Newbie. Need advice on buying a used prius.
Discussion in 'Gen 2 Prius Main Forum' started by Ramie Khung, Jan 31, 2018.
  1. Ramie Khung
    Ramie Khung Junior Member
    47
    17
    Montreal
    Im just looking for options. If compression is fine, was thinking of changing the injectors.
  2. Prodigyplace
    12,569
    11,782
    Central Virginia
    I would tend to stick with OEM or at least third-party ones that the manufacturer says are for the Prius.
    Your link mentions 2004 - 2007 and you have a 2009 Prius, IIRC.
    HPrimeAdvanced and Ramie Khung like this.
  3. Ramie Khung
    47
    17
    Montreal
    Not sure if you guys the same link. Mine says 2004-09
    Prodigyplace likes this.
  4. Prodigyplace
    12,569
    11,782
    Central Virginia
    Sorry. I guess I misread that?
  5. padroo
    padroo Senior Member
    2,763
    2,252
    The front of the engine and number one cylinder should be the passengers side. All cars I have ever worked on the transmission is where the rear of the engine is no matter what it's orientation is in the car.
    You swapped the coil on plug and installed new plugs and the misfire stayed on number one cylinder, if this is correct how hard is it to move the fuel injectors to known good cylinders. I have never worked on this fuel injection system because my old Prius never gave me a problem. I'ts all about time versus money when troubleshooting. Go ahead with the compression test first, it's the cheapest and doesn't take long. Here is another problem I don't have an answer to is how to take a compression test on a Prius because of the way it is designed to start. If you are going to buy a compression tester I would look into a Cylinder Leak Down Tester instead but you will need an air compressor to do that and it is actually a better test. Just some thoughts.
    http://www.harborfreight.com/cylinder-leak-down-tester-62595.html
    Ramie Khung likes this.
  6. DMC-5180
    DMC-5180 Active Member
    294
    134
    I gonna chime in here because My car had PO300 and P0301 when I bought it. @123k mi. The first thing I did was all new plugs. Cleared codes only to have it return after 2 drive cycles. The next thing was swapping cyl1 and cyl4 Coil positions. Cleared codes. Code returned after 2 more drive cycles. The next thing I tried was Fuel injector cleaner. Cleared codes again. This time the MIL stayed off for about a week. Then returned. I tried 3-4 tank fulls with injector cleaner. Each time it would last about a week the MIL would return. Finally I decided to replace the injector on Cyl 1. You can do it without removing the rocker cover. 1 only replaced the 1 injector $ 32 from Rockauto at the time.
    Cleared codes and the never returned. I’ve put another 147k Mile on it and no codes for misfires have ever returned.
    Btw, replacing injector 1 or 2 is relatively easy. However with 3-4 you would likely need to remove the rocker cover. I would avoid replacing All the injectors for that reason. That’s a much more involved job. I changed the cyl 1 injector in about 20 minutes being very slow and deliberate. You need to be very diligent to get the injector fully seated within the fuel rail. Those thick O-rings are a tight fit and require a firm push to seat them.
    Here is the thread I referenced when I had my problem. See post #13 for replacement details. I commented several posts later with my results.
    2005 Prius P0301 misfire | PriusChat
    iPhone X ?
  7. Ramie Khung
    47
    17
    Montreal
    Very helpful. Thanks!
  8. Ramie Khung
    47
    17
    Montreal
    Update.
    This morning, cel light was blinking. I plugged in the reader and got a random misfiring. Some misfiring occured in cylinder 1,2,3. See attachments. Weather was mild ydya and today was 2-3 degrees colder. Could it be water??
