Newbie question: adding nav receiver to Prius II
Discussion in 'Gen 3 Prius Audio and Electronics' started by macdot, Nov 17, 2010.
  1. macdot
    macdot Junior Member
    25
    I'm by no means versed any much car anything. However, I have tinkered with computers and other electronics, so I'm not completely in the dark about what I'm asking.
    Is there a starter guide to replacing the Prius II's stock stereo with a navigation system? I know it's possible, but I want to be sure to retain all the non-radio functionality, steering wheel controls and probably other things that I'm forgetting about.
    Also, in regards to satellite radio... I have a separate kit since I use it at home and in the car. I know the Prius is wired for XM, is there any chance when I do the stereo install that I'll be able to connect the antenna to my car dock?
    Thanks!!
  2. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    See the link below:
    http://priuschat.com/forums/gen-iii...-another-rosen-navigation-system-install.html
    If you think that you can follow these pictures, then you probably could install a new radio/nav unit.
    Keith :welcome:
  3. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
