435
    4,285
    Wellington, New Zealand
    I think you'd be pushing it up hill in -5ºF conditions, to be quite honest. You don't need to focus on whether you a running on electric or not, just let the car do its thing. If you need to accelerate take the opportunity to run the ICE, after all you need heat too.
    #65 dolj, Feb 5, 2018
  6. Deft Jef
    Deft Jef Junior Member
    27
    Chicago
    Based on what I've read in prior posts this may be indicative of a small head gasket leak between cylinders 1 & 2. A small amount of coolant is seeping into the cylinder(s) causing the misfire upon start-up before it is eventually burnt off. Any good technician should be able to diagnose the dual mis-fire and I would recon the dealership knew what the issue was but claimed ignorance as to not have to honor the warranty with a new engine or digging into the engine to replace the head gasket.
    #66 Deft Jef, Feb 5, 2018
    SFO likes this.
  7. Ramie Khung
    47
    17
    Montreal
    Now if I get all the service record and check engine code logged when under warranty.. I wonder if I could pull something out of it. But them why would the dealership play ignorance if all repair done under warranty would be paid by toyota (easy money for them).?
    padroo likes this.
  8. Deft Jef
    27
    Chicago
    The combination of a lazy and/or incompetent technician combined with the fact the original owner didn't press the issue. Where I live the vehicle wouldn't pass the every other year emissions test and the dealership would have been forced to address the mis-fire more extensively.
  9. padroo
    padroo Senior Member
    2,763
    2,252
    Dealerships don't make as much on warranty work and neither do the Toyota techs. They would rather have your money instead.
    If you are going to claim warranty work don't clear the codes.
  10. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    This is the part that confuses me, too. If I had a car under warranty, and the car was throwing a code, I'd make sure it was repaired under warranty. And I would have escalated it.
    I've had good experiences dealing with Toyota North America and there are many cases here where corporate helped with traction battery replacements for Prii that were out of warranty.
  11. padroo
    2,763
    2,252
    I am on my second Prius bought from two local dealers. The first one ten years old o lyrics saw the dealership two or three times for light bulbs under warranty and recalls and now my new one.. so far I have no complaints.
  12. Ramie Khung
    47
    17
    Montreal
    Called the dealership who worked the car. The misfire was always due to water in the fuel system. How common is this and whats the best way to remove the water?
  13. Prodigyplace
    12,540
    11,767
    Central Virginia
    Was the water in the fuel tank or just the engine? Some people have had condensation & oil in the engine intake when the engine is cold.
    The best solution appears to be installing an Oil Catch Can to remove it before it reaches the engine. The can needs to be emptied regularly. @danlatu here is our main expert on this.
    danlatu and Ramie Khung like this.
  14. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    I was able to get a printed copy of the service records from the local dealer by offering up my VIN, they also updated the name on file for the vehicle warranty.
  15. Ramie Khung
    47
    17
    Montreal
    Ya i did. Got the full record. Thanks!
    Raytheeagle and Prodigyplace like this.
  16. Ramie Khung
    47
    17
    Montreal
    I feel like I got a really good deal. The last owner really did all the necessary maintenance and more.. brakes pads and disk were replaced recently. Water inverter pump and spark plugs not too long ago. Getting the full maintenance history is quite reassuring.
    Prodigyplace likes this.
  17. danlatu
    danlatu Senior Member
    533
    1,363
    maryland
    I would say, not very common. Especially when the car is driven often. I have heard of to many excuse's from mechanics. They say things because they think people don't know any better. They are just as bad as the finance department at the dealer. They like to sugar coat things to justify the repair bill. Does the knock only happen at start up? How is the level of the coolant reservoir? Some owner's like to ditch their car before they think expensive repairs are in order. When our 2010 prius knocked at start-up around 75k, WT F TOYOTA! Maybe a nissan:p:p but toyota? Cars that have blown head gasket's knock like this. Upon digging, I ripped apart the intake plenum, and found wet oil inside the intake plenum and traced it back to the pcv valve. I cleaned the intake plenum, with a rag and made an oil catch can out of a ball jar. 3 years and 118k later, the prius has not had one knock period. Both of our prii have oil catch cans/occ and they run smooth. The prius is a great car, but if it breaks down on you, it's big $$$$ to fix, more expensive to fix than your average car. Look and see how much an ac compressor or a catalytic converter is new from the dealer for fun?
  18. danlatu
    533
    1,363
    maryland
    Check the spare tire area. Does it have water in there? I had a 2005 and found water in the tire area and the battery bus bars were all corroded. The triangle of death popped up and ended up with 1 bad battery out of 28 cells. I replaced the bad cell for 30$ with a used one and rebalanced all the cells with my quadcopter charger and car drove fine. I bought my 2011 prius for 2k$ with a blown head gasket:)
    #78 danlatu, Feb 7, 2018
  19. Ramie Khung
    47
    17
    Montreal
    Theres no knocks on startup really. Engine just shakes a bit for a couple of seconds (barely noticeable).
    From the service history I notice the spark plugs were changed 100k miles ago. I think they are due.
    Also..from an almost empty tank I was only able to fill up 8 gallons? Why is that? Now im halfway the tank and i barely drove 90 miles even the computer states 36 mpg...confused.
  20. padroo
    2,763
    2,252
    Gen 2 Prius have a bladder in the gas tank and it doesn't take fuel well in the winter. They did away with it in later generations, it's just something everyone has had to live with. Do a websearch, prius gas tank bladder and you should get all the information you ever wanted.
    That doesn't make it any easier but it's just the way it is.
    Cold weather affects all cars, a Prius is no exception but worse because it affects the big traction battery too and check your tire pressure, the pressure drops when it's cold.
    Raytheeagle, Ramie Khung and danlatu like this.
